2003 4x4 on 1991 2wd? - S-10 Forum
 1Likes
  • 1 Post By Xnke
post #1 of 6 Old 03-18-2017, 10:26 PM Thread Starter
RustyDime's Avatar
User is: RustyDime is offline
I have a 1991 2wd s10
I have a 2003 4x4 Blazer that is truly only good for parts anymore
If i take the front axles and diff off of the blazer and fab something to mount the axles and diff on the s10, take a tcase from a early gmt400 with the manual shifter, and get a driveshaft made, will it really "work"? If anybody has done anything similar would there be anything to look out for? I know anythings possible but i want to know if i can do this or if it would just be easier to sas it?
Thanks in advance guys!
post #2 of 6 Old 03-18-2017, 11:57 PM
oldeerslayer's Avatar
Re: 2003 4x4 on 1991 2wd?
SERIOUSLY?
The least expensive and most effective way to do what you are asking is to crush both of them and go buy a 4wd truck. An S10 if that's what you want.
post #3 of 6 Old 03-19-2017, 01:05 AM
User is: Xnke is offline
You can section the front frame and slide them together-S10 frames are slipped together in two sections and welded.
This is definitely and "Advanced Course" kind of thing. If you have to ask how it's done, it's probably over your head.
You'll need to strip both frames completely, everything comes off, and then carefully cut the welds on both frames where the frame splice is welded. You'll need to use a frame table or a very flat, (truly flat, not just "that looks flat") concrete floor to make sure the frame aligns well.
When you slide the frame halves together, you'll need to carefully measure the wheelbase and that you get each frame rail the same length on both sides, as well as maintaining both zero twist in the vertical plane and keeping it square in the horizontal plane.
I have a frame table, and have assisted in the sectioning of an S10 frame before...it's NOT easy. But it can be done.
DaveP likes this.
Xnke is offline
post #4 of 6 Old 03-26-2017, 02:40 PM
User is: DaveP is offline
I researched the 2WD to 4X4 about 20 years ago. I had a 93 4-door that I had purchased new, had about 100K on it at the time, was in perfect condition and I wanted AWD. (Borg Warner full-time T-case like a Bravada). Xnke is correct: there is a LOT to know and do for this swap to be successful.
I discovered the "splice", and thought about sectioning the frames at the splice. But ended up purchasing a complete 4X4 frame with suspension, brakes, exhaust system (it's different too) from a theft-recovery ( no accident damage) 92 Blazer. Cost me $900 for the complete frame assembly, and by the time I was finished, about $4,000 for the complete swap. I drove that truck 290,000 miles total through 48 States and 3 countries. I used to say "I took a perfect car and made it better".
I was very pleased with my decision, and got 15 years out of it before I sold it. It is still in service. However, the truck was still "new" at the time, and good used and new parts were available in yards and from GM. No way would I consider doing it again today on a 25 year old vehicle, with only used-up 25 year old parts.
Do your research. There's a LOT to it.
DaveP is offline
post #5 of 6 Old 03-26-2017, 03:21 PM
dchawk81's Avatar
User is: dchawk81 is offline
Yeah you can get a 4WD S-10 for 4 grand anymore. They're old enough to be cheapish.
dchawk81 is offline
post #6 of 6 Old 03-26-2017, 05:18 PM
AWD V8's Avatar
User is: AWD V8 is offline
Yes you can convert a 2wd S10 to 4wd,.... with a straight axle.
It simply is not cost or time efficient to swap 4wd front end parts into a 2wd. Buy a 2wd truck and swap in your good 2wd engine if need be.
AWD V8 is offline
