1986 chevy s10 2.5l no gas coming from injector. - S-10 Forum
post #1 of 25 Old 09-02-2009, 03:53 PM Thread Starter
User is: gunslinger27 is offline
I have no gas coming from my injector it a 1986 chevy s10 2.5l I have replaced the fuel pump,oil pressure switch & I checked and oil would come out the hole when turning over,fuel pump relay,cleaned tank and lines, I baught a pressure regulater kit from orilleys and built it,fuel injector,fuel filter, throttle position sensor, mass air sensor, I have traced all the wires back to the computer and they all have good continuity and all look good,i have checked the fuses and they all look good, I have also replaced the computer but it didnt work after that so I took the computer back, I am throwing no codes and if I pour gas down the throttle body it starts right up but doest stay started. I have spark . I am getting 11.7 volts through the red wire and the blue puts some out when turning it over. when I put 12 volts to one side of the injector and ground the other out it spits fuel... I had a pressure tester to it and it would go to 10 or so pressure after I turned it over for a few seconds.. none of this has worked and It dosnt have a single fuel inj fuse or fuel inf relay..
post #2 of 25 Old 09-02-2009, 04:16 PM
User is: MadMikeZ28 is offline
Re: 1986 chevy s10 2.5l no gas coming from injector.
I just repsonded in a thread from a guy having about the same problem.
It does have a fuel injector fuse, ECMI.
Sounds like what you are not getting is the ground signal from the ECM to the injector (blue wire). Ultimatly the ignition module send a refernce to the ECM. Your module may be bad. Take it out and to an auto parts store to have it tested.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #3 of 25 Old 09-02-2009, 08:25 PM Thread Starter
thanks I will try that tommarow morning. So if the ignition modual is bad fuel will not come out? I ran a check on my coil the day before it broke down and it passed all the test exept for the one you have to ground on of the terminals to the bracket.
post #4 of 25 Old 09-02-2009, 08:46 PM Thread Starter
it also had white stuff on the terminal
post #5 of 25 Old 09-02-2009, 08:49 PM
DiElectric grease (if I spelled that crrect )
Somehow the truck has to let the fuel injector know its running so a signal will come from the ignition module.
post #6 of 25 Old 09-02-2009, 09:03 PM Thread Starter
I am just asking......could the pick up coil in the in the dizzy not let it spit fuel?
post #7 of 25 Old 09-02-2009, 10:41 PM
Ahh ok, I did not see that question. The stator that works with the reluctor ring (the things with the fingers) do connect to the module and work with it to to make the coil spark. Just in the same way as points did.
post #8 of 25 Old 09-02-2009, 10:57 PM
OOps! My brother called me and I reacted by clicking post before explaing how to test the pick up coil.
If you have a multi meter connect a lead to the base of the dizzy. and the other test lead to one of the wires to see if its grounding. then hook your test lead to both of the leads on the pick up and there should be around 500-1500 ohms resistance.
post #9 of 25 Old 09-03-2009, 03:33 PM Thread Starter
I had my old ignition moduale tested and it failed the dwell light did not light up on tester. so I replaced it and It still wont start. Is there anything else it could be? I rebuilt my fuel pressure reg with a diafram kit from orilleys and the chilton manual said not to remove the for screws that atached the regualter to the fuel meter cover but I had to to rebuild it and the diaphram was a little diffrent. I tested the fuel pressure ofter I did the rebuild and the pressure would go up to 10psi after 2 seconds of turning the motor over but bleed all the way off as soon as I stoped turning it over. I dont know if its sopposed to do that. I could not find a used or new fuel meter cover with a fuel pressure regulater for that truck anywere.
post #10 of 25 Old 09-03-2009, 07:17 PM
Have you made sure you have a ground pulse to the injector? You have a test light? Instead of connecting to the negative side of the battery like when you test for power hook it to the positive side. Then probe the blue wire and have some one crank it. It should light up or flash really. Don't touch any hot leads. Hot + hot = sparks and burns and fire!
post #11 of 25 Old 09-03-2009, 08:33 PM Thread Starter
with key on and fuel injector harness unhooked red wire makes test light come on. blue does not even blink when turning the ignition over but with harness hooked to the injector red stays on and blue stays on but does not blink or pulse.
post #12 of 25 Old 09-03-2009, 08:34 PM Thread Starter
test light from positive to blue side injection no pulse, no light, no anything
post #13 of 25 Old 09-03-2009, 11:16 PM
And that was tested while cranking I hope?
You can go to the ECM and test the injector's blue wire the same way. I think it is cavity D16 (light blue). If you have a pulse there is a break some where. Maybe in the bulkhead connector or the engine harness or make sure no one tapped into it for some reason like for an alarm.
If there is no pulse then the ECM is not getting a signal that the engine is cranking over. You tested and replaced the ignition module, did you test the pick up coil?
post #14 of 25 Old 09-08-2009, 03:21 PM Thread Starter
I dont know how to or even see wires that go to a pickup coil on my truck there are wires for both sides of my ignition mod and three that go to that black thing on top I forgot what thats called.....when I hook up a test light to the blue wire I have power coming from the blue wire even when its not hooked up to the injector and it dosnt pulse ......the test light says that the blue wire has power coming from it when the harrnes it un hooked and grounded to a ground.,,,,,,,,weird, what would cause that and is it sopposed to have power? When i turn it over it does not pulse even when hooked up to the battery. red has power also.
post #15 of 25 Old 09-08-2009, 03:38 PM
The pick up coil (also may be called stator) is inside the dizzy. It has two wires that plug into one side of the module (one yellow and one green I think).
Does the blue wire have as much power as the red? The test light is as bright on both wires? Unplug the computer wires to see if it still has power. Maybe the wires got melted together somewhere in the harness.
post #16 of 25 Old 09-08-2009, 04:08 PM
Layin Low Customz
User is: lkrayzie is offline
Send a message via AIM to lkrayzie
mine had the same exact problem, it ended up being the sensor under the dist. cap, replaced that and it started and ran fine
lkrayzie is offline
post #17 of 25 Old 09-08-2009, 06:15 PM
Right, the ignition module. I stated that in post #2 but the OP later stated he had it tested and it failed so he replaced it. So some where between the injector to the computer to the module there must be a problem.
post #18 of 25 Old 08-14-2013, 05:04 PM
User is: dimentd is offline
where did this guy leave off? i am having the same issue and have also done proper testing and coming up with a loss!
HELP LOL.....
thanks
Perfect Poise
dimentd is offline
post #19 of 25 Old 01-10-2015, 09:48 PM
User is: barrettjds123 is offline
My fuel pump relay just turns on and off repeatedly causing a buzzing noise. Any pointers? The oil pump broke and blew the engine up, when I rebuilt it I used the old oil pressure switch. Should I buy a new one? I heard something about they shut down if oil pressure is lost. Any help with the buzzing would be appreciated! Also, there is continuity in the tan/white wire coming from the relay when ohmed. Oil light and battery light are on too.
post #20 of 25 Old 01-11-2015, 07:02 AM
User is: max1million is offline
hall effect switch if it has it is separate from icm (ignition control module)
if you replace injector with light and it don't pulse may be fuse ecm1, hall effect, wiring connections
http://www.justanswer.com/chevy/1bko...ttle-body.html
On another note, the oil pressure switch will keep fuel pump going even if the pump relay dies in mid trip. Ran for few years without oil pressure switch. Relay buzzing may be low voltage (low battery, bad wiring/connection) causing the relay to go on off.
It has a single cab, cause one cab is enough.
post #21 of 25 Old 01-11-2015, 10:25 PM
Buzzing turned out to be prime connector. Unplugged it and it works fine now, but still no spray from injector. Both blue and red wire to injector have power with the key on. Ohmed the injector at 1.5. No check engine light, also no check engine light with a and b terminals grounded on aldl. I can hear the fuel pump come on for a few seconds and turn off but no spray still..
post #22 of 25 Old 01-13-2015, 07:05 AM
Apparently the fuse is ok. I don't know what ohms the injector is seems about right (14volts/1.5ohms=~9amps). If you short/jumper the blue wire on injector to ground (ground it) while the ignition is on and fuel pump running (such as when prime/test) injector should spray. If you just replace injector with light it should pulse when cranking. The link has a chart to follow for diagnostics, with a simple schematic.
a and b, 1 of the terminal is ground, you just jumper/short the 2 together.
post #23 of 25 Old 01-19-2015, 08:43 PM
OK now there's a code 24, also my truck was idling smooth as ever and all the sudden died and wouldn't start back up. No spray from injector, but it fired with starting fluid...
post #24 of 25 Old 11-04-2015, 03:41 PM
User is: Jakdariper is offline
1988 2.5 s10 no injector pulse after start up (cranks and run fine for 2sec then it's dead) new dizzy new ECM all wires traced and tested. Blue wire has pulse until start up (bypass mode) tan black ref wire to ECM has 5v purple white has pulse to ECM what's next
post #25 of 25 Old 04-15-2016, 11:06 PM
User is: Irondukehero is offline
Just curious if anyone found out their issues? The thread kinda died out. If you found out what you problem is please post what it was! Thanks guys! Still trying to figure out my truck also.
