the 4x4 vacuum thread.
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
LinkBack (3) Thread Tools
Old 12-13-2007, 02:20 AM   3 links from elsewhere to this Post. Click to view. #1
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
a lot of people have been asking, and probably because the weather is getting bad. a lot of people have problems with their 4x4 not working, for various reasons. one of the common reasons is the vacuum actuator going bad, or the vacuum lines going to it. i have gotten a PM from somebody, and i figured i could share some of the info with everyone.
in s10's, when you put it in 4wd (4hi or 4low) with either the 233 (push button) or 231 (manual shift(also 207)), the transfer case has a switch of sorts that tells the front axle to engage. this switch routes vacuum to one of two places. if you are in 4wd (hi or low), the vacuum goes to the actuator. if you are in 2hi then the vacuum gets routed to an orb where it is just stored. this line also supplies the vacuum. now, the switch it self is on the drivers side, almost at the front of the t-case. it has three vacuum lines going to it. the switch works similar to a ball point pen, meaning there is a round ball that is either pushed or not. the ball gets pushed by the shift fork inside the t-case, when the case is shifted into 4wd.
now, there are three vacuum lines going to the switch. one line supplies the vacuum, and stores it in the orb when not in 4wd. one line vents to the open air, and the t-case vent piggy backs onto it. the other line goes to the actuator. all three lines run together up to the passenger side of the bell housing. then two go one way, and one goes the other. the vacuum supply/orb is the line that breaks from the pack and follows over to the drivers side. the other two lines, the vent and the actuator line, continue to run along the passenger side frame rail where they end near the vacuum actuator. one line plugs into the actuator and the other is just a vent that clips onto the inside of the outer fender well.
the actuator takes the vacuum, when supplied, and has a diaphragm that pulls on a cable. this cable runs down to the passenger side of the front differential, and moves a collar back and forth. this collar either connects the passenger side cv shaft to the carrier, or it disconnects it. this is how the 4wd system works on an s10, and all IFS 4x4 gm products (with a few variants).
now the pictures:
this is the switch installed on a 231. note the vent line coming off the t-case
here is where the t-case vent line meets up with the open air circuit.
you can see the lines running along the trans and bell housing
this line goes off to the orb, and supplies the vacuum from the engine
this line will follow the wiring harness and go the orb, located behind the drivers side headlight
this is the orb
this is where the switch gets vacuum, off the intake
this is the other two lines that go off to the passenger side
they end behind the passenger side headlight
this is the line going into the actuator
the actuator is under the battery tray
now onto the switch. the switch looks like this
if you look at the top, where the lines go in you will notice a little "key"
this lines up with a similar spot on the female end
the three vacuum lines must be in the right spot in order to function properly. take the female end of the vacuum lines, looking at the open end towards you like in the above pic. if you orientate it to where the key is on top, the lines are as follows
if anyone has any questions, or wants any more pics, just ask. i have my body off right now so everything is really easy to get to.
Old 12-13-2007, 08:08 AM   #2
100% A-hole
BatwingZ's Avatar
BatwingZ is on a distinguished road
Re: the 4x4 vacuum thread.
Very good write up Don...
The only downfall tho...those vaccum lines and switches on the side of the tcase are not easiest to get to with the body on...It can become a major pain....But you hit the nail on the head...
Old 12-13-2007, 11:06 AM   #3
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
The vacuum actuator on my truck isn't under the battery tray, it's on the wheel well and extremely accessible (which is nice if it ever dies, but thank god it works perfectly still). My '91 parts truck had it under the battery tray before I removed it.
Three years ago before I was into the S10/S15 scene I had a loaner Blazer... I found out the hard way that the 4WD didn't work (vaccuum actuator):
Had to get pulled out by the blue 2WD dodge behind that hideous camper thing, it was quite embarrassing
Old 12-13-2007, 11:57 AM   #4
Registered Asshole
crazy91s10's Avatar
crazy91s10 is on a distinguished road
^^That chick is prolly thinkin... "Man, whatta loser"
but yeah... def a good write up donahue! i cringe when i have to explain this whole process to folks... so it's def nice that you were able to get pics of the whole system now that you have your body off! now i can just link to this thread when i get this question! thanks donahue!
Old 12-13-2007, 12:48 PM   #5
i love my chevy
19914x4blazer's Avatar
19914x4blazer is on a distinguished road
what happens when you put a solid Axel out front does that affect any thing with the way the t case works or any thing to do with the vacuum set up?
Old 12-13-2007, 01:42 PM   #6
3 Leaf Fab
Donahue's Avatar
when you go sfa, just unplug the lines at the t-case, leaving the switch in there so the t-case doesnt leak atf everywhere. you will want to cap the line coming off the engine so you dont have a vacuum leak. then just remove everything else as it is not needed anymore. that is unless you wanted to hook up the vac disconnect system on a waggy axle or something.
Old 12-13-2007, 02:42 PM   #7
gusdaman's Avatar
gusdaman is on a distinguished road
Can the mods add this to the sticky at the top of the page?
Old 12-13-2007, 04:35 PM   #8
American Muslce
85S10Project's Avatar
85S10Project is on a distinguished road
Is there any chance you could show me where your other vac lines go from the TBI? I have an 86 and the diagram I have is not showing me the stuff for the 4x4 and I think one of my lines is messed up or missing.
Old 12-13-2007, 04:54 PM   #9
3 Leaf Fab
Donahue's Avatar
yeah, do you just want a more specific pic of the vac line coming off the intake? you are talking about the one that supplies vac to the t-case right?
Old 12-13-2007, 05:26 PM   #10
Mr. Sparkle
Onimun's Avatar
Onimun is a jewel in the roughOnimun is a jewel in the roughOnimun is a jewel in the rough
Thanks for the info man! Definatly dont want to replace all thos elines in the near future...
Old 12-13-2007, 05:57 PM   #11
American Muslce
Yeah I need a better one of the one coming off the Intake and tbi. I'm tring to figure out if all of mine are hooked up to the TBi and intake like they should. My truck for some reason has no power brakes and its running rough so I am thinking that a vac line isnt hooked wp right.
Old 12-13-2007, 05:59 PM   #12
American Muslce
Also where is your ORB located? I cant seem to find it on my truck.
Old 12-13-2007, 07:12 PM   #13
3 Leaf Fab
Donahue's Avatar
my orb was behind the driver side headlight by the charcoal canister
Old 12-13-2007, 07:54 PM   #14
RickRock is on a distinguished road
very good write up. Definatly needs to become a sticky.
I have a question:
The three vac lines @ the transfer case. Do they have to be plugged in a certain way from the Tcase? After I put a trans in my truck, I plugged it back in as best as I could remember, and the 4wd worked. I used it like once. Then it stopped working altogether. Even low did nothing. So I got under there and that three line fitting came unplugged. I plugged it back in (wasn't sure if it needed to be plugged in a certain way), and now my front drive shaft spins, and it goes into low, but still no 4wd.
I know it sounds like the vac act. but if that line is plugged in wrong will the actuator not get what it needs to do what it does? How can I tell how it needs to be pluged in without dropping my Tcase? Trail and error??
Old 12-13-2007, 08:17 PM   #15
3 Leaf Fab
Donahue's Avatar
I have a question:
correct, if they are plugged in wrong at the t-case it might not lock up. plug them in according to this:
make sure you line up the little "key". it only goes on one way.
Old 12-13-2007, 08:52 PM   #16
American Muslce
Yeah my truck doesnt have a ORB on it. The air line just stops and has a plug on it. I can take a picture of it if you want.
Old 12-13-2007, 09:48 PM   #17
3 Leaf Fab
Donahue's Avatar
apparently there are a few irregularities. but you get the general idea. i didnt even know what that orb thing was or that i had one until i threw it away.
Old 12-21-2007, 02:08 PM   #18
ChrisInVT's Avatar
That's my cousin, she was in the truck with me when the POS got stuck
Old 12-21-2007, 07:41 PM   #19
4x4 v6 blazer
neo71665's Avatar
neo71665 is on a distinguished road
Vacuum canister
Old 12-21-2007, 08:03 PM   #20
3 Leaf Fab
Donahue's Avatar
Quote: Originally Posted by neo71665
Vacuum canister
sounds like a better description than "orb"
Old 12-21-2007, 10:06 PM   #21
ol' Grey Hair
lbcblazer88's Avatar
lbcblazer88 is on a distinguished road
i got a question is the actuator kinda rubbery on the front side?like were u can push in on it.
Old 12-21-2007, 11:40 PM   #22
3 Leaf Fab
Donahue's Avatar
yeah, thats the vacuum diaphram
Old 12-23-2007, 10:23 AM   #23
ol' Grey Hair
ight thanks.
Old 12-23-2007, 08:44 PM   #24
DIMES MAKIN DOLLARS
project87sdime's Avatar
project87sdime is an unknown quantity at this point
glad i found this again i think this maybe my issue from today when i went wheeling
Old 12-24-2007, 06:19 PM   #25
DIMES MAKIN DOLLARS
ok so looking under there i only see a plug kinda like the 3 plug thing like above but only had 2 not 3 also only had 1 air hose coming out of it. im so damn lost with this and NEW at it too.
Old 01-30-2008, 03:18 PM   #26
pgdion is on a distinguished road
Thanks Donahue for the excellent write up. I'm rebuilding an S-10 Blazer and these vacuum lines are the last thing to figure out. I had one left ... looks like it's just a vent line. :-) This was a huge help as the Chiltons and Haynes (now the same book) are both worthless for vacuum lines (and not much better for electrical). This info is hard to find.
Old 01-31-2008, 11:04 PM   #27
IN A HICKTOWN
chevyrules05's Avatar
chevyrules05 is on a distinguished road
I have a newer s10(2000) and it doesn't have any vacum lines running to it and my 4wd won't engadge any Ideas? the t-casemakes the sound as if it is changing to 4wd but the front axle wont engagde?
Old 02-01-2008, 06:55 AM   #28
3 Leaf Fab
Donahue's Avatar
are you sure there are no vacuum lines? this is a new one to me, this is how all IFS gm's engage the front axle.
Old 02-01-2008, 10:11 AM   #29
2000_Diamond is on a distinguished road
I am having the same issue with my 4wd on my 2000, if i hit the button about 30 times eventually it will engage, it goes right into auto 4wd, but half the time when i try to go back to 2wd, the 4lo light starts to blink and i have to hit 2wd repeatedly for it to go back
Old 02-01-2008, 03:10 PM   #30
Lifted without a clue
Svenson14's Avatar
Svenson14 is on a distinguished road
i had that problem too, it happened to me in the diamond lane of a six lane highway with stop and go traffic in San Jose.
Dealer said it was EPA (some three letter acronym) valve that had to deal with smog restrictions on the intake that got stuck open. they replaced that, and all the vacuum came back, giving me power breaks, and got rid of the rough running.
Old 02-03-2008, 02:15 PM   #31
Zuminazx is on a distinguished road
So a ruptured or broken orb-line will not affect the 4wd?
My 4wd went out last year, turned out the line from the manifold was dry-rotted and worn. I replaced it and it worked fine for the duration of the winter.
It's out again this year. The actuator and line leading to it checked out, however the line going from the T to the orb feels like it has a hole it. Could the problem lie elsewhere? The T case still clicks and the lights on the dash illuminate, but the front wheels remain unlocked.
