Project: Fix to busted CV shafts & wheel bearings! 56k no no
LinkBack (2) Thread Tools
Old 12-29-2007, 01:19 AM   #51
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
Re: Project: Fix to busted CV shafts & wheel bearings! 56k no no
is that front hanger for the rear spring a zr2 specific one, or is that some aftermarket part? as for my comment on the 30* shackle, that is my personal preference. the more vertical the shackle, the more stable it is, but at the cost of (a little) flex. the more you angle it, the better it flexes, but you give up some stability. i would for sure reinforce those shackle mounts too. did you use weld on perches for the rear flip, or the "flip kit"? as for cutting the overload short, but leaving it in the pack, i would do that. the only reason though is to keep that extra 1/2" of lift it gives you. if you take the spring pack apart to put in an aal, be sure to replace the center pin with a new one.
and, the rear pinion angle look fine to me check the angle of the rear output with an angle finder, and then compare it to the pinion angle. at static height your pinion should be tipped down about 3* from what ever the output is at. my rear output slopes down at 5* in my blazer FYI.
Old 12-29-2007, 01:31 AM   #52
Baggey22's Avatar
Baggey22 is on a distinguished road
Maybe it was just the picture I looked at. As I said I was eating pancakes at the time so I wasn't 100% paying attention.
Old 12-29-2007, 01:31 AM   #53
Tim99Zr2's Avatar
Tim99Zr2 will become famous soon enough
when you get parts cheeks...
ok, as for the shackle hanger, i ordered a bushing and i will pick it up weds. this way is just a temp job, by no means staying on there. haha. the shackle mount should be tuff enough for what i do. i cut my old perches off, and re welded them on, (i just seen that flip kit fail on here. not good) i could prob use any spring off a vehicle with a 2" wide pack? or do i need a Z one. and will do on the center pin!
i didnt have any vibrations at all, truck drives really nice, steering is a little loose, i think the pitman arm will help it?
all in all, i feel pretty good about myself for being able to accomplish this in roughly 5 days
thanks guys.
Old 12-29-2007, 01:33 AM   #54
Baggey22's Avatar
You can do anything as long as it is the same width. If it's from a different vehicle you may have to drill a new center pin hole but thats not a big deal.
Old 12-29-2007, 01:35 AM   #55
Tim99Zr2's Avatar
sweet. i hope i can find something to put good arch back in it. what would be a good one to use? any ideas. prob something off a full size?
Old 12-29-2007, 02:05 AM   #56
WTF?
02ZQ's Avatar
02ZQ is on a distinguished road
More lift per springs and ditch the BL and it'll be major !once again good work Tim.
Old 12-29-2007, 02:06 AM   #57
Tim99Zr2's Avatar
dads tryin to get me too.. haha. we'll see. its a DD project!
Old 12-29-2007, 02:10 AM   #58
WTF?
02ZQ's Avatar
Hell yeah!
Old 12-29-2007, 03:00 AM   #59
3 Leaf Fab
Donahue's Avatar
the springs are 2.5" wide so start there. if the plan is to run a main leaf with the eyes cut off as an aal, i would recommend a 52" chevy main leaf. they will stiffen the pack up some, but not too much. they also have a centered pin. drilling holes in springs sucks, they tend to laugh at most drill bits.
Old 12-29-2007, 03:02 AM   #60
Tim99Zr2's Avatar
yea, i knew they werent quite 3" but yea.. you get what i meant.
ok. would that leaf come off a old full size front axle, or newer rear? where could i find it?
and thanks for the warning about drilling it out!
Old 12-29-2007, 03:08 AM   #61
3 Leaf Fab
Donahue's Avatar
your looking for 73-87 pickup (73-91 burb and k5) rear springs. they are mostly found in 1/2t's but are rumored to be in 3/4t's sometimes too. take a tape measure because they can also have 56" springs. they are very similar, but have an offset pin. the 52's have a pin distance of 26" on both sides, the 56's have one side at 26", and the other at 30".
Old 12-29-2007, 03:10 AM   #62
Tim99Zr2's Avatar
hmm thank you! your so helpful!
Old 12-29-2007, 04:53 AM   #63
i love my chevy
19914x4blazer's Avatar
19914x4blazer is on a distinguished road
December 28
Got everythin almost finished, so i took it out driving around. although with no shocks / sway bar makes for a "floating" ride.. god it sucks! and my brakes still need bled out.. oh well! i just had to drive it around! got a few looks.
pics arent very good. ugh ill have to get them tomorrow.
that is so sweet makes me want to go start cuting thing off my blazer and get ti work
Old 12-29-2007, 11:44 AM   #64
Baggey22's Avatar
This is why I'm going with full size springs to start with. I've already seen them work nearly perfect in another application.
Old 12-29-2007, 12:03 PM   #65
Registered Asshole
crazy91s10's Avatar
crazy91s10 is on a distinguished road
Quote: Originally Posted by 1up_1down
Looks good tim. hey i mounted those front tires didnt I??? when are we doing mine??
not before we do mine!
Old 12-29-2007, 06:15 PM   #66
Tim99Zr2's Avatar
well i got some pics, but im st my bros house right now, ill upload them when i go home!
Old 12-29-2007, 08:34 PM   #67
1up_1down's Avatar
1up_1down is on a distinguished road
ur gonna half to wait in line. besides we half to do ours at the same time to be twins!!!!!
Old 12-29-2007, 10:03 PM   #68
Baggey22's Avatar
Twins like Amos and Drmrman?
Old 12-29-2007, 10:05 PM   #69
Tim99Zr2's Avatar
but gayer
Old 12-30-2007, 12:46 PM   #70
Registered Asshole
crazy91s10's Avatar
so yeah... how bout that damn pitman arm!!!!!!
next time i'm gunna tell ya everythings easy.
by the way... the basement is finished so i'll be good to come down again sometime soon!
Old 12-30-2007, 01:05 PM   #71
Baggey22's Avatar
damn pitman arm?
Old 12-30-2007, 01:21 PM   #72
Registered Asshole
crazy91s10's Avatar
damn pitman arm?
well i went down to tim's this past thursday and took my pitman arm puller down with me so he could pull his stock one off. and the whole time i kept tellin him how it was gunna be a bitch to get off and how i fought with mine for hours just a few days before. well... his came off in a minute and he put the new one on in minutes. pissed me off cuz mine gave me such trouble!
Old 12-30-2007, 01:22 PM   #73
Baggey22's Avatar
What actually holds the pitman arm on?
And did he have to use the tool to get the old one off or just regular tools?
Old 12-30-2007, 01:27 PM   #74
Tim99Zr2's Avatar
brandon gave me his pitman arm puller to use, tightened it down and tapped the pitman arm with a hammer and tightened the bolt up as i taped the pitman arm. it was a breeze..
the pitman are is held on by just that one nut and lock washer. I've heard they can be hard to pull off.
i also heard t-bars are a bitch to get out, mine popped right out with a couple taps with a mini sledge hammer
Old 12-30-2007, 01:31 PM   #75
Registered Asshole
crazy91s10's Avatar
your truck was obviosly ready to just fall apart!
but yeah like tim said... big nut and washer. i used a 1 5/16" socket but it had a lil slop in it so i'm thinkin its metric....30 some odd millimeters
Old 12-30-2007, 05:14 PM   #76
Tim99Zr2's Avatar
couple pics.. i need my wheels back!
Old 12-30-2007, 05:33 PM   #77
Registered Asshole
crazy91s10's Avatar
33s look tiny now! need 35s
Old 12-30-2007, 05:38 PM   #78
Tim99Zr2's Avatar
nah, ill keep the 33's... for now
Old 12-30-2007, 05:47 PM   #79
Registered Asshole
crazy91s10's Avatar
plus i'd be a lil worried bout wheelin 35s on that d30! just me though!
Old 12-30-2007, 05:49 PM   #80
Baggey22's Avatar
35s would be okay if you didn't have the vacuum disconnect axle shaft
Old 12-30-2007, 05:50 PM   #81
Tim99Zr2's Avatar
dont matter, im keepin 33's just spent 800$ on them. haha
