#401 |
Registered Asshole
Location: Moscow, PA / Mansfield, PA User is: OffLine ![]() |
Re: Project: 1995 s10 SAS
i like the idea baggey.... i do think you should adapt chris's idea though of making it function like a stock tailgate. i think constantly pulling it up just to open it will get old pretty quick.
#402 |
That's not a bad idea Chris. I just got the idea while I was flying home from my trip. I was thinking about all the cool trucks I saw and drew it up quickly on a napkin. So I haven't actually looked at the truck yet to see if the idea is even plausible, and like I said I don't use the bed much so even if I can't do your idea it's not that big of a deal. I just want something better than a nylon net that is held onto my bed by 4 sheet metal screws.
#403 |
I Rather Be Wheelin'
#404 |
So bad news. I was counting on a CV joint to put on my rear drive shaft to come in today so I could drive Sally to my apartment and start the tail gate but it didn't come in. So my truck is still a lawn ornament, WHICH SUCKS. The more and more I think about it the more I'm leaning towards just making a square tube rear DS just to get the truck done so I can have some fun with it.
Question about the square tube: since I have a rear slip yoke can't I just make a solid rear DS? Just get a piece thats longer than what I have now and weld my ends onto it? Or should I just make a slip square tube one? |
#405 |
That's exactly why I don't mess with my stuff until winter. Don't want to kill all my wheeling time with fixing time.
#406 |
Well I had to do this. Your transfer case had a shorter output shaft than mine. So it screwed up my rear drive shaft. Not a big deal, it's an easy fix. Just waiting for parts sucks
#407 |
Yeah you could do that. Or instead of square tube for the rear you could go to home depot and just get some sch40 and make one. And since you still have the slip yoke, you dont have to have a slip in the driveshaft. |
#408 |
Why do you need a cv joint at the rear shaft?
#409 |
It was the easiest fix. When I swapped the NP233 to the NP231 the driveshaft wasn't long enough because the NP231 output shaft is shorter than the NP233. So I was going to put a CV joint on the original drive shaft because it only needs like 2" to work.
So what do people think? Solid square tube or slip square tube? Because I don't have time to go out to a junk yard and find another s10 with a CV drive shaft to fix it that way. Unless someone has an old s10/Blazer CV joint laying around to donate to my offroading cause. |
#410 |
As far as I know no s-10 ever came with a CV driveshaft because they all ran a slip yoke.
Heres what I did to lengthen my driveshaft 2 inches. Its ghetto but its holding up great. Cut your driveshaft in half, get a piece of 3" exhaust pipe, slide one end in and then the other till you get the length you need then Weld her up and youll be good. Before anyone says that wont be strong enough. If youve ever cut apart your driveshaft its about the same thickness as exhaust tubing. The exhaust tubing might actually be a little thicker. |
#411 |
Can I get pictures of that Wrekd?
#412 |
Yeah ill try to snap some tomorrow if I remember. Im going on a 3 day fishing trip wednesday and packing and doin all little stuff and everything. But I'll try to remember.
#413 |
I dunno, I wouldn't trust an exhaust pipe section much for my driveshaft...
#414 |
![]() ![]() ![]() We pretty much sleeved the whole driveshaft with 3" exhaust pipe. Ive beat on it good a couple of times and it took it like a champ. Plus it cheap and easy to do, and I pretty much have a double walled driveshaft. |
#415 |
So how long of a piece of exhaust pipe did you use? a short one or one that was almost the whole length of the drive shaft?
#416 |
Its almost the whole length of the driveshaft but you could get away with a shorter piece. We just used that much cause I had it layin around from when we put a catback on my dads truck.
#417 |
where are these tires?
#418 |
Thanks Wrekd
Tim - I was on the other side of the country for 3 weeks, the tires are still in the bed of my truck. They'll be going on as soon as I figure out this drive shaft problem. |
#419 |
your gay..
#420 |
I'm not gay, I'm just busy. I'm gonna try to get the drive shaft done tomorrow.
#421 |
2UP1DOWN
If your new 231 has a shorter output than the 233 did then might have the same problem I did when we were building my brothers...you must have the 231 with the small/short yolk...the problem we had with that one is that there wasnt enough slip for the amount of travel in the rear...in other words if you get the driveline to the proper length so it doesnt bottom out on up travel then it will fall out of the t-case on down travel, and if you get it set in the right spot to have enough yolk in the t-case on down travel then it will bottom out long before you get all of your up travel...that is why we had to find the other style 231 (which is the same yolk as a 233)...you might recall this pic of the 2 different 231's...
![]() This is the short output 231 (notice the ribs on the output housing) ![]() This is the long output 231 (again notice the ribs on the output housing) ![]() I strongly suggest you figure out which one you are dealing with before you waste time/money on something that probably wont work!! |
#422 |
I have the shorter one. It came out of Chris's parts truck. So you're saying it doesn't have the correct amount of slip?
#423 |
2UP1DOWN
I hate to say it, but thats what we found...its just to short...in a stock or slightly lifted aplication it is ok because the driveline is nearly pointing straight back, but once you go so far as spring over axle and get the driveline at that much of an angle it needs a lot more room to move in and out...I guess that would be geometry?...but that is why we decided really quickly to go with the long one! And even at that the long one is still kinda tricky...the driveline has to be JUST RIGHT...it still has enough travel that it can go in to far or out to far if the driveline is even a 1/2 inch off either way...
#424 |
Slightly Over Built
Does the older 207 t-case have the long output? I might have been real lucky with my old setup, because other than bending it bashing it on the rocks, it never gave me any trouble and that was with an axle flip, 2" blocks, and 3" springs.
#425 |
I thought it was the longer one since it came out of a standard cab longbed? I thought the shorter one was only for x-cabs that have the carrier bearing with the split driveshaft?
Edit: Hmm, it does look like the shorter one... I guess I stand corrected. ![]() Last edited by ChrisInVT : 06-19-2008 at 01:30 PM. |
#426 |
2UP1DOWN
Honestly I think the difference is in years...my brothers red blazer was a 90 with the short shaft and his 92 has the long one...it seems to be that it changed in 91 or 92...Im not saying its impossible but it does make it more difficult...the fact that your truck is longer might make it more possible, but in the end the longer one would certainly be easier to deal with!
#427 |
he could always run an intermediate shaft with a carrier bearing like an x-cab since he has a longbed and not a shortbed.
#428 |
Run a what?
Would running a rear square drive shaft work? I know they don't balace worth crap but I'd rather not dump more money into a new transfer case. If it has a lot of slip will it slip before the slip yoke of the Tcase? I don't drive it on the street much, just to trails and back and I always go back roads so I can go slow. Last edited by Baggey22 : 06-19-2008 at 07:14 PM. |
#429 |
yes, if you dont plan on going over 20 mph
#430 |
2UP1DOWN
#431 |
#432 |
Pictures are good. Thanks Chris
#433 |
