Got the blazer today...found some mud and...
Go Back   S-10 Forum > Suspension Tech > Liftin' It
Old 06-16-2008, 09:01 PM   #1
Drifting Nomad
Outlawz24's Avatar
Outlawz24 is on a distinguished road
Im HOOKED!!!! Even though i was only out for a bit i had a blast testing out the 4wd in my Blazer..I picked it up earlier this afternoon and after it stops raining i will get some pics...
Old 06-16-2008, 10:02 PM   #2
Drifting Nomad
Outlawz24's Avatar
Re: Got the blazer today...found some mud and...
As promised heres some pics of the truck...I do have all 4 of the chrome wheels but i had to install my spare that the seller gave me off of an olympic edition 2wd parts truck since one of the tires on the chrome wheels was completely screwed...
Only paid $700 for the truck and for the most part all it really needs is a tune up and a new muffler to be a decent running lil truck..
Old 06-16-2008, 10:33 PM   #3
IN A HICKTOWN
chevyrules05's Avatar
chevyrules05 is on a distinguished road
i am jealous i want an old beater that runs good, and not bad for only $700, are you going to make it your DD or is it a toy?
Old 06-16-2008, 11:12 PM   #4
Drifting Nomad
Outlawz24's Avatar
This truck will be my DD.
Old 06-16-2008, 11:19 PM   #5
hot damn.
lee-mill's Avatar
lee-mill is on a distinguished road
beaters ftw!
Old 06-16-2008, 11:22 PM   #6
IN A HICKTOWN
thats cool as long as it runs good how many miles?
Old 06-17-2008, 03:22 AM   #7
Drifting Nomad
Outlawz24's Avatar
In miles it comes out to 155383 Miles and in Kms its 248613. From first driving impressions..i forsee needing to put in new plugs and wires..Probably wouldnt hurt to throw in a cap and rotor as well. Def need to run some fuel system treatment through the lines and carb. The truck sat for 2 years prior to my buying it today. The main thing i need to get used to is being up high compared to being in a low slung cadillac...But as of today Project Blackout begins..
Old 06-17-2008, 03:47 AM   #8
IN A HICKTOWN
is it carb or a throtle body?
Old 06-17-2008, 04:05 AM   #9
Drifting Nomad
Outlawz24's Avatar
Carb
Old 06-17-2008, 05:19 AM   #10
Mr. Sparkle
Onimun's Avatar
Onimun will become famous soon enough
Mudding? i see no evidence of that. Truck looks clean...
The steering wheel is installed terribly wrong. Looks solid. Could use some paint.
Old 06-17-2008, 10:26 PM   #11
IN A HICKTOWN
Carb
yea def make sure, what engine is it?
Old 06-17-2008, 10:52 PM   #12
Drifting Nomad
Outlawz24's Avatar
Stock 2.8 V6
Old 06-17-2008, 11:00 PM   #13
wrekd's Avatar
wrekd is on a distinguished road
Just judging by the dash it looks like an 83 or 84.
Old 06-18-2008, 02:32 AM   #14
Mr. Sparkle
Onimun's Avatar
or 85...
Old 06-19-2008, 01:41 AM   #15
American Muslce
85S10Project's Avatar
85S10Project is on a distinguished road
are those flares off a jeep cherokee? It looks good for 700
Old 06-19-2008, 07:22 AM   #16
Drifting Nomad
Outlawz24's Avatar
Thats what i suspect they are off of. They fit pretty well other then the gaps where the cladding would be on the Jeep...But when i cover the lower part of the body with diamond plate i will probably form rock guards where it meets the flare to hide those gaps..i travel on enough gravel roads that i can justify adding the lower body armor to the truck. The one other bonus about the jeep flares is that i could cut some of the existing fenders sort of like when cut out fender flares are used.
Old 06-19-2008, 07:25 AM   #17
Drifting Nomad
Outlawz24's Avatar
oopps...forgot to post some pics of the truck after i went out mudding again on tuesday..this time finding a lot more mud after installing some M/S tires.
Old 06-19-2008, 03:13 PM   #18
Who needs 4x4
marcua56's Avatar
marcua56 can only hope to improve
do a body lift, crank the t bars, add some shackles and then throw some 32's on that bad boy. Perfect mud rig.
Old 06-20-2008, 03:09 PM   #19
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
That's what my truck looks like when it's clean
Old 06-23-2008, 12:33 AM   #20
vv future wife vv
Merritj2417's Avatar
Merritj2417 is on a distinguished road
seriously...
Old 06-29-2008, 09:07 PM   #21
Drifting Nomad
Outlawz24's Avatar
How large of tire can i use if i were to lift the truck with a Superlift 2" suspension lift and Bushwacker cut out fender flares? I was going to body lift this truck but i decided against it so i can use headers when i build a new engine for it.
Old 06-29-2008, 09:32 PM   #22
mbord79's Avatar
mbord79 is on a distinguished road
Everyone I talked to said that the 2in sus lifts suck and cause more problems than they are worth. Too much angle on the ball joints and cv shafts and stuff.
Old 06-29-2008, 11:15 PM   #23
wrekd's Avatar
Yep, might as well just crank the t-bars and throw some lift shackles on the back. With the stock rims you can fit 31's by just beating on the inner fender with a BFH. Theyll rub the sway bar and frame a little bit but not to much.
Old 06-30-2008, 11:29 AM   #24
ChrisInVT's Avatar
That makes no sense... How is a body LIFT going to create problems with headers?
Old 06-30-2008, 12:16 PM   #25
95BlazerLT4wd's Avatar
95BlazerLT4wd is on a distinguished road
dont you need a body lift to run a v8 or is that just 2nd gens?
Old 06-30-2008, 01:11 PM   #26
Drifting Nomad
Outlawz24's Avatar
not building a V8 for this truck building a hopped up V6. And as for how the Body lift interferes with the headers its a clearance issue when it comes to the header and the steering shaft. Neo was the one that brought this point up.
Old 06-30-2008, 01:14 PM   #27
ChrisInVT's Avatar
I've never heard that before. The steering shaft doesn't change angles or anything, I'm not sure why it would create a problem.
Old 06-30-2008, 01:24 PM   #28
Drifting Nomad
Outlawz24's Avatar
http://www.s10forum.com/forum/f106/w...-2-8-a-357169/
It was brought up in this thread.
Old 06-30-2008, 01:27 PM   #29
ChrisInVT's Avatar
There's a shitton of info there, I'm going to check it out in a bit.
Old 06-30-2008, 02:47 PM   #30
ChrisInVT's Avatar
I checked it out, and there's was no evidence that they won't fit, other than a "so and so said I'd have to modify them" kinda thing.
Old 06-30-2008, 03:03 PM   #31
Drifting Nomad
Outlawz24's Avatar
Still on the fence about the idea of a BL. Not exactly liking the idea of ordering some nice long tube headers and installing them then go to add a BL and find out i do have to mod something..
Old 07-01-2008, 12:02 AM   #32
Drifting Nomad
Outlawz24's Avatar
Ok..since it was suggested to go with a T bar crank and shackles instead..i will ask this..Will it be safe to assume i will be able to clear 30"s with the T bars cranked and shackles along with some sawsall surgery to fit bushwacker flares?
Old 07-01-2008, 12:16 AM   #33
Productive Member
Criticalbeatdown95s's Avatar
Criticalbeatdown95s is on a distinguished road
not enough mud...try again bro...that just looks like what was left over from last winter haha
Old 07-01-2008, 07:02 AM   #34
