D30 steering problem.
I have the D30 under the blazer and the long arms done, but the steering won't hook up. I used a cherokee pitnam arm but the arm is to far back it sits over top of the diff. Do I have to move the box forward or something? Thanks for the help and all my research told me the steering was a direct bolt up.
Re: D30 steering problem.
Pictures might help
You can use a steering box from a early 90's RWD astrovan. Its a direct bolt in and will move the pitman arm 180 degrees to what you have now. To see if thats what you need, just unbolt your pitman arm and turn it 180 degrees.
3 Leaf Fab
steering is a bolt up if you keep the axle in the same place. but it sounds like you moved it forward, or you wouldnt be having this problem. from the sounds of it, you need an astro steering box. its the same, other than the arm points forward instead of rearward.
3 Leaf Fab
and be sure not to drive it with the pitman arm 180* on the stock box, or it will turn left when you steer right. |
3 Leaf Fab
i ended up moving my front axle forward somewhere between 4" and 6" and i could have used the stock box if i didnt have reverse steering. the end of my pitman arm is about centered on my axle tube.
Ok I'm in pretty good shape and down to waiting for a astro box to be delivered. has anyone used a 97 transfer case with the slide on yoke and the cv joint, of did you change to a older transfer with a double cardian knuckle. I don;t think this cv knucle on the factory front shaft is going to flex enough to hook up to the D30. Has anyone else had this problem. Thanks for any help. I'll get pics up soon.
Finally got it out of the garage today, 9 inches of lift. We made the long arms, used explorer coil buckets, D30 and D44 axles, astro box, 6 in cherokee front springs, spring over and 3 in blocks in back, and a Dakota rear rubber brake line. Wow lots of different parts and got all my help here. Been lurking for a year so I finally decided to do the build. Just ended up being for a buddie.
those are huge tires!!! haha sorry i just had to be a smart ass. but that is a very nice/clean rig. cant wait till it get on some bigger tires. that thing will look badass. way to go |
I demand more pictures!
Got the steering done and putting disks on the back today. I'll get some more pics..
SAS inprogress
nice! what size are the boggers?
Those are my 33's I run on my cherokee. We put them on, then decided to go from 6 to 9 inches. He's going to run 35's
Tucking 37"s what?!?!
Location: Hamilton, Ontario (Canada) User is: OffLine ![]() |
BAH beat me to it!!!ah well I just ordered my 37"s today!
looks pretty clean, nicely done
3 Leaf Fab
is that factory jeep steering linkage? it seems odd to have inverted Y linkage on a solid axle. inverted T style where the tie rod connects both tires and the draglink connects to that is more common.
thats how xjs are set up from the factory |
3 Leaf Fab
that has got to cause alignment issues with articulation. toe would not be constant like it would be if there was a conventional tie rod.
Got the same steering set up on my xj with 6.5 lift and don't have any trouble with it.
#24 |
Pulled it out of the paint bay and flexed it with the fork lift. Here's a few pics.
#25 |
Ok done, 12 day's and it went on it's maiden run. Morris really stay's on a build. Lots of little piddle stuff yet but the major stuff is out of the way. The new tread is 35/10.50 tsl radials.
#26 |
Looks pretty good man, especially the Earnhardt sticker. :P
#27 |
Looks real good!! Are they SSR's?
#28 |
I think so, I didn't look real hard. I thought it said tsl radial. I'll look tomorrow.
#29 |
3 Leaf Fab
they are SSR's, which are radials (Super Swamper Radials)
#30 |
They also make the regular TSL's in radials too. I just cant tell if I see those weird side knobs that are on the SSR's from the picture or not. |
#31 |
3 Leaf Fab
they are, the SSR's
