What is the cheapest Suspension lift out there???
Go Back   S-10 Forum > Suspension Tech > Liftin' It
Old 07-03-2008, 01:55 PM   #1
84liftedS10's Avatar
84liftedS10 is on a distinguished road
what is the best Suspension lift for the cheapest price??
thanks
Old 07-03-2008, 02:09 PM   #2
Tim99Zr2's Avatar
Tim99Zr2 is on a distinguished road
Re: What is the cheapest Suspension lift out there???
you cant have those two qualities together.
dont be cheap on suspension
Old 07-03-2008, 02:10 PM   #3
well, then whats the best deal out there??
and Is there any out there inder $500???
Old 07-03-2008, 04:58 PM   #4
goin broke but n style
S15vortecpwr's Avatar
S15vortecpwr is on a distinguished road
i would not want one under 500
Old 07-03-2008, 05:00 PM   #5
Tim99Zr2's Avatar
the "cheapest" way would be a BL, TBar crank, and Shackles. that could be had for about 150$ for a first gen.
Old 07-03-2008, 05:20 PM   #6
89-S-Dime's Avatar
89-S-Dime is on a distinguished road
2 or 4 wheel drive?
Old 07-03-2008, 06:13 PM   #7
4x4
And T bar crank hurts the truck too much!!
Any places where you could get one used??
you guys like these??
http://www.hannemannfiberglass.com/P...es/HF5013.html
Old 07-03-2008, 06:17 PM   #8
Tim99Zr2's Avatar
i actually thought about pre runner fenders too.
any lift is going to affect your cv angles. (except SAS) and i dont think you want to do that.
Old 07-03-2008, 06:30 PM   #9
yeah, no SAS for me but what other mods should i do??
Old 07-03-2008, 08:53 PM   #10
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
Body lift and trimming is your friend. Body lift is around 200, and trimming is free! The prerunner fenders/bedsides are cool - but again; trimming is free!
Old 07-03-2008, 09:52 PM   #11
Tim99Zr2's Avatar
my bad, i thought first gen BLs were only about 100$
maybe toss a locker in the rear. i dunno what else to do
Old 07-03-2008, 10:34 PM   #12
whats a good locker for a low price??
Old 07-03-2008, 10:54 PM   #13
ChrisInVT's Avatar
You can get a posi from an f-body for around $150, it's the getting it installed part that costs a bunch.
Could always go with a mini spool
Old 07-03-2008, 10:58 PM   #14
whats a mini spool?
Old 07-03-2008, 11:28 PM   #15
ChrisInVT's Avatar
Basically, it's a fully locked rear. It's easy to install and you don't even have to pull your carrier to do it. Baggey22 did a writeup on it a while back. IIRC they're fairly cheap too.
I might end up welding my diff gears solid in my truck because it looks like I'll be replacing my rear soon anyways
Old 07-04-2008, 01:11 AM   #16
Tim99Zr2's Avatar
lincoln lockers FTW (welded spider gears)
Old 07-04-2008, 11:45 AM   #17
can you put a mini spool in the front???
Old 07-04-2008, 12:35 PM   #18
I lead the blind
Speedy2222's Avatar
Speedy2222 can only hope to improve
dont... plain and simple... maybe a selectable locker
Old 07-04-2008, 03:52 PM   #19
boar huntin' fool
4x4zr2GA's Avatar
4x4zr2GA is an unknown quantity at this point
for a locker... just go and buy a mini-spool for $100. at the parts store... O'riellys can get them, thats the absolute cheapest you can buy, but it keeps the rear tires locked at all times. if you can go to a junkyard and find a factory g80 limited slip out of a camaro or another s10 or a full size depending on what size rear end you have for cheap then do that. as far as lift... the cheapest way is honestly to do a SAS. find some jeep axles (dana 30 and 35) though not the greatest axles to take a beating, they will start the way and will hold up just fine for normal off road stuff... if you want to stick with factory IFS setup, cheapest way is a body lift, crank the torsion bars, get re-indexed torsion keys off of ebay for $80 and get shackles for the back... that will give you roughly 4 -5" of lift, cut the fenders and throw some 33's on there.
Old 07-04-2008, 04:59 PM   #20
how much do you think a g80 limited slip would cost??
and do i just ask if they have one or do i have to look?
Old 07-04-2008, 06:16 PM   #21
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
g80's bring the suck in real off road situations. get a real locker, a lock right (or similar), mini spool, or just weld the spiders like i did. lockers in the front are very hard on the power steering systems, a spool would be even worse. tire size can play a lot into the equation, but with my 38's and my hubs locked in, its basically like i have no power steering because of the detroit locker i have in the front.
Old 07-04-2008, 07:59 PM   #22
ok, then what spool do i need for a 84 s10??
Easy to put in?? never done anything like this, could i do it??
Old 07-04-2008, 08:04 PM   #23
3 Leaf Fab
Donahue's Avatar
the mini spools and lunch box lockers are the same to install. its fairly easy with simple hand tools and no R&P setup. you have a 26 spline 7.5" 10 bolt axle.
Old 07-04-2008, 08:13 PM   #24
I am afraid it going to hert my truck though?
How bad is it if its just my every day driver to school and easy off roading. like mud but no rocks??
Old 07-04-2008, 08:29 PM   #25
wrekd's Avatar
wrekd is on a distinguished road
It wont hurt your truck but it will wear out your tires a little faster.
But once youve experienced a locked rearend offroad, youll wonder how you ever got along without it.
Old 07-04-2008, 08:45 PM   #26
3 Leaf Fab
Donahue's Avatar
i broke a shaft with 32's and a welded diff. i was also bouncing it in rocks at the time. with light to moderate wheeling, and 33's or less a spool will mainly just eat tires faster. it will have its effect on pavement driving, parking lots might become your bane. for a street truck, i would probably spend the extra money and get a lockright, though anything will be better than nothing.
Old 07-04-2008, 08:49 PM   #27
yeah, i am only running 31s
Old 07-05-2008, 08:30 PM   #28
where can i can i get instructions? with pix??
Old 07-09-2008, 11:08 AM   #29
3 Leaf Fab
Donahue's Avatar
likely in the box with the spool.
Old 07-10-2008, 12:11 PM   #30
JohnnyG's Avatar
JohnnyG is on a distinguished road
This is in regards to a locker but im pretty sure a spool is about the same. But you can actually download the instructions at the lockright website, thats what I did before I put my locker in just to get an idea ahead of time. You just have to fill some info out like name and stuff and it will let you view and print the instructions off. I will add this, the instructions may seem a little confusing or like its going to be very hard to do but once you have the parts in your hand, seeing all the parts on the truck, and following the instructions its almost dummy proof.
Heres the website
http://www.richmondgear.com/powertrax/lockright.html
Old 07-10-2008, 12:56 PM   #31
89-S-Dime's Avatar
4x4
Not if done properly, if you don't more then 1.5" of lift and your T-bars are in good condition you will be fine.
Page generated in 0.24932 seconds with 11 queries
