LinkBack (10) | Thread Tools |
#1
I BURN THINGS
Solid Axle thread
Let get a thread going about solid axles conversions. Post any info, links, how-to's, tips, tricks, or pics you have. I'll make this a sticky and see what come about.
Off Roadin' Member
How to Swap a Solid Front Axle into a First Generation S-10
First off, I want to present this in as simple as a manner as I can. If a project of this magnitude scares you, I want to get rid of those fears. My swap took just over a year to complete. Planning, parts gathering, and more planning consumed 90% of my time. Did I mention planning? Patience is key here, so make sure you have lots of it. With that said, let's continue. I. Introduction The S-10 comes from the factory with an independent front suspension (IFS) manufactured by American Axle Manufacturing. No years of production ever offered a solid axle, although we all wish they did! This configuration is prone to accelerated wear and breakage when used off-highway. CV axles, ball joints, and idler arms are the most frequently replaced components. The rear suspension is a leaf sprung solid axle, with the axle residing on top of the springs. The GM 10-Bolt in the S-10's comes with either a 7.5" ring gear and 26 spline axle shafts, or a 7.625" ring gear and 28 spline axle shafts. This axle is comparable to the Dana 35 / 35c and 8.25 Chrysler Corporate unit. II. Preliminary Planning When you decide to start cranking the SFA gears, there are a few things that you need to decide before you start. The first is the obvious "Leaves vs. Coils" debate. While coils will yield lots of articulation, keep in mind that coil suspensions are much more complicated than leaf springs and have more axle-to-frame linkages. Also keep in mind the sometimes common "death-wobble" associated with coil sprung Jeep Cherokees, or "torque-steer" in Jeep TJ's. After you decide the type of suspension, now the gears shift into how much lift you want. Leaf springers need to ask if they want spring over or under, flat springs or arched springs, etc etc. Coil springers will need to figure out how long control arms need to be and what coils to use (progressive rate or standard). Each decision you make at this stage can put you anywhere on the map, so give these serious thought. III. Searching for Parts This is another stage where good planning comes into play. Be honest when assessing your needs at this stage, as it will save you from headache later and keep some of your wallet intact. When searching for a front axle, you want to find something with the differential on the left-hand side, otherwise your transfer case wont match up (assuming you have the stock NP 231.) Try to get the tie-rod and draglink with it as well. A. Front Axles If you use a Reverse Cut Dana 30 from an '87 - '95 Jeep Wrangler, it makes life a lot easier. For instance, the pinion yoke and transfer case yokes are the same, brake lines adapt without hitch, and best of all, steering is a direct bolt on. Any Jeep Wrangler pitman arm will bolt on to the S-10's Saginaw steering box. Spring perches are also at a perfect distance apart, at 31". This allows the springs to sit inside of the frame rails just as the stage west kit was designed, while spring perches do not require modification. This unit is very adaptable, and can survive 35" tires without a hitch. The Dana 44 is also a great choice for an axle. Almost all of the parts are available at Pep Boys, Auto Zone, Advance Auto, etc. These axles can be built from mild to wild or anything in between. Best picks to swap into an S-10 would be from '66 - '77 Ford Broncos and late '70s and early '80's Wagoneers. Note that when swapping the Wagoneer axle, it has a 6-lug pattern that must be either converted to match the rear, or the rear must have the same lug pattern. Bronco axles will have the 5 on 5.5" lug pattern, making adaptation quite easy to other axles. Some came with the Spicer 1310 series pinion yoke, while others may have had the Spicer 1330. The Dana 60 is the obvious choice for ultimate strength. Used in many applications over the years, unfortunately none came in an appropriate width for the S-10. If you did want to go full width, take into consideration that your tires will not be under any part of the vehicle. This is illegal in some states, so make sure you know the details before making a purchase. The Dana 60 is an 8-lug axle that came on just about any 1-ton pickup. Ford Dana 60's have the driver's side drop required by the S-10. Like the Dana 44, many axle-shaft, u-joint and ring and pinion upgrades are available. Any axle listed here would be a good choice, yet if cost is a limiting factor, the Dana 30 alone is a great axle. Of course the hardcore guys will tell ya it is a weak piece; it really is appropriate to the size and weight of the S-10. So unless you are into some hardcore rock crawling, the Dana 30 or 44 will prove to be a great bang for the buck. B. Rear Axles GM 10-Bolt, Dana 35 / 35C, and some Chrysler Corporate axles all share the same relative strength. They are considered "safe" up to 33" tires, but after that, look out. Axle shafts will snap, axle tubes will spin, and wheel bearings will be eaten up. They are adequate for one who goes off-roading on occasion, or those with medium to mild trail tastes. GM 12 Bolts Ford 9"s, and Dana 44's are and awesome compromise between strength and expense of parts and ground clearance. Availability of parts its great, where you can get bearings seals, etc at almost any parts store, and gear/locker choices are innumerable while still not totally breaking the bank. Ford 9" and Dana 44's are available in appropriate widths, coming from '66 - '77 Broncos, or late model International Harvester Scouts. The 12-Bolt was most common in trucks, so finding one in the right width may be tricky. GM 14-Bolts, Dana 60's, 70's, 80's, and Rockwell 2.5's are all you need to know for ultimate strength. These axles were used in 1-ton pickups, Ford F-250's and up, M1009's and M715's and other military vehicles came with these axles. 14-Bolts are the most common wrecking yard find, with prices ranging from 75 to 200 dollars. Military 14-Bolts came stock with Detroit Lockers and more acceptable gear ratios. Dana 60's are another common find, but hope that no one has taken out the good stuff. A Dana 60 in good condition should run about 200-300 dollars. 70's, 80's and Rockwells come in UPS trucks, Step Vans, U haul trucks, F-450's, 550's, 650's and 750's. C. Springs Many people have used all kinds of springs for their projects. The most popular choices are springs from Wranglers, CJ's, full-size vans, Dodge Dakotas, and S-10's. In my own project, I used Dakota springs, with a CJ add-a-leaf. In the near future, I plan on adding another main leaf from some Dodge Dakota springs. D. Steel / Misc. When fabricating my mounts for springs, I used 3/16ths Box tubing for my cross member and other brackets. You can use 1/4", but in my opinion, i would rather save weight and use the 3/16ths. It is strong enough to carry the weight of the vehicle, while not burdening the rest of the vehicle with excess weight. When designing a leaf spring suspension for an S-10, the trend is to make a cross member with a drop to it that is welded to the bottom of the frame in the front. The Stage West kit is designed like this as are the vehicles owned by Randy Danielson, Paul (Blackhawk on www.s10-4x4.com), James Loar (jrloar on www.s10-4x4.com), and myself, Darrell Krueger (fullreversal on www.s10-4x4.org.) Especially important in the front, to prevent unnecessary negative arch to the springs, is to have the straight line connecting the endpoints of the spring to be almost if not exactly parallel to the ground plane. If you look at the Stage West kit, the drop bracket and where the end of the shackle is is a parallel line. IV. Pre-Swap Fabrication Before you swap, it is important to know that you can weld on cross members and test fit springs before chopping any bit of IFS off. Also, be sure to drill a 3/4 " dia. Hole through the frame exactly 3 inches back from the original hole that Stage West used for mounting the shackle bolts. Be sure to sleeve this hole with some .75" tubing. If you plan on doing a Stage West style swap, note that Dakota springs are the closest match to the springs that they supply with the now-discontinued kit. When fabricating your cross member, assuming that you have leaf springs, make sure that you are absolutely sure of your welding skills. If not, have someone else do it. Remember, the weight of your front end will be on these springs, so you don't want any shoddy welds breaking in the heat-of-the-moment. V. IFS Removal This can be taken care of with an acetylene torch, plasma cutter, or in its simplest form, unbolting as much as you can, then using a 4.5" angle grinder and a cutoff wheel to eliminate any offending IFS brackets. Retain the shock mounts as they can be used with relative ease on the new axle. Take extra care not to knick the brake lines (rubber or steel) and make sure to disconnect every connection to the center section before letting it drop. This includes breather hoses, electrical connections, CAD cables, drive shaft, etc. This is the most time consuming process in the whole swap, taking up 1- 3 "average persons" days. My swap took about a week and a half working at a leisurely pace after work in the weekday, and all day on Saturdays and Sundays. |
Off Roadin' Member
VI. Assembly (Front)
By this time I am assuming that you have checked and double-checked you measurements of your cross member and shackle boltholes. In my situation, I had a cart that you move furniture with. It's about 3 inches off the ground, has some heavy-duty casters on it, and has a wooden deck on it. I bolted the springs to the axle, along with all of the steering components, and placed it on the cart. From there, I just wheeled it under the vehicle and bolted the front of the springs on first (the end that doesn't have the shackle.) Next, attach the steering, brakes, and electrical connections (4wd light switch). Do the drive shafts last, since this requires the skills of a driveline shop. VII. Assembly (Rear) The rear is fairly straightforward and doesn't require that much thought. Basically, it involves removing the old axle, retaining the old hard brake lines, and preparing the drive shaft for adapting with Neapco PN 3-3130. After removal of the axle, attach the springs to the shackles, wheel the new axle under and set the spring pads onto the axle. Now set the pinion angle, making sure that the angles at the transfer case and at the pinion cancel each other out. This will eliminate any driveline vibrations. In my case with a simple spring over in the rear, I didn't need a new drive shaft. It's a little short, but it still has enough room to do its job. When welding spring perches, make sure you only do about 1" at a time on opposite corners of the spring perch. This will reduce warping created by the welding process. Be sure not to test-drive the vehicle with just tack welds on the spring perches. I made that mistake and caught myself just before I drove off. As soon as I put it in drive, the initial lurch of the vehicle snapped the welds and sent the pinion vertical, almost destroying the U-joint and pulling the drive shaft out of the transfer case. Emergency brakes aren't tough, but do require probably the most effort, due to adapting cables and getting them to hold just right. In my project, I took out the E-brake stuff, and will install a line lock soon. VIII. Test Drive Preparation Before getting all antsy and wanting to drive it around the block or over your neighbors landscape, make sure that you will be safe when you ride in it. Here is a checklist: Are the tires inflated to recommended pressure? Are the brakes bled thoroughly? Do the tires have adequate clearance? Does the steering move freely? Is the drive shaft secured to the transfer case and axle securely? Are all suspension bolts / nuts and lug nuts properly torqued? Are the axles filled with the appropriate amount of gear oil? Have the wheel bearings been packed with grease? This is just a basic checklist, and there are probably more things to look over. Remember, it is the owner/operator's responsibility to make sure that the vehicle is safe to drive. IX. Test Drive On the initial test drive, I recommend taking the vehicle for a short test drive in your neighborhood, away from heavy traffic, and not to stray too far incase you need to be towed back home. Take careful note of the handling characteristics, braking distances, whether or not you have bad axle wrap under acceleration, etc, etc. Fix each problem, and then take it out for another test drive. By doing this, you will keep uncovering problems until you are ready to take it off road. Remember that when you have a lifted truck, your center of gravity will be raised, your braking distance will be increased, requiring a more alert driver. Be sure to adjust your driving style accordingly. X. Final Thoughts This project is easy to do unless you psyche yourself into it being a difficult one. Here are three pieces of advice I would like to pass on. First get damn good at welding, or shell out to have it done for you. Second, don't be afraid of the project. There are many who have done this conversion and can offer help if you really f-up. Finally, do not start this project until you have absolutely every piece that you will need. Do your homework, and plan well. It pays off. I spent a whole year planning, and when it came time to do everything, I ran into fewer snags than most people, and completed the project in less overall time. Don't get yourself down about "not having the fabrication skills needed." Anyone with half of a brain and who likes to do some work on their car/truck will be able to do this project. Good luck! |
Off Roadin' Member
btw, i took that from s10-4x4.org so i didnt type all that.
I BURN THINGS
a few companies make or have made solid axle kits for s10s. stage west used to make a leaf sprung solid axle conversion. fabritech makes and sells 2 versions of a coil sprung solid axle kit. www.setstr8.com
got SFA?
Im almost done doign SFA on my truck, i can give you specs, pics and anything ya want. Lemme know.
I BURN THINGS
Hey that was a great write up on that swap. I have done that swap on my truck and I agree with a lot of what was said. I am going to keep checking this thread to see if I can help anyone. I am going to give a link to my pics of my truck so you all can see some up close pics of all my mounts and how they went on and how it looks in the end. And like it was said before this isn't the hardest thing in the world it just takes time and planing. It also take a willingness to say that you don't know everything and ask for some help. I did the first setup on my truck when I was only 17 and I built the whole thing myself and it worked alright but if I would have listened a little more and had planned a little better I wouldn't have had to do it again after 2 years. Now it is almost flawless and works like a champ offroad.
http://community.webshots.com/user/trialsintrigger Here is the link to my pics and I should have some more soon I just have to finish getting the motor through the smog leagal swap so my time and money are tied up in that right now. and if you guys are thinking of doing a motor swap also just ask it really isn't that hard even in california to keep it smog leagal. |
I'm still trying to figure out how to connect the driveshafts. The truck drives without the front d.s. and the rear is at a sharp angle.
The front d.s. won't even go on without binding. I think it needs custom double cardon joints at the transfer case front and rear. The truck is bone stock except for the suspension, a shop installed it for the previous owner, no one got around to the driveshaft work though. Here are two pictures of it. |
Hung Member
Trialsins truck origonally was just a series of madifications and a whole lot of junk yard research. Just walkin around and seeing if this and that will fit.
Off Roadin' Member
what do you guys run for your front springs on the SAS? i want alot of articulation yet it needs to be stiff enough to support the weight of the truck. i was thinking of either a set of front 73-87 K10 2" lift springs..or maybe some front YJ's with an AAL maybe?
I run a set of stock hight K5 springs. They are great and flex well but I am going to take a couple more leafs out to get some more articulation. I already took off the overload. They are plenty stiff for freeway driving but really flexy off-road. Just run a nice set of shocks. I have pro-crap es3000 and they work well enough to keep it from fliping on the freeway.
Off Roadin' Member
stock K5 front springs? i always thought those were like 2 or 3 real thick leaves but i guess i was wrong.
got SFA?
I run the Rancho 44044 Front springs on mine. It's really flexxy. I just got my fenders trimmed up so ive been testing it out alot here lately. For front springs you can also use stock grand waggy springs, take two sets of rear s10 springs and put them together, a set of rear Fullsize springs from the 80's chevyies and there are a few other out there. Just have to look around.
Off Roadin' Member
well I'm wanting to run 35" tires with this SFA swap, which of those springs have enough arch to them to allow clearance for 35's? thanks
got SFA?
Id run the Rought Country 2" Rear Springs for the fullsize Chevy's. KY Mudhunter has those and bushwackers on his truck at the extremist site and hes running 35"s. Your bets bet is gonna be SOA and some fullsize springs.
Off Roadin' Member
ok cool, ive saw his truck and i love it. yours is awesome too. i guess i just like all SFA chevies. do you think 4.10 gears are gonna be too fast for 35's though?
hey guys i'm new here and i am glad to see all the info given on this topic......as i am pondering a 350 sbc, s&m465, and np205 swap in a 88 4x4 blazer....i came here to do some reasearch as i want to swap the dana 44 front and 12 bolt rear end also(everything is out of a 75 k-5 blazer thats wrecked)...i am wondering about frame width on the little s-10...i know the full size axles are quite abit wider and wanted some input on reverse deep dish rims to tuck tires back in some...i want to run 39.5 swampers...and also some info on the steering box out of the s-10 to the dana 44 front....keep in mind this will be a toy...only thing i want to keep is p/s and a heater and of course an alternator any help will be greatly appreciated
btw b4 any1 suggests different axles ....i want the wider track of the fullsize axles
got SFA?
thanks for the complament. 4.10 with 35"s should be good. MAYBE look into 4.56 if you can. Most the guys i talk to with 35" on the S10 are running 4.56. I am running 4.11 with 33" on mine and its got plenty of power. I can sping the back very easily at a dead stop, even though i have done it much cause the soft swampers.
RudeDog..for a toy thowing those axles under there are fine. You'll only have about 2-3" of the tire in the wheel well though.The Front frame width is 32" outside to outside, so you'll want to make a 31" crossmember going across it. The back im not sure off the top of my head. The steering box should work with the D44 axle. Most guys keep the stock box. |
Off Roadin' Member
ok thanks for the tips man..now im just stuck on how to get enough rear lift. its gonna be spring over axle, long shackles, and an AAL...all together thats about 9-10 inches of lift...is that enough?
#24 |
got SFA?
i did spring over and a overload spring from a BDS lift for a fullsize truck and used the stock shackle. I sit perfectly level right now. and its 11" over stock.
#25 |
I Hate IFS
Halfway through the straight axle conversion on my 89 s-10 and I stumbled upon a wee bit of a problem. There is no way I can mount front shackles on my truck! I have the baja version of S-10 and apparently the sub frame is too narrow for Shackle mounts and doesn't go far enough in front to mount the leaf springs and keep the axle centered. Does anyone know a way around this or some sort of set up a shop might sell to fix this problem? Thanks for your help.
#27 |
Off Roadin' Member
look what i picked up today...axle, tierod, steering stabilizer, drag link, new brake pads, rotors and calipers(just some surface rust) and a body mount i needed all for $100. only thing it needs is 1 tie rod end..new spider gears (but im putting in a detroit tru trac) and a pinion nut...so i think i got an awesome deal.
#28 |
got SFA?
Why are you mounting shackles in the front?!?! Most people just use a hanger design up front that are connected to the crossmember you should make. I wouldnt even trust shackles up front, but thats me.
#29 |
got SFA?
DAMN!! that is an awesome deal!! I got my axle, tie rod, drag link, rotors and everything for 80 bucks. Thats both axles included.
#30 |
alrite this thing is coming apart this weekend...any1 need a broke 2.8 or a good tranny or tranfercase from a 88 s10 blazer.email me..also the whole front dif is coming out, from hub to hub and the rearend....with this said will i need a special oil pan after the stock ifs is outta there? i'm thinkin seriously about puttin crossmembers across the bottom of the frame and let them stick out past the frame 1" on both sides(sum1 said my s10 frame is 32") my full size axle fit a 34" frame (i'm not sure yet bout s10 frame first mini i've ever dealt with i will measure after it is disassembled)......still worried about my steering hooking up....its all serious mud around here so i need little articulation....basically building a bogger i can drive to the local hole....with enuff said after i get all 4 new cross members in place correctly i plan on installin leave springs(hanger, shackles, shackle mounts and all) out of the rear of a 1/2 ton truck(fullsize) both front and rear to hang my axels under i no it will ride like a dump truck but i need cheapo and i have all this stuff laying around and i'm a certified welder who is working my way thru engineering school (only 3 semesters left...whuuuuuhuuu) any1 done this? any1 understand what i'm talking about? any input would be greatly appreciated...or just sum reassurance would help
#31 |
oh yea i wanted to no if any1 knew anything about rear backspacing on my rims to set them back into the tubs alittle.....i want it fat with the tires out the side but not 2 much |
