1.9 Anybody?
Old 11-05-2009, 08:45 PM   #1
"Future" '85 Pussy Wagon
barkboy6's Avatar
1.9 Anybody?
I have the 1.9 engine in my truck and after a little reading I found out it only has 84 hp?! Anyway it seems to pull alright from what I can tell (I haven't driven it much since I bought it cause it needs a new exhaust system, plugs/wires, tires, paint and insurance!) Anybody have, or had, the 1.9? Any simple mods I can do to it to give it a little more GO?
Old 11-05-2009, 09:29 PM   #2
4-bangin's Avatar
Re: 1.9 Anybody?
put a v8 in?
Old 11-05-2009, 10:21 PM   #3
barkboy6's Avatar
Re: 1.9 Anybody?
Quote: Originally Posted by 4-bangin
put a v8 in?
I knew someone would say that! But I already have two v8 vehicles. I like the 4 cylinder and I could make do with it as it is I guess, just would like to put maybe 10 or more hp to it without doing major engine work. To get to the 100 hp mark would be even better. I was thinking more along the lines of carbs, intakes, air filters, ignition components, new exhaust manifold or header??
Old 11-05-2009, 10:25 PM   #4
luckyducky199's Avatar
Re: 1.9 Anybody?
I don't think there is much after market products for the 1.9
Do a general tune up. change all the fluids and filters. maybe get some fuel additives to help clean out the junk.
Ohhh and really if it came from the factory with 84hp then i probably really only has like 43hp now as cars age they lose power really fast.
you could pep it up with low shots of nitrous.
the answer to every s series question is put a v8 in it.
broken windshield?
Put a v8 in it.
but you could always try a different route and build a custom turbo kit build the engine. but as far as i know the 1.9 was a Isuzu motor. not many things to do with the lowest of the low motors.
you could look at v6 swaps.
Old 11-05-2009, 10:33 PM   #5
Re: 1.9 Anybody?
Weight Reduction.
you could strip all unneeded amenities from your truck.
like parts of the interior or shave metal off from places.
Old 11-06-2009, 12:05 AM   #6
barkboy6's Avatar
Re: 1.9 Anybody?
Yep I think a v6 swap will be something I'll do in the future...either swap the engine out or swap the truck. But for now I'm keepin this one
Old 11-06-2009, 12:43 AM   #7
orangesonoma supporter
JChapoton's Avatar
Location: Warren, MI -- Home of GM's Tech Center--soon to be the new GM Headquarters
Re: 1.9 Anybody?
http://www.s10forum.com/forum/f104/m...s-that-420370/
and no they do not make any aftermarket parts for the 1.9, 2.0, or 2.2 diesel.
Old 11-07-2009, 02:38 AM   #8
barkboy6's Avatar
Re: 1.9 Anybody?
Not even any tricks? Sounds like this motor was just to pass the time.
Old 11-07-2009, 10:11 AM   #9
v8s10dave's Avatar
Re: 1.9 Anybody?
I believe Weber makes a carb for it.
Old 11-07-2009, 12:12 PM   #10
4-bangin's Avatar
Re: 1.9 Anybody?
If you have 2 cars with v8s, whateverthey are put your money into go fast parts for them and just keep the s10 the get good mpg's with
Old 11-07-2009, 12:36 PM   #11
rotormatic's Avatar
Re: 1.9 Anybody?
I've had a S10 with a 1.9 since new (1985). Not a lot of power, but has run great and never let me down. Only thing I have had to do to the truck to keep it running has been to put brakes on, replace the water pump, alternator, and rebuild the carburetor.
As said above, the only aftermarket item avalible is the webber carb conversion.
82 - 85
S-10 P/U Blazer 4 CYL 1.9 , 2.0 W/ HITACHI CARB K696
32-36_DGEV_Electric_Choke 319.95
http://www.carburetion.com/weber/Dat...696&Model=S-10 P/U Blazer
Old 11-07-2009, 05:30 PM   #12
Re: 1.9 Anybody?
I wish i could find a 1.9L, Been looking for 4 years and still not one seen
Old 11-09-2009, 10:30 AM   #13
barkboy6's Avatar
Re: 1.9 Anybody?
Yeah that's what I plan on doing. It does run good, I drove it home about 60 miles after I bought it and it seemed to pull pretty good up hills and mountains, so after a tune-up and a new exhaust system it should run even better. Catalytic converter or no cat?
Page generated in 0.57007 seconds with 31 queries
[Output: 81.66 Kb. compressed to 76.00 Kb. by saving 5.66 Kb. (6.93%)]
