1991 4.3 ltr distributor firing order - S-10 Forum
Old 05-31-2008, 10:02 AM   #1
Need help. Trying to replace distributor cap and rotor wires got mixed up. Have obtained firing order but am not sure where exactly is the number one position on cap. Inside cap there is a #1. Is this the number one wire to connect to #1 plug. Also need a diagram identifying firing order on block.. Marks on manifold are not legible.
Thanks.
Old 05-31-2008, 10:10 AM   #2
I'm slap happy, bitches!
Re: 1991 4.3 ltr distributor firing order
okay, on chevy motors, the odd side is ALWAYS the drivers side
so
6 5
4 3
2 1
ft of truck
never go by cap marks, you never know if anyone cobbed the distributor in in the wrong place. roll the motor over to top dead on the 2nd mark on the balancer with the distributor cap off and the rotor on.
use that for number one. line the cap up and firing order is 165432. clockwise.
(yeah i know he can be off 180 this way to all the non noobs, but at least this way he has a 50% shot)
Old 05-31-2008, 10:20 AM   #3
It's "Neanderthal"
SH-60B's Avatar
Take the spark plug out of #1 and feel for pressure as you turn the crank. When you do feel it continue to the mark on the balancer. That is TDC for #1. Run the wires according to the firing order like deeze said and you're good to go.
Old 05-31-2008, 12:10 PM   #4
Number 1 on the dist should always be pointing towards
num 1 cylinder.
PS welcome to the site..
Old 05-31-2008, 12:26 PM   #5
Mr. Clean
EYEROCK89's Avatar
Isn't the firing order stamped on the intake manifold?
Old 05-31-2008, 04:45 PM   #6
And an easy way to figure out what the number one side is look and see which head is furthest forward.
Old 05-31-2008, 05:21 PM   #7
not always true.
Old 06-01-2008, 01:39 AM   #8
Quote: Originally Posted by Deeze49686
not always true.
Really! When is it not true?
Old 06-01-2008, 11:33 AM   #9
AWOLMIND's Avatar
Sounds like you did not pull the distributer out, so don't worry about finding TDC. Just put the cap on and go from there. Now follow BG's good picture diagram and try not to let the others confuse you with to much info.[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
