trimming it up
okay I got a couple ?'s
well I got my lift on. I got 32 11.50's with a 2" body lift , t-bar tweak and shackles. I got a 2" shackle and I only could get 1.5 out of my bars without it being to much so If someone wants to trade me for 1.5 mabye we can work something out. If not im gonna drill them again. Do I need to go an 1" lower on the shackle to get a .5" right? also I was wondering for thos who have close to the same setup how bad did you half to trim cause I pretty much got to cut the corner of my fender's off. I thought about selling my 32s and getting 31s but even then it still looks like I would half to take some of my fender in. pics welcome |
Slightly Over Built
Re: trimming it up
Your right on the shackles. Do you have wheels on it that cause them to stick out more than stock?
Re: trimming it up
4"bs soft 8's |
Re: trimming it up
I think that is like 2wd back spacing. My s10 had an offset similiar to that and 235's I think and rubbed like a b!tch when turning sharp. Did you just get the wheels too or did you already have them on there?
Registered Asshole
Location: Moscow, PA / Mansfield, PA User is: OffLine ![]() |
Re: trimming it up
all i can say is you will rub... best thing to do is sit down with a sawzall one day and turn the wheels and trim as you go. it's hard to say an exact amount to trim off... every rig is different. i basically trimmed as i went for my 31s. heres the best pic if have that shows the trimming...
![]() hard to see... but you can tell i trimmed the very bottom of my outer fender at an angle. the inner fender i just hammered with a bfh until it didnt rub anymore on flat ground. even though you trim... you should still expect it to rub some when wheeling or on really uneven ground. |
Re: trimming it up
I trimmed a little on the wheel wells a few months ago and I dont hit when I turn.
I hit when wheeling . and the wheels I have hade for awhile I wanted to get 4.5 bs but summit didnt have them at the time. also my tires stick out pretty far ill half to get some pics but I dont like fender flares all that much. I think it looks like I built it with out knowing anything. will zr2 fender flares fit up? . I think they are hard to find |
Re: trimming it up
[quote=crazy91s10;5497633]all i can say is you will rub... best thing to do is sit down with a sawzall one day and turn the wheels and trim as you go. it's hard to say an exact amount to trim off... every rig is different. i basically trimmed as i went for my 31s. heres the best pic if have that shows the trimming...
![]() Im gonna half to do the same thing . I thought about driving one tire up on a ramp till it hits then marking how I want to cut then just repeat till I get it how I like. |
Registered Asshole
Re: trimming it up
zr2 flares wont fit because the fenders have a built in lip that holds the flares on. you'd have to get zr2 front fenders and a zr2 bed to make it work. that = lots of $$$$$
Re: trimming it up
yeah im not doing that
3 Leaf Fab
Re: trimming it up
i assume you are a second gen truck, though i cant remember for sure. i think the first and second gen's have different openings, i fit 32's (mind you on stock rims) on my first gen with no lift and only slight trimming.
Re: trimming it up
yeha I got a 2nd gen
i thought about getting 31s but i think i still would half to trim its becaue of my back spacing if i get a wheel thats stock bs the 11.50 will then rub on the frame real bad right? |
3 Leaf Fab
Re: trimming it up
only at full lock, and the thing to remember is this. tires rubbing the frame is not really hard on either the tire or the frame. tires rubbing the fenders is hard on both the tire and the fender.
Re: trimming it up
is 4.5 as close as i can get i like my soft 8s tho
I Rather Be Wheelin'
Re: trimming it up
Check it: http://www.s10forum.com/forum/f134/3...i-come-364425/
I don't rub so far. If you use the stock wheels, you won't rub on the fenders, if you use the 2WD wheels (like I am) you'll have to trim. My 30/31's only rubbed the sway bar and the frame - which didn't hurt anything at all. |
Re: trimming it up
If I put my tires on stock 4x4 wheels i belive they are 15x7's well my bighorn says that It should be only mounted on 15x8's will that hurt it.
3 Leaf Fab
Re: trimming it up
no, it will be fine on 15x7 rims. i would probably run up to about a 35x12.5 on a 7" wide rim if thats all the budget would allow.
Registered Asshole
Re: trimming it up
i believe jigg ran 33s on stock crewcab wheels no prob which are 15x7.
Re: trimming it up
any stock wheels that look good in black? I have a burgandy s10 so i like them being black
