83 dash removal
Old 09-12-2008, 01:09 AM   #1
bigwinslow is on a distinguished road
83 dash removal
i got an 83 s10 4x4 i need some help with. how do you remove the dash from this truck and how diffucult will it be
Old 09-12-2008, 02:19 AM   #2
That's Life
Xtremegurl's Avatar
Xtremegurl has a spectacular aura aboutXtremegurl has a spectacular aura aboutXtremegurl has a spectacular aura about
Re: 83 dash removal
it's not hard but i can't remember for the life of me how my 1st gen dash came out, it's been 3 summers since that was
Old 09-12-2008, 10:12 AM   #3
Fan of the S-10
jtcfanof3's Avatar
jtcfanof3 is on a distinguished road
Re: 83 dash removal
Actually,the dash itself comes out pretty easy,the top portion is held on with 4 smaller screws in the defrost vents,then its only a couple more at the bottom and the one in the brace below the radio area,but the hard part is unhooking clips and relays from the back of the dash,this is difficult cus the dash doesnt pull away alot from its location,just take it easy.
Old 09-13-2008, 11:14 PM   #4
NCRides's Avatar
NCRides is on a distinguished road
Re: 83 dash removal
It makes it much easier if you remove the steering collum, the gauges and headlight switch then disconect the heater wires and vacume lines pull the heater control out as you pull the dash out you will find all the rest of the wires that need to be disconected
Old 09-15-2008, 08:22 PM   #5
easterwabbit
fastr68's Avatar
fastr68 is on a distinguished road
Re: 83 dash removal
drop the column down
ive bene here done this in these trucks a few time
the entire dash is one piece and all comesoff the firewall completely
gotta disconnect wireplugs and such its tedious work disconnecting stuff
bolts in lower corners bottom of dash take them out
glove box door off
pull light switch and heater panel and unplug the wiring to them
cig lighter
forgot if you gotta pull the sterio out too but im pretty sure you have to also
you basically are removing everything
no matter what you try to do
itsnot that bad
but then it is
depends on your technical abilities
im not afraid to take car dashes out i have done billlions now for heater core replacements
recently a 95 ford pickup and a 97 plymouth breeze and a bonneville 92
im always the one who has to do them, because everyone else is too scared to haha
good luck
Page generated in 0.08786 seconds with 12 queries
