2.8 to a 4.3
Old 10-23-2009, 04:11 PM   #1
1994dime's Avatar
2.8 to a 4.3
i have a 4.3 out of a 1994 and i was curious if it would work in a 1st gen...
Old 10-23-2009, 04:48 PM   #2
Banned
Re: 2.8 to a 4.3
the w motor became available in 92
Old 10-23-2009, 04:50 PM   #3
1994dime's Avatar
Re: 2.8 to a 4.3
sooo... it wouldnt work?
Old 10-23-2009, 04:52 PM   #4
Whats this for?
mr spree's Avatar
Re: 2.8 to a 4.3
no it will. but it would be like doing a v8 swap.
Old 10-23-2009, 04:53 PM   #5
1994dime's Avatar
Re: 2.8 to a 4.3
ok. so could i use everything rite out of the 2nd gen truck or will i need more?
Old 10-23-2009, 05:01 PM   #6
Whats this for?
mr spree's Avatar
Re: 2.8 to a 4.3
You would need a transmission that bolts up to the 4.3
Idk what you would need to do about the wiring.
Also the mounts are different for a 4.3 too i believe
Old 10-23-2009, 05:11 PM   #7
1994dime's Avatar
Re: 2.8 to a 4.3
well i have a whole doner truck with a 4.3
Old 10-23-2009, 05:13 PM   #8
Whats this for?
mr spree's Avatar
Re: 2.8 to a 4.3
well thats good!
some of the plugs on the firewall will probably be different.
ever thought about just flipping cabs? pretty sure that would work
Old 10-23-2009, 06:11 PM   #9
1994dime's Avatar
Re: 2.8 to a 4.3
ok thankyou
Old 10-23-2009, 07:51 PM   #10
1994dime's Avatar
Re: 2.8 to a 4.3
no i cant swap cabs the doner is wrecked i got t-boned pretty hard the cab, bed, and frame are shot the motor and trans are good along with the mounts, i just need to get an anwser about the computer...
Old 10-23-2009, 08:39 PM   #11
Whats this for?
mr spree's Avatar
Re: 2.8 to a 4.3
i thought you were putting the motor into a 1st gen? so put the first gen body and what not over the top of the 1994 frame and motor
Old 10-23-2009, 10:23 PM   #12
1994dime's Avatar
Re: 2.8 to a 4.3
no u giot them mixed up.... the doner truck is a 94' s10(my avatar picture) which is wrecked. my buddy has a 88' s10 durango with a 2.8 in it. the body of the 1st gen is in excellent shape just dosent have that much balls. so i wanted to take the 4.3+tranny outta my second gen and put it into the 1st gen. and another thing i just thought of is my 94' is 2wd and my buddys 1st gen is 4x4, so will the 4.3 trans work with the transfercase in the 2.8?
Old 10-23-2009, 11:51 PM   #13
Done with the whinners
Re: 2.8 to a 4.3
Get the JTR 2.8 to 4.3 swap mounts that go on the block. They will bolt right up to the 2.8 rubber mounts.
You can use your second gens motor, harness and computer. You can also use the second gens fuel tank in the first gen so you'll have the pump and all.
You would have to change the tranny's output shaft for the transfer case. I don't know if they are interchangeable from an early 700R4 to a 4L60E even though the 700R4 and 4L60 are the same. The E adds electronics that may change some of the internals
Old 10-24-2009, 09:32 AM   #14
1994dime's Avatar
Re: 2.8 to a 4.3
ok thankyou for the advice it helped a lot. thanks
