Project: Fix to busted CV shafts & wheel bearings! 56k no no
LinkBack (2) Thread Tools
Old 01-14-2008, 11:28 PM   #201
Tim99Zr2's Avatar
Tim99Zr2 will become famous soon enough
Re: Project: Fix to busted CV shafts & wheel bearings! 56k no no
alright, cause im pretty sure i cant just lengthen mine to a fixed length.. it needs to be able to get longer and shorter?.. correct?
Old 01-14-2008, 11:31 PM   #202
Baggey22's Avatar
Baggey22 is on a distinguished road
for flexing purposes it needs to slightly change length
Old 01-14-2008, 11:33 PM   #203
Tim99Zr2's Avatar
thought so. dammit!!
Old 01-14-2008, 11:47 PM   #204
Baggey22's Avatar
best way to measure is flex your truck out so your driver's side front wheel is off the ground. That is when your driveshaft will need to be the longest.
Old 01-14-2008, 11:49 PM   #205
Tim99Zr2's Avatar
then i'd have to fully compress it, then subtract them and get how much my DS will need to flex.. hmm?
too bad its a DD or i'd just make a square one.. and put some bb's in it to balance it, right donahue? i wish..
Old 01-14-2008, 11:51 PM   #206
Baggey22's Avatar
Yea, I'm thinking an XJ driveshaft for mine. They are upgradeable so if it's not long enough you can make it slip longer
Old 01-14-2008, 11:52 PM   #207
Tim99Zr2's Avatar
yea, ill prob be researching a DS this week.. i wanna get this thing done!! well.. 4x4 wise
Old 01-14-2008, 11:54 PM   #208
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
atf balances driveshafts, bb's are for tires. and if you get yours lengthened, it doesnt get rid of the slip, it just adds to the "tube" portion of the driveshaft. and a square driveshaft is only bad when you use it at high speeds. if you have locking hubs and never plan on using say 4 hi, i would run it. the thing you have to think about is the driveshaft that you "need" is probably $400 because you have a very flexy front spring and require more slip than stock drivelines. this is why square drivelines are popular, because they have hugh amounts of slip at very low cost. check out http://www.highangledriveline.com/
Old 01-14-2008, 11:57 PM   #209
Tim99Zr2's Avatar
hmm. so i could get away with a square DS, IF i get locking hubs?
and auto tranny fluid balances it? how do you go about keeping it in the DS?
Old 01-14-2008, 11:59 PM   #210
3 Leaf Fab
Donahue's Avatar
it doesnt work for sq, but on a round shaft you just put it in before you weld the fixed end on, about a quart.
Old 01-15-2008, 12:02 AM   #211
Tim99Zr2's Avatar
ooh, i thought you meant a square one.. damn haha..
i could make a square one, if i dont plan on using 4x4 at higher speeds? correct?
EDIT: Square tube DS FTMFW!!! i think this is what im going to do.. if my truck falls apart from vibrations, oh well.
Old 01-15-2008, 12:25 AM   #212
Baggey22's Avatar
It's not using 4x4 at high speeds, it's driving at high speeds. The front driveshaft will spin if your in 4wd or not.
Old 01-15-2008, 12:27 AM   #213
Sponsoring Amsoil Dealer!
poriggity's Avatar
poriggity is on a distinguished road
yup.. unless you do a manual hub conversion on that D30 which is $$$ your front shaft will still spin all the time, and an unbalanced front shaft will cause the truck to drive like crap.
Scott
Old 01-15-2008, 12:29 AM   #214
Baggey22's Avatar
Well he does have the vacuum disconnect. So with the passenger side of the axle disconnected I don't think his driveshaft will spin. On mine I flipped the fork over so that it's constantly "locked" so mine will spin. Thats why I'm doing an XJ shaft. I'll just put a longer slip yoke on it if necessary
Old 01-15-2008, 12:32 AM   #215
Tim99Zr2's Avatar
yea, i plan on leaving the vac lock on there, if i do, i wonder if my ds will spin?
im going to try to hook some steel cables up to the vac lock somehow.. cause vacum sucks.. cables are better.
Old 01-15-2008, 12:38 AM   #216
Baggey22's Avatar
Good plan. I believe if you have the vacuum lock disconnected your drive shaft won't spin. I can test it on mine since it's on a table tomorrow for ya. (like unlock it and spin both tires)
Old 01-15-2008, 12:40 AM   #217
Tim99Zr2's Avatar
yea, i was thinkin about going out on my alley, putting my truck in gear and hopin out to check it out.. im curious now. haha, go look NOW!!!
Old 01-15-2008, 12:42 AM   #218
Baggey22's Avatar
the building(theatre) that my axle is in is locked right now, I can go look tomorrow morning and get you an answer.
Old 01-15-2008, 12:45 AM   #219
Tim99Zr2's Avatar
sounds good, if i dont find out before then! haha
Old 01-15-2008, 01:24 AM   #220
3 Leaf Fab
Donahue's Avatar
yeah, all ive said is only for trucks with lockouts or some other way to make the ds not spin. yet another reason i think the d30 would not be my first choice.
Old 01-15-2008, 01:25 AM   #221
Tim99Zr2's Avatar
eh, there is always room to upgrade.. haha.
do you know if my ds will spin if i have the vac lock "open" orr. not engaged?
i dont think it should?
Old 01-15-2008, 01:27 AM   #222
3 Leaf Fab
Donahue's Avatar
it wont spin, same as an s10.
Old 01-15-2008, 01:29 AM   #223
Tim99Zr2's Avatar
alright cool, guess ill rock that for awhile.. thanks guys.
time to research the simple square DS
Old 01-15-2008, 01:33 AM   #224
3 Leaf Fab
Donahue's Avatar
whats to research, take the stock one, cut off the ends. then take some 2x2 and some 2.5x2.5 and weld it on.
Old 01-15-2008, 01:36 AM   #225
Tim99Zr2's Avatar
just trying to sound like im using my time wisely.. haha.
but yea, they are simple and cheap! what i like!
Old 01-15-2008, 08:17 PM   #226
Registered dumbass
NC4x4's Avatar
NC4x4 is on a distinguished road
If you live in areas where it snows and the city salts the ground a lot + you don't wind up using 4x4 all that often, consider spraying lubricant on the square driveshaft to minimize any seizing that it might do.
Not generally a big problem, but I've heard of it before, so may as well pass it on.
Old 01-15-2008, 08:21 PM   #227
Eroq's Avatar
Eroq is on a distinguished road
check out yer local TSC, they have square driveshafts premade with yokes already on them.. just a matter of finding the one with the right yoke size
Old 01-15-2008, 09:09 PM   #228
3 Leaf Fab
Donahue's Avatar
is that tractor supply company?
Old 01-15-2008, 09:18 PM   #229
Registered dumbass
NC4x4's Avatar
Yes
Old 01-15-2008, 09:38 PM   #230
3 Leaf Fab
Donahue's Avatar
we dont really have those here
Old 01-15-2008, 09:53 PM   #231
Registered dumbass
NC4x4's Avatar
I do know they are all over the South, at least around here anyhow.
Old 01-15-2008, 11:08 PM   #232
Tim99Zr2's Avatar
nc, could you post up a pic of your tranny cross member?.. please and thanks
ill have to check at TSC, i was just going to go to the steel shop up the street
