SAS inprogress
zhillz's SAS thread
After yesterday i want my truck done NOW! So **** it, im breakin out the card and going to town.
*IM ORDERING STUFF IN THE NEXT FEW DAYS SO CAN YALL MAKE SURE IM ORDERING THE RIGHT STUFF LOL* INFO TRUCK: 98 automatic extended cab s10 with vortec 4.3 4x4 ![]() AXLES: High Pinion Dana 44 and 9" from late 70s Bronco ![]() The goal: 10" of lift all spring in front and 35-37s The setup: I perfer to run leafs and the axles i got are set up for them so im good to go. --------more info to come---------- Gears: $385 Part Number: KITFD9D44485R
Front- $750 Part Number: OXLOXD44C392H
Ok i learned the ratchetin lockers like detriots are locked when you accelerate..Well since i have an automatic wont it always be locked? Springs: I dont want a harsh ride so im stayin away from fullsize truck springs how about springs from a 79-85 yota? will soa and 5" lift springs get me 10" im not a fan of huge shackles. Steering: this is where i dont feel comfortable and need input! i have no steering parts should i get this kit for a 79 bronco its only $60 Part Number: EXPFD400
When lifted, the drag link attachment point needs to be moved down to reduce link angle, creating the need for a drop pitman arm.; Pitman Arm; 4 in. Drop; Steering correction Brakes: Do i need anything special to get my brakes to work on these axles? The tierod end was cut off my knuckle so i will need 1 new one for sure. When i was searching i was findin people rubbing on the springs leafs and soa. Should i get the highsteer knuckles or flatop w/e they are called. For the things i listed im ordering from http://www.4wheelparts.com/ because they are local and will save a lot in shipping everything else ill need to find (or you ) the best price. |
I Rather Be Wheelin'
Re: zhillz's SAS thread
IN A HICKTOWN
do full high steer, or cross over. you could prob buy a tie rod for a D44 but you may need to make your drag link (i dunno if it would be the same length as a bronco or not.
but worry about drive line / steering last. and im not sure about your brake lines. def need to be long ones. with that much lift. and i would perfer to run at least a 6" shackle. i think mine are too short. |
cant wait to see ANOTHER SAS thread, man these keep poppin up! i think we'll need our own section.
3 Leaf Fab
my front shackles are at 5" and they seem to be good. if you are running leafs SOA you are going to have trouble running a ford style steering linkage. they run an inverted T style, where the drag link runs into the tie rod. this is because they are coil and have nothing in front of the axle to get in the way. i would look into getting a flat top knuckle and running it that way with a high steer arm. if you plan on doing any wheeling, make or get made something better than oem linkage. the stock stuff is worthless off road.
also, auto lockers like the detroit are locked in when there is throttle input. when you are just cruising down the freeway there is no real input, just cruising. acceleration is defined by the change in velocity, so basically when you are getting up to speed or braking. this also only applies when the hubs are locked in. i wouldnt say you needed the ox locker, but i will say you will probably never reget it, i wish i had a selectable up front. one thing i forgot to ask, you say the axles are from a late 70's bronco, does that mean 78 or 79? i assume it does because those are the only broncos that would have come with a Hp44 front. in that case, good luck running leafs up front. you will have to run u-bolts around the radius arm wedges, they cannot be cut off because they are hollow and there is no axle tube under them. |
________________
*subscribes
SAS inprogress
3 Leaf Fab
IN A HICKTOWN
when you get done with yours i am taking a road trip and you can do mine
Very nice man, I dont live to far from ya, let me know if ya need a hand. I have a HP Dana 30 and a ford 8.8 with 4.10's I will be putting in mine soon
pssh. so many floridians..
i just put my name in american pavers for a welder / fabricator position. starting 16-20$ / hr. |
SAS inprogress
Hey im trying to check out and i need to know real quick! What the hell is reverse cut when talkin about the axles and how do i know?
3 Leaf Fab
it basically means high pinion or low pinion. low pinion is regular cut, high pinion is "reverse cut", though that is not a fully correct term, but it gets the job done and people know what you mean.
SAS inprogress
I didnt know i couldnt edit my post so i have a lot of BS i would like removed from the first post please.Im not going with the ox for the front im leaving it open.
I ordered most of the stuff tonight!!! I got 5" leaf springs for a first gen toyota all around with perches shackles and bushings- 800 ordered the 4.88s and extended break lines- 500 Flatop knuckles -500 I guess im waiting till im done to measure stuff to find out what shocks i need. |
3 Leaf Fab
SAS inprogress
3 Leaf Fab
SAS inprogress
3 Leaf Fab
you went full high steer? did you get new knuckles?
SAS inprogress
3 Leaf Fab
how much do you know about the parts you bought? |
SAS inprogress
1 x Ford Left Heavy Duty Flat Top Dana 44 Steering Knuckle |
#24 |
3 Leaf Fab
ok, i just want to make sure you werent getting screwed.
#25 |
SAS inprogress
writing down a list so i dont ferget stuff and see if anything pops up.Alrighty i have my request in for days off of work so hopefully then end of the september it will be done!
Parts list i have: Flattop knuckles -Reid racing 4.88 with install kit - 4wheelparts of Tampa 5" toyota lift springs -Marlin Crawler hanger kit f&r with crossmember -Marlin Crawler extended brake lines - Procomp (4wheelparts) Highsteer arms/tubing 3/4 GM TRE/4"drop pitman arm - 4wdfactory (ordered today) ubolts and hardware - 4wdfactory NEED: the brake lines come in pairs of 2 so i need another set hubs break pads TIRES! ?astro box? idk yet. lots of paint. Any tips here? I want to do my whole frame and axles i was thinkin rustoleum. The only write up i found used tractor paint and it takes a couple of days to dry so f that. my 4wd isnt engaging...so ill need to tackle that asap. Perfect timing with the write up Donahue! |
#26 |
Totally Confused
Location: Abbotsford, BC, Canada User is: OffLine ![]() |
#27 |
3 Leaf Fab
also, what TRE's did you get? (looking for part numbers) |
#28 |
1 es2234L 1 es2027L 2 es2234R ![]() |
#29 |
3 Leaf Fab
ah.
i run (4) 2234R's |
#30 |
...and the pitman arm is reamed to fit the 2027L.
#31 |
3 Leaf Fab
