rim help
I just got my lift on and looking for new tires and rims.
I want the tire to stick out so i believe a need negitive offset? what size offest will stick out 1-2 inches and what bolt pattern? thanks Last edited by NorthernCrew : 09-09-2008 at 12:39 AM. |
2UP1DOWN
Re: rim help
5x4.75 is the lug pattern...you cant go wrong with these...
http://store.summitracing.com/partde...5&autoview=sku |
Re: rim help
thanks i will be looking at those rims!
How much mm offset will it take to set the tire out 1.5 inches from fender |
2UP1DOWN
Re: rim help
Not real sure?...But this is what they would look like on a first gen with 32x11.50s...you dont have a lot of options on offset with cheap wheels...its usually a 4 in. "backspace" on an 8" wide wheel...
![]() not soft 8's but same offset and size Last edited by tfpets : 09-09-2008 at 01:27 AM. |
3 Leaf Fab
Re: rim help
a 4" BS rim (8" wide) will stick out 2.5" more than stock with the same size tire.
Re: rim help
this is what im looking for
Support 4WD Factory
Re: rim help
then that's what you want basically a 2wd offset on our 4x4s
Size Matters
Re: rim help
Here's mine with 33" BFG's. But I am running a Long Travel kit so that gained me an extra 1.5" over stock per side. The rims are the Soft 8's 17x8, 0 offset with 4.5" BS. The links are to the fullsize photo.
![]() http://i56.photobucket.com/albums/g1...g?t=1221004217 ![]() http://i56.photobucket.com/albums/g1...g?t=1221004251 Here's with 1.5" wheel spacers installed on the front: ![]() http://i56.photobucket.com/albums/g1...g?t=1221004307 Here's the info from Unique's website www.uniquewheel.com: RIM SIZE-------------- BOLT CIRCLE------------- OFFSET (+/-)MM--------------- BACKSIDE SETTING 17x8--------------------- 5-4.75---------------------- 0------------------------------- 4 1/2" Last edited by Blackie : 09-09-2008 at 09:02 PM. |
Re: rim help
would i run into any problems with a 4" offset?
Re: rim help
wear on ball joints and wheel bearings will be worse.
3 Leaf Fab
Re: rim help
Re: rim help
yes 4" backspace!
dang donahue you've been correcting me all day! |
Go Big or Go Home
Re: rim help
will those soft 8's (http://store.summitracing.com/partde...700+4294923106) fit my 2002, regular cab? How about 31/10.50/15 tires?
Who needs 4x4
Re: rim help
nope never in a million years haha ya they'll work fine. |
Re: rim help
will they work for my stock tires until i get my 31" in the spring?
stock 215X70XR15 rim - 15X8 |
Re: rim help
why dis mount and re mount, buy the rims and wait til spring to put them on.
Re: rim help
cant wait that long to run the black rim look
![]() would they fit till then? |
3 Leaf Fab
Re: rim help
just paint the stock ones black.
Re: rim help
nice donahue.
yea they will fit |
Re: rim help
ha thanks guys!
Re: rim help
well i just bought my new 31's tonight so no need for stock tires
Go Big or Go Home
Re: rim help
Good deal, I just got my 31's on today and couldn't be happier.
