UN-lifting my blazer..
Old 08-11-2008, 01:46 AM   #1
therron258 is on a distinguished road
I have a 98 s10 blazer that has a Tmaster lift on it. I want to have the lift removed and just run on my body lift and smaller tires.
would a shop do this? how hard would it be to get the vehicle back to stock suspension specs?
I want the lift taken off because all i do anymore is tow my boat with it and the 33's sort of bog it down when going up hills and pulling it out of the water after it is put on the trailer.
If someone wanted to, i would even let them use my driveway and swap their parts with mine and have a free trailmaster lift...
Old 08-11-2008, 01:50 AM   #2
boar huntin' fool
4x4zr2GA's Avatar
4x4zr2GA is an unknown quantity at this point
Re: UN-lifting my blazer..
thats the only way you can do it... becuase with the lift... parts had to be cut off... so the only way your gonna be able to do this is if someone wants the lift and knows how to weld the parts they cut off of their truck and onto yours... good deal for someone tho
Old 08-11-2008, 01:51 AM   #3
boar huntin' fool
4x4zr2GA's Avatar
why not take the body lift off and run 31's?
Old 08-11-2008, 02:00 AM   #4
would a shop do that? im leaving for college in a week, i have the money, but not the time.
wouldnt i need stock body bolts?
Old 08-11-2008, 02:07 AM   #5
wrekd's Avatar
wrekd is on a distinguished road
Yeah you'll need stock body bolts. I just did the same thing to mine about 2 months ago.
Old 08-11-2008, 08:20 AM   #6
was it hard to do? does it run better now?
Old 08-11-2008, 09:02 AM   #7
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
when you did the lift did you change out the gears? mine has all sorts of tourqe low end with 4.56's
and if parts were cut off its not going to be a simple swap out
Old 08-11-2008, 09:14 AM   #8
snoma20 is on a distinguished road
Where are you located i would def trade?
Old 08-11-2008, 06:49 PM   #9
in madisonville KY.
id trade my 33's for 31's if someone just wanted to come take my body lift off.
no i didnt do gears, just stock 373's
Old 08-11-2008, 06:56 PM   #10
well thats your problem.. mine was shitty with 373...once i did the 4.56 the life came back and then some
Old 08-11-2008, 08:59 PM   #11
Tankerblade is on a distinguished road
Just get some new gearing for the rear and you'll have a fine rig and im sure it'll tow a bit better with the new gearing.
Old 08-11-2008, 09:06 PM   #12
i would do both.. you dont want the transfer case to bind up
Old 08-11-2008, 09:36 PM   #13
wont my gas mileage go down the shitter?
Old 08-11-2008, 09:45 PM   #14
what do you get now? and it depends on how you drive.. my truck gets WOT a few times a day and all i do is highway...about 40-60-100 miles...some time even more
Old 08-11-2008, 09:54 PM   #15
WOT?
i get 13-15 now
how much would gears cost?
Old 08-11-2008, 09:56 PM   #16
wide open throttle...wot
i get 12-14 and liek i said i beat on it.. gears will run you around 300-500
and you can hold off and do just the rear but do not put it in 4wd....your transfer case will hate you
but i will tell you out of all the things i did to my blazer the gears made the best difference...and you dont need 4.56 you can go 4.11
Old 08-11-2008, 11:15 PM   #17
goin broke but n style
S15vortecpwr's Avatar
S15vortecpwr is on a distinguished road
i gained mpg when i went from 3.08 to 3.73 on my truck. i have them just in the rear since i never offroad. i just unhooked the cable from the vac ball under my battery. I only sees highway. I average about 16 now on the highway. I have 31 AT on it. Since you pull a boat i would go with 4.56
You will not be able to remove the lift due to the upper control mounts was cut all but off for the brackets to bolt up. I installed mine and it states multiple in the instructions that this is a non-reversible kit. Any attempt to remove will weaken the front suspension mounts and can cause serious injury or death.
Old 08-12-2008, 01:23 AM   #18
my cv's are shot, so no 4x4 would be used anyway.
Old 08-12-2008, 01:29 AM   #19
Slightly Over Built
DieselS10's Avatar
DieselS10 is on a distinguished road
Just change the gears, it's your best solution and like they said, it will probably help your mileage.
Old 08-12-2008, 03:32 PM   #20
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
IMO don't bother changing the gears. You can put 3-500 into gearing and you'll still have a shitty 10-bolt. You can snag an 8.8 from a Ford Explorer with a limited slip and 4.10's for around $200. That's the route I'm going because I don't feel like paying to have someone install my posi carrier.
Old 08-12-2008, 05:51 PM   #21
i would rather just sell the thing for 3000!!!!!!!
Old 08-14-2008, 01:04 AM   #22
well ive come up witht he following plan:
Get BL taken off
Get 31s instead of my 33's and sell the 33s
Possibly get gears if still needed.
I found some 31 11.00 15 super swamper LTB's for 130 apiece + 100 shipping, are these good tires? is that a good deal?
Old 08-14-2008, 11:19 AM   #23
chris15706's Avatar
chris15706 is on a distinguished road
Those are some aggressive tires.
btw check out the s-10 on the interco homepage.
http://www.intercotire.com/site.php
Old 08-15-2008, 02:16 AM   #24
Registered Staff
What?'s Avatar
What? will become famous soon enough
depends how many miles on the truck, you could sell it for 3k and get another from auction/towing company/police auctions, tweak tbar and shackle, 31s and call it a day
or no tweak tbar and bl along with 31s
otherwise, sell the bl and 33s, get the 31s
Old 08-16-2008, 12:08 PM   #25
19954x4's Avatar
19954x4 is on a distinguished road
i live in somerset ky if ur still wanting to trade for a lift
Page generated in 0.19743 seconds with 12 queries
