dunno if anyone cares but heres something different
Go Back   S-10 Forum > Suspension Tech > Liftin' It
LinkBack (1) Thread Tools
Old 12-15-2007, 10:43 AM   1 links from elsewhere to this Post. Click to view. #1
Loose Nut is on a distinguished road
doing a buildup and figured id let you all see what im doing.
well i have is a 1991 GMC Jimmy 1500 with the following
dana 60 Front with 4:56's and posi.
CTM u-joints
35 spline Alloy axle shafts
ATOR 35 spline Lockouts
Custom Hydro assist
ORD High Steer w/ 2wd steer gear box for side to side, not push pull steering
Rock crusher Diff cover
Rebuilt King pins
Black Widow Extended brake lines (4 inches longer then pro comp)
New Brakes
14Bolt w/ Detroit Locker & 4:56's
Ruff Stuff Spring Perchs
Pro-comp extended brake lines
DIY4X Pinion Guard (BEEFY!!!)
New Brakes
ORD 4 inch Shackles Fully greasable
ORD Shakle flip kit
ORD Frame brace for steering box
Blazen Offroad Winch Bumper
BlueTorch Fab U-Bolts
New Altenater
Stainless steel brake lines front to rear
Underneath Coated with Rustolem Hammered paint
38.5 TSL's
so, wheeled it a bunch at Gore VA and RC in PA. body got beat to crap and it was basicly falling off. so i decided to do a body swap...
here is the donor truck and the trail rig side by side
a slight difference in size
Here is the rear shot, the body will be moved forward a few more inchs so the rear frame is going to be hacked right behind the shackle. the tank has been pulled and a fuel cell will be installed in its place.
here is a shot to show how wide the stance is. This is fullwidth 1 tons with 4.25 inch back spacing on 38's. ill be going to 42's shortly.
In this picture, you notice how tight space will be. Where the body sits right now there is no room for a radiator or fan, so we need to cut out the firewall and move the body forward a little bit.
When we move the body forward, that will resolve the frame hanging out in the front and my offroad bumper and 12kwarn will hide what ever we dont get tucked in under the truck
Another shot of the side of the s-10, 42's will look hot on there
Couple other things to note, the rear will need comp cut to clear the tires, the front will be cut from the front wheel well to the core support to clear the tires. The wheelbase on the s10 is 101 inch's, the wheel base on the jimmy is 105.
The inside of the s10 will have a full cage installed, the rear and side windows will be pulled, the doors will be removed with the door bars coming out the side of the body a inch or to then being angled into the truck to connect to the cage. this will give us alot more room and will act as a slider for trees and hopefully spare the body for a little bit.
The inside of the roof has been notched as well to provide more headroom as well. the cage will sit super close to the body. Also during the swap a spool will be installed in the D60 because posi sucks The entire dash, heat and ac will be removed and a pair of tubes will run across and will run aftermarket gauges as well with a winch controller and dual battery switch. batterys will be located behind the passenger seat.
thats all i got right now. The birth of the gmc s-10 blazer
Old 12-15-2007, 10:47 AM   #2
Baggey22's Avatar
Baggey22 is on a distinguished road
Re: dunno if anyone cares but heres something different
I personally can't wait to see it done
Old 12-15-2007, 10:54 AM   #3
shot of the jimmy before it was ever wheeled It was so pretty
and the next set of pictures are for comedy sake :P i beat my rig, and well this is the first and only time i ran a mud pit. I will never do it again because it was so nasty, it stank and the mud took 4 hours of power washing. this also broke my steering box, 2 tires, sheered the steering coluom in half at the tilt, tailgate fell off, 2 body mounts broke.... screw mud!
Old 12-15-2007, 11:03 AM   #4
ol' Grey Hair
lbcblazer88's Avatar
lbcblazer88 is on a distinguished road
tht musta been a nasty mud hole!
Old 12-15-2007, 11:05 AM   #5
i blame the driver
http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=21931 380
looks so uneventfull but in person it was really cool :P
p.s. this is a rock crawler, not a mud bogger. MUD SUCKS
Old 12-15-2007, 11:17 AM   #6
ol' Grey Hair
wow u hit hard lol
Old 12-15-2007, 11:18 AM   #7
isnt livin the lyfstyl3!!
Wicked Mayhem's Avatar
Wicked Mayhem is on a distinguished road
interesting
Old 12-15-2007, 11:24 AM   #8
WTF?
02ZQ's Avatar
02ZQ is on a distinguished road
Quote: Originally Posted by Loose Nut
i blame the driver
meh.
Old 12-15-2007, 11:38 AM   #9
yfzracr89's Avatar
yfzracr89 is on a distinguished road
Loose NUt where you located? in in Northern VA around the leesburg area (Aldie to be exact)
i'v been to Gore once in a friends truck but my S10 would never survive up there vbmenu_register("postmenu_4724497", true);
Old 12-15-2007, 12:47 PM   #10
TCOB
Donahue's Avatar
Donahue is on a distinguished road
is your s10 a 4dr? my 2dr's wheel base is 100.5. nice to see another s10 with full size axles. also, are your 38.5 tsls the 16 wide flavor? they seem a lot narrower than mine (mine are also on a 10" rim)
Old 12-15-2007, 12:55 PM   #11
im in maryland.
tires are 38.5x16.5x12.50's
Gore rocks. Thanks for the comments ill post more next week of the progress.
Old 12-15-2007, 12:57 PM   #12
TCOB
Donahue's Avatar
im in maryland.
ah. my tires are 38.5x16x15. you didnt answer me about if your s10 is a 4dr
Old 12-15-2007, 05:15 PM   #13
Quad MX racer #24
yamaha405's Avatar
yamaha405 is on a distinguished road
It's a two door
Old 12-15-2007, 06:14 PM   #14
TCOB
Donahue's Avatar
...The wheelbase on the s10 is 101 inch's, the wheel base on the jimmy is 105...
just trying to figure out where this came from?
Old 12-15-2007, 07:40 PM   #15
i love my chevy
19914x4blazer's Avatar
19914x4blazer is on a distinguished road
looking good so far loose nut
Old 12-15-2007, 09:03 PM   #16
American Muslce
85S10Project's Avatar
85S10Project is on a distinguished road
He probaly just rounded it off
Looking good so far.
Old 12-15-2007, 09:04 PM   #17
TCOB
Donahue's Avatar
rounded up 10"?
Old 12-15-2007, 09:08 PM   #18
American Muslce
rounded up 10"?
He only rounded a 1/2" You said yours was 100.5 and he says his is 101 thats only 1/2".
Old 12-15-2007, 09:11 PM   #19
TCOB
Donahue's Avatar
im effing retarded, damn dyslexia strikes again. i thought this whole time it said 110"
never mind me, im the kid in the corner eating paste...
Old 12-15-2007, 10:22 PM   #20
Blazin_Jason's Avatar
Blazin_Jason is on a distinguished road
That is gonna be a nice truck. So I'm sure that you've seen this recent build.
Old 12-15-2007, 11:04 PM   #21
i love my chevy
that a good looking truck to
Old 12-16-2007, 08:29 AM   #22
whoa nice, ill have to read that thread!
Old 12-16-2007, 09:09 AM   #23
WTF?
02ZQ's Avatar
First of all I commend the Ingenuity on that build,but I hate to see a classic chevy like that get butchered to save a S10,bondo or not my '77 gmc was bondo bucket from hell when I bought it in HS,same with current '79 but new sheet metal works wonders.Second,to put all that effort into a build and not upgrade the axles,,anyway not trying to bash it just my opinion.
Old 12-16-2007, 12:55 PM   #24
Registered dumbass
NC4x4's Avatar
NC4x4 is on a distinguished road
I'm not a fan of swapping bodies, but what are you suggesting he the 60/14 combo to?
Old 12-16-2007, 01:22 PM   #25
TCOB
Donahue's Avatar
yeah, hes already upgarded the axles about as far as you can go. the next step would be 2 1/2 ton rockwells
and the s10 body on a full size frame has been done thousands of times, probably since the s10 debuted in the early 80's.
Old 12-16-2007, 07:08 PM   #26
WTF?
02ZQ's Avatar
Was talking about the other person's build,but guess it applies for both,I thought a D60 front and FF14 bolt rear would be better,my bad on the axles,I know you rock guys know your axles.Still not a fan of body swaps,guess I just love the old full sizes to much to see them thrown away,I'll shut up nowgood luck with the build anyhow.
Old 12-16-2007, 07:17 PM   #27
TCOB
Donahue's Avatar
full size bodies get in the way more.
Old 12-16-2007, 07:27 PM   #28
WTF?
02ZQ's Avatar
I can understand that,love that fullsize stepside in the rock field pic though.
Old 12-16-2007, 07:59 PM   #29
TCOB
Donahue's Avatar
thats probably going to get a pathfinder body in the next 5 years. thats my best friends truck, i helped him build it from the ground up years ago.
Old 12-17-2007, 01:10 AM   #30
i have a D60 with CTM's and Inner and outter 35 spline alloys. Not much better then that axle wise unless you go to a rockwell which has allready been said.
As far as the body swap i didnt have much of a choice. the Body mounts were shot on both the frame and body, it was being held together with ratchet straps since 5 trips ago. As much as i love the fullsize, It is just to wide. I ripped both mirrors off and the passenger door was caved in to the point the window wouldnt work anymore. The seams at the top of the cab were seperating, and the rest of the truck was allready full of bondo which was falling out from the body flexing so much due to only 2 out of 6 or so mounts holding it on.
The reason im doing the s-10 is not only due to size, but its something different. Yea it may have been dont a million times but not the way im doing it. I will have updated pictures sometime this afternoon. The firewall has been removed, and the floor has been notched to allow the cab to sit lower onto the frame for a lower Center of gravity.
Thanks for the comments guys, updates to come.
