2.8 v6 throttle body problems - S-10 Forum
post #1 of 4 Old 05-01-2010, 09:32 PM Thread Starter
HOOK'D 4 LYFE
User is: hookd4lyfe09 is offline
i need a fuel pressure regulator or a whole new throttle body pretty cheap if possible
HOOK'D~4~LYFE
post #2 of 4 Old 05-02-2010, 10:27 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Re: 2.8 v6 throttle body problems
and then............
You need a rephrase guy!
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #3 of 4 Old 05-03-2010, 10:54 PM Thread Starter
HOOK'D 4 LYFE
well never mind about the problems ive got a 4.3 throttle body ima put on it where do i start like accelerator cable wise and other stuff
HOOK'D~4~LYFE
post #4 of 4 Old 05-04-2010, 01:45 AM
i saw what you did there!
fast68chevy's Avatar
use 4.3L parts
cable you can buy new at auto zone etc or junkyard from a 4.3L truck with same injection as yours, either vin Z TBI,
or vin W CFI/SFI
you will need vin Z cable anyways
dirt common in the '88-92 years
the regulator you can modify
you remove the hat of it off the tb unit and drill out the brass in the end of it just until the screw in the middle of the regulator will screw thead, and you turn it so the roof of the regulator raises higher some
this increases volume of fuel
mine idles a little faster and stronger than other vin Z 4.3L engines out there after doing this mod
also after disconnecting tthe EGR valve in which was malfunctioning and sticking open and killing the engine in gear at stops when warm, after having been on the freeway cruising
