i searched and did not find what i was looking for.i got a 88 4.3 s10 pick up which is which and what do they do.my gauge is not working and one person swears its the sensor and the other says its the switch.i know one is supposed to be for the computer and the other for gauge or maybe im wrong.somebody give me some info on what the two do where i dont buy the wrong part
The sensor for the gauge is at the passenger side in top of the exhaust manifold.
A single green wire goes there.
Take off the wire and connect it to ground (ign. on). The gauge must move to max temp.
If it does the sensor is bad.
If not it could be the gauge, the wire or a bad ground somewhere by the cluster...
ok thanks ima make sure the gauge is good when i get around to replacing it.gotta replace my serpentine belt,radiator hoses and a power steering line first fortunatley
