I have $500 to spend on my truck and not sure what i should det performance wise. It is a 91 Sonoma with a 4.3L and auto. I found a 5/6 lowering kit for $600 but i don't want to spend that money right now. What performance parts should i get? I allready have throttle body spacer, KNN, Flowmaster Exhaust.
Thanks |
baby blue
Re: $500
shift kits are pretty cheap, only thing is when you truck shifts, it shifts hard
not everyone wants that could also invest in polyurethane mounts/bushings, itll help with cornering |
Re: $500
Right now the tranny shifts really hard from first to second. Not sure if there is a shift kit.
Mr. Sparkle
Location: Southern California User is: OffLine ![]() ![]() ![]() ![]() |
Re: $500
You could get a performance cam, but I think with Installation its going to be more then $500. I bought a Performance TBI unit and Noticed some performance gains.
Re: $500
cam sounds good... id do that
Re: $500
i would keep saving for the drop, you can get a nice 3/4 for around 500
Re: $500
where should i go to find parts for the drop?
Re: $500
i think that me lowering is not the greatest idea because in the summer i tow a boat to lakes. Will i be able to tow a boat even when its lowered?
Thanks |
Truck #121616
Re: $500
Re: $500
i know nothing about towing someone in the drop section will but if your gonig to lower it i would go to summit.com
here is the stuff i went w/ but i have 2nd gen (x2) http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/partde...5&autoview=sku |
Re: $500
electric fan/ignition upgrade
Re: $500
Re: $500
3/4 drop at jc whitney.com was $310. Comes with spindles, springs, and drop blocks.
Re: $500
thanks i will look at all the advice and make my secision but i am leaning towards lowering it.
Re: $500
i was looking at the jcwhitney store and i found some lowering blocks for the rear and some 2 inch drop spindles for the front. I was wondering if you guys so on that website lowering springs and leafs as i want to go lower with my truck. Also would rear sway bar upgrade be good for handling?
Thanks |
Crazy for a square body
Re: $500
You can tow when it's lowered but keep in mind most trucks lower in the back when a trailer is attached. So since you are already lowered you would bottom out quicker when the trailer is attached. Basically if 5" is the max you can go before hitting the frame and you lowered the truck 3" and the trailer being attached would make it sag 2" in the back then you would be riding on the frame in the back.
You could always install helped bags in the back for when you tow stuff so it won't sag down |
Re: $500
$600 for a static drop lowering kit seems abit pricey. I'd check around on ebay and the classifieds and piece together a kit with used components, although I wouldn't suggest reusing springs or ubolts. I know I got my spindles for $75 and my leaf springs for $100, so $175 for a 2/3. And blocks are only 30 along with springs can be had used for 75 for a total of $280. Just a suggestion.
Registered Boozer
Re: $500
use s10forum go talk to the guys in the avs forum and ask them about lowering kits they will hook you up!
If you plan on lowering it |
Re: $500
Re: $500
good to no
Re: $500
I got my 2/3 spindles and blocks for $100 just look asround on the classifieds
