my s-10
Old 08-03-2008, 08:55 PM   #1
loud s-10
project truck is an unknown quantity at this point
my s-10
2 wheel drive no clue on lift , tire is a 285 / 65 / R16 sitting with the hub centerd to get a idea... pics..
any idea on inches of lift?
Old 08-03-2008, 09:31 PM   #2
Slightly Over Built
DieselS10's Avatar
DieselS10 is on a distinguished road
Re: my s-10
Hard to tell with those pics. If you take the jack out from under it, probably none.
Old 08-03-2008, 09:41 PM   #3
loud s-10
Re: my s-10
the jack is holding the hubs centerd... it is lifted but i dono how much... no stock 92 2wd s-10 is going to clear a 285 / 65 / R16 like that without a lift.. pic with 205 / 70 / R15's
Old 08-03-2008, 09:42 PM   #4
Tim99Zr2's Avatar
Tim99Zr2 will become famous soon enough
Re: my s-10
when you jack it up, the extend the suspension it will..
Old 08-03-2008, 09:47 PM   #5
loud s-10
Re: my s-10
yeah but my sus. dont compress but maybe a inch cause of the way i lifted it
Old 08-03-2008, 09:51 PM   #6
Tim99Zr2's Avatar
Re: my s-10
you lifted it? how dont you know what kind of lift it has?
coils, leafs, shackles, and spindles. take a pick
Old 08-03-2008, 09:53 PM   #7
loud s-10
Re: my s-10
shackles in the back and twist in coil spring boosters in the front 4 per spring
Old 08-03-2008, 09:54 PM   #8
Tim99Zr2's Avatar
Re: my s-10
how much longer were the shackles over stock?
Old 08-03-2008, 09:56 PM   #9
loud s-10
Re: my s-10
i dono alittle longer there off a 94 explorer cause i gave him mine i had from discount from a while agaio when i 1st got the truck and put his on mine.. ill go out now with a tape and find out
Old 08-03-2008, 09:57 PM   #10
Tim99Zr2's Avatar
Re: my s-10
i believe stock ones are 6" CTC, and for each inch on the shackle length, thats .5" of lift.
Old 08-03-2008, 10:04 PM   #11
loud s-10
Re: my s-10
stock ones are 3 inches bolt hole to bolt hole the ones i got are 6 inches bolt hole to bolt hole
Old 08-03-2008, 10:12 PM   #12
Slightly Over Built
DieselS10's Avatar
Re: my s-10
Does it have an engine in it?
Old 08-03-2008, 10:14 PM   #13
loud s-10
Re: my s-10
yes it was my DD till my tag expired then i parked it and its sat in the same spot since only thing i did was put the stock springs in and the ghetto lift on and started the bodywork / new paint
Old 08-03-2008, 10:16 PM   #14
Tim99Zr2's Avatar
Re: my s-10
then it'll be 1.5" of lift over stock (in the rear)
Old 08-03-2008, 10:18 PM   #15
loud s-10
Re: my s-10
someone told me the front is about 3 inches but the back sits level with the front.. so i need to get me some more discount ones that are hella longer... and then put a 3 inch coil spacer in the front and be done
Old 08-03-2008, 10:25 PM   #16
Tim99Zr2's Avatar
Re: my s-10
can you put coil spacers in dimes? i didnt think you could.
Old 08-03-2008, 10:26 PM   #17
loud s-10
Re: my s-10
im talking about the ones that go inbetween the springs not under them
Old 08-03-2008, 10:28 PM   #18
Tim99Zr2's Avatar
Re: my s-10
ahh, i would just get spindles.
Old 08-03-2008, 10:30 PM   #19
loud s-10
Re: my s-10
30 bucks for 3 inch coil spacers > 180+ for 3 inch spindles for something ill be takeing out when i find jeep live axles anyways
Old 08-03-2008, 10:31 PM   #20
PABlazin's Avatar
PABlazin is on a distinguished road
Re: my s-10
the 2wd sags in the front, so 1.5 in the rear and 3" in the front would level it out. Just thought I would add that.
Old 08-03-2008, 10:33 PM   #21
loud s-10
Re: my s-10
i never noticed mine saged but i never parked on anything stright everything i park on has a lean to it.. i pulled the s-10 out on the road to find out it sat level
Old 08-03-2008, 10:35 PM   #22
Tim99Zr2's Avatar
Re: my s-10
then why bother lifting it now? just wait.
youll need that 30$ when it nickle and dimes you to death!
Old 08-03-2008, 10:36 PM   #23
loud s-10
Re: my s-10
cause itll be a while befor i get the live axle.. and i hate anything stock ride highth and my truck didnt work out lowerd so a 3 inch raise will be food for now
Old 08-03-2008, 10:39 PM   #24
Slightly Over Built
DieselS10's Avatar
Re: my s-10
put a body lift on it, that's 3 fairly cheap inches.
Old 08-03-2008, 10:40 PM   #25
Tim99Zr2's Avatar
Re: my s-10
i see i see. i know its hard to leave stuff stock.. i cant. haha!
Old 08-03-2008, 10:42 PM   #26
loud s-10
Re: my s-10
body lift's are ugly and i would never run one...
Old 08-03-2008, 10:43 PM   #27
loud s-10
Re: my s-10
i cant keep anything stock.. my 1992 her metro 2 door vert was lowerd ... that link in your sig.. i was looking at it and i like lol
Old 08-03-2008, 10:45 PM   #28
Slightly Over Built
DieselS10's Avatar
Re: my s-10
Then ya better start saving $$$$$$$.
Old 08-03-2008, 10:54 PM   #29
Tim99Zr2's Avatar
Re: my s-10
body lifts are gay. but make it 100 times better working on it under neath.
Old 08-03-2008, 11:00 PM   #30
Slightly Over Built
DieselS10's Avatar
Re: my s-10
So do air bags .
Old 08-03-2008, 11:04 PM   #31
Tim99Zr2's Avatar
Re: my s-10
So do air bags .
i hope a stick blows out your bag!!
Old 08-03-2008, 11:48 PM   #32
Slightly Over Built
DieselS10's Avatar
Re: my s-10
Why thank you.
Old 08-04-2008, 01:58 AM   #33
Tankerblade is on a distinguished road
Re: my s-10
just get a 2 inch one so it isnt that bad and save some big bucks for any other type of lift
Old 08-04-2008, 02:02 AM   #34
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
Re: my s-10
stock s10 shackles are 4" CTC, all of them.
Old 08-04-2008, 08:04 AM   #35
loud s-10
Re: my s-10
well i might be 4x4 sooner then i thought found a old CJ jeep frame motor tranny T case axles everything besides the body
