Project: 1995 s10 SAS
Old 08-04-2008, 03:32 PM   #651
Tim99Zr2's Avatar
Tim99Zr2 will become famous soon enough
Re: Project: 1995 s10 SAS
pssh, PTOS are better.
piss off then i wont help you!
Old 08-04-2008, 03:39 PM   #652
Baggey22's Avatar
Baggey22 is on a distinguished road
I never said PTOs were worse/better. I'm just saying that I'm going the square tube route because I don't feel like spending $100 MORE when all I need is like $20 or $30 in steel.
Old 08-04-2008, 03:42 PM   #653
Tim99Zr2's Avatar
yea, i would think you could use my same lengths thou, they are basically the same concept. get your outside tube 20" and the inside like 18"
Old 08-04-2008, 05:16 PM   #654
wrekd's Avatar
wrekd is on a distinguished road
I used 2.5"x.25 wall and 2"x.25 wall to make mine. I just bought 2 foot of each. you'll be doing alot of grinding to get it to fit. I know I had to
Old 08-04-2008, 05:19 PM   #655
Baggey22's Avatar
What grinding is going to be necessary?
Old 08-04-2008, 05:46 PM   #656
Tim99Zr2's Avatar
on the square tube, there is a weld seam on the inside of the tube, you will need to grind a channel into the inside tube so it can slide into the other. (i think thats what he is talking about) or maybe just alot of grinding to get it level on the yokes
Old 08-04-2008, 05:51 PM   #657
wrekd's Avatar
Oh yeah, I forgot about that seam
And there is alot of grinding to do to get them to slide together. But for the price and durability it is 100% worth it.
Old 08-04-2008, 07:09 PM   #658
Baggey22's Avatar
Actually I don't have to do anything to get them to slide together. When I went to the steel place they gave me my sections of steel already slid together. So that part is easy and done. Now what about getting the round pieces of old drive shaft onto the square pieces of new driveshaft? any suggestions?
Old 08-04-2008, 08:15 PM   #659
wrekd's Avatar
Just cut them off flush and then weld them on.
Old 08-04-2008, 10:20 PM   #660
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
when i did mine, i cut the yoke off about 1.5" from flush with the yoke. i then ground 4 flat sides in the remaining 1.5" and gave it a press fit in the sq tube. i also made sure and tried to get the yokes as in phase as possible, to keep the vibes to a minimum (kind of a moot point with a sq shaft but oh well...).
Old 08-04-2008, 10:25 PM   #661
Baggey22's Avatar
Donahue do you have more pictures of the shaft all welded up? Thanks
Old 08-05-2008, 12:41 AM   #662
3 Leaf Fab
Donahue's Avatar
this is everything i have.
Old 08-05-2008, 12:52 AM   #663
wrekd's Avatar
These are the only ones I have of mine
Old 08-05-2008, 09:07 AM   #664
Baggey22's Avatar
Thanks guys, I'm taking everything to my buddy's house and he's gonna help me weld it up. Then once I install the tranny Xmember Chris and I made it'll go in.
Old 08-05-2008, 09:34 AM   #665
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
Yeah, satellite internet sucks. Pics don't do that thing justice, it was much cooler IRL
Old 08-05-2008, 05:06 PM   #666
Registered Boozer
coloRADo_S10's Avatar
coloRADo_S10 has a little shameless behaviour in the past
Baggey your truck looks sick! Looks good now that you got tires on it
Old 08-05-2008, 09:34 PM   #667
Baggey22's Avatar
Update: Today I got out of work early and got my square tube drive shaft all welded up, it came out great and wasn't terribly difficult to make.
Then when I got home I took on the task of installing my new tranny Xmember. It wasn't as easy as I thought it would be, mostly because I was working alone. But it's in, for the most part. I need to add a few more bolts (drill and tap them into the frame)
I WAS going to install my drive shaft but I've run into ANOTHER problem. I got a Jeep front output yoke a while ago and come to find out it doesn't work with the drive shaft I have and the original one on the s10 doesn't either. So I'm kinda stuck until I find an output yoke that fits my drive shaft. I'm guessing that the yoke is from some Wrangler but my drive shaft is from an XJ. So anyone have one or know someone that has one? I'm going to keep on the prowl myself.
I'll take pictures soon, it's dark out and they wouldn't look good right now anyways.
Old 08-05-2008, 10:21 PM   #668
3 Leaf Fab
Donahue's Avatar
231's and d44's have swappable yokes, you may look there. i know this works because my front axle has my original 231 yoke on it for the driveline.
i also would not trust anything "tapped" into the frame. the frame is only like .125" thick, and i would not trust any load bearing bolt like a trans crossmember.
Old 08-05-2008, 10:24 PM   #669
Baggey22's Avatar
The plan with the tapping into the frame is I'm doing it temporarily to check for clearance. Then once I know it works (which it does) I'm going to ream the holes bigger and weld nuts onto plates, then weld the plates into the frame.
Old 08-05-2008, 10:32 PM   #670
3 Leaf Fab
Donahue's Avatar
sound good. i would say use at least 4 3/8" bolts.
Old 08-05-2008, 10:43 PM   #671
ChrisInVT's Avatar
You installed that x-member by yourself? You're a brave man.
Weld the nuts to the x-member, IMO that would be your better (and easier) bet.
Old 08-05-2008, 10:43 PM   #672
Baggey22's Avatar
Well right now it's being held on by six 1/2" bolts
How do you propose I weld them to the Xmember?
Old 08-05-2008, 10:59 PM   #673
3 Leaf Fab
Donahue's Avatar
1/2" bolts are plenty.
Old 08-06-2008, 12:59 AM   #674
wrekd's Avatar
You need the yoke from an XJ since your running a CV driveshaft.
Old 08-06-2008, 01:09 AM   #675
ChrisInVT's Avatar
With my welder
Old 08-06-2008, 01:58 AM   #676
3 Leaf Fab
Donahue's Avatar
for that to work he would have to drop the bolts in from the inside of the frame, which i'm guessing is fully boxed at that point.
Old 08-06-2008, 02:57 AM   #677
ChrisInVT's Avatar
That's how the stock x-member is held into place. The nuts aren't welded on, but you have to place the bolts through the frame. It would be easier to drill the hole to insert the bolts, than to hack up the frame to get a torch head in there to weld the nuts on.
Might actually be better off not welding the nuts at all, that IMO would be the easiest/quickest/less troublesome way to go.
Old 08-06-2008, 09:07 AM   #678
Baggey22's Avatar
I don't think you 100% understand what I'm saying Chris. I'm saying take the nuts and weld them to a small square of flat stock. Then take the holes that I've already tapped out and ream them BIGGER than the nut. stick the nut inside the hole and then weld the plate to the frame. Then attach cross member.
Old 08-06-2008, 12:57 PM   #679
Drifting Nomad
Outlawz24's Avatar
Outlawz24 is on a distinguished road
so basicly the plate that the nut is welded to is sandwiched between the chassis and the cross member...adding more material to the mount areas in the process...
Old 08-06-2008, 01:03 PM   #680
ChrisInVT's Avatar
AHHHH I understand what you're saying now.
That's probably not going to work too well for you, the x-member doesn't have enough clearance since we designed it to touch both frame rails.
I might be misunderstanding you again though.
Old 08-06-2008, 06:10 PM   #681
Baggey22's Avatar
Either that or I could just weld it right to the frame.
Old 08-07-2008, 01:41 AM   #682
3 Leaf Fab
Donahue's Avatar
that sounds like a great idea...
