Too much camber because of lift?
Go Back   S-10 Forum > Suspension Tech > Liftin' It
Old 07-01-2008, 05:03 PM   #1
Lifted97s-10 is on a distinguished road
A guy at a tire center said he noticed my front tires had a lot of camber and said it was because of the lift kit on it. I bought this truck recently and i didnt install the 4'' lift kit on it but idk if anybody would know if the lift kit could cause a camber problem and if so what should i do about it?...BTW its a 2x4
http://i146.photobucket.com/albums/r...b/DSC01901.jpg
http://i146.photobucket.com/albums/r...b/DSC01902.jpg
Does it look like the front tires have too much camber?
The guy also said the lift kit would ruin the truck because its a 2x4?
Old 07-01-2008, 05:11 PM   #2
wrekd's Avatar
wrekd is on a distinguished road
Re: Too much camber because of lift?
Get an alignment done asap. Otherwise say bye bye to your tires.
The lift wont harm your truck at all.
Old 07-01-2008, 05:25 PM   #3
bellcranks no more
greencactus3's Avatar
uhyea... way to take pics of it with the wheels straight.
lift can cause camber issues.
but if its a good kit you should still be able to align it to factory specs
Old 07-01-2008, 05:54 PM   #4
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
Since the wheels are at full lock, we can definitely tell how much camber it has...
Old 07-01-2008, 06:31 PM   #5
Prerunner Madness
sapperb's Avatar
sapperb is an unknown quantity at this point
You might want to check out your ball joints, they look kinda roached. If I am not mistaking, all you have to do is put more shims in to correct that. Is that a SA kit? They are famous on doing that to caster.
Old 07-01-2008, 06:41 PM   #6
My bad, the guy at the tire center said that he noticed the camber when i was turning into the place and that the lift kit was killin my truck? Lol so i guess i thought turnin the wheels for the pic would help...here's the tires at full lock...
http://i146.photobucket.com/albums/r...b/DSC01906.jpg
http://i146.photobucket.com/albums/r...b/DSC01905.jpg
http://i146.photobucket.com/albums/r...b/DSC01904.jpg
Old 07-01-2008, 06:46 PM   #7
they were leanin pretty bad when i first got the truck but i switched the 2 front tires and they seem to be a lot better...i have another thread titled(headers...right or wrong?)...this is the same guy who said its pointless doin stuff to the 4.3 exhaust if im not gettin headers because the headers will choke it out anyway and even if i just did the y-pipe and cat and muffler he said i wont gain any power...so maybe this guy is just a chevy hater or just is talkin outta his ***?
Old 07-01-2008, 08:38 PM   #8
My bed fell off???
NegativeSwitches's Avatar
NegativeSwitches is on a distinguished road
camber while turning is not going to wear out your tires alone on the streets
you do 99% of your driving with the wheels straight ahead
what you see while your wheels are turned is a mix of camber and caster. caster on an s-truck should be about 4 ish give or take a lil degrees i believe. which is not measurable by the naked eye. camber should be spec is 0 to -.25 ish give or take a .25 degree which is HARDLY noticeable by the naked eye unless you got 35's of 40's with a straight wall tractor trailer style tire.
by looking at your specs i'd say you COULD be a little positive on camber on your right (passenger) side which in case you should get a proper alignment.
camber is a direct relation to tire wear via
excessive negative camber = inside shoulder wear
excessive positive camber = outside shoulder wear
the biggest factor of tire wear is toe in and out
alot of rinky dink alignment shops wont even adjust caster or camber and abide by the crappy toe and go policy because it makes a quick buck
make sure when you get an alignment to ask for a thrustline alignment since you have no rear adjustment.
hope that helps,
-Erik
Old 07-02-2008, 08:13 PM   #9
I MADE IT!!
muddubber's Avatar
muddubber is on a distinguished road
yeah I'd say get you a good mechanic you can trust to give it a good "true" alignment....It really doesn't look bad...I have had worse actually.....haha
Old 07-03-2008, 12:34 AM   #10
vv future wife vv
Merritj2417's Avatar
Merritj2417 is on a distinguished road
yeah, just get it aligned, you should be good
Old 07-03-2008, 09:41 AM   #11
ChrisInVT's Avatar
My truck is SO much worse than that!
Old 07-04-2008, 11:16 AM   #12
forum idiot
orangesonoma's Avatar
orangesonoma will become famous soon enoughorangesonoma will become famous soon enough
yeah it looks good to me..
Page generated in 0.12533 seconds with 11 queries
