95 Blazer solid axle swap
Old 08-20-2008, 11:39 PM   #51
Formerly VETTEPOWER
V8JUICE is on a distinguished road
Re: 95 Blazer solid axle swap
what bushings did you use in the shackle mounts? or is it part of sky's kit?
Old 08-20-2008, 11:55 PM   #52
Baggey22's Avatar
Baggey22 is on a distinguished road
When you order the shackle mounts you can order it with or without rubber bushings. Just make sure when you weld them in you TAKE THE BUSHING OUT. I forgot once, now I have one slightly melty bushing
Old 08-21-2008, 12:54 AM   #53
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
the speedo may be one thing, but will the trans shift properly without a vss? that i dont know.
Old 08-21-2008, 12:59 AM   #54
Slightly Over Built
DieselS10's Avatar
DieselS10 is on a distinguished road
Good point, I think the VSS sends info to the VSSB, which the computer reads to know when to shift, again, I think.
Old 08-21-2008, 08:27 AM   #55
bodydroppeds10's Avatar
bodydroppeds10
If I run into that problem then I will change it out with a turbo 350 trans. The front bushings in the shackles came with them from sky. They are a 2 piece with sleeve insert.
Old 08-21-2008, 09:16 AM   #56
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
hahahaha...
"Ummmmmm Adam...?"
"Yeah, what's up?"
"Come look at this..."
"OH fuck."
"You have water?"
"No, but I have Iced tea."
"Good enough!"
Old 08-21-2008, 01:31 PM   #57
Drifting Nomad
Outlawz24's Avatar
Outlawz24 is on a distinguished road
Conversation between you two while working on baggys truck there chris?
Old 08-21-2008, 01:45 PM   #58
ChrisInVT's Avatar
Yeah, welding on his shackle mount at like 12:15am
Old 08-21-2008, 02:44 PM   #59
Street Vandals
redteamgo2000's Avatar
redteamgo2000 is on a distinguished road
the sky manufacturing kit is really nice for the price. it includes almost everything you need for the front axle mounts. as for the trans it was discussed in the planning stages that a turbo 350 might be the best bet.
Old 08-21-2008, 03:57 PM   #60
Drifting Nomad
Outlawz24's Avatar
That begs the question..how long did it take you to notice?
Old 08-21-2008, 04:04 PM   #61
ChrisInVT's Avatar
About a whole 10 seconds. I was like "wait, is this shit melting!?! Oh ****! Ummmmmm Adam....?"
Old 08-21-2008, 05:29 PM   #62
Drifting Nomad
Outlawz24's Avatar
Old 08-21-2008, 10:43 PM   #63
local12hand is on a distinguished road
Wouldn't you need something to tell the motor that the trans is there and ok if you put a turbo 350 in there?
Old 08-21-2008, 10:51 PM   #64
Slightly Over Built
DieselS10's Avatar
Might have to switch to a computer from a manual tranny equiped truck?
Old 08-21-2008, 10:56 PM   #65
bodydroppeds10
Im thinking about possibly putting a Ford 302 motor and trans in it. I already have a ford transfer case in the garage
Old 08-21-2008, 11:02 PM   #66
Slightly Over Built
DieselS10's Avatar
A lot of people will cry about putting a Ford in a Chevy, but if that's what you've got, use it. I'm not brand prejudice, I have a little Ford and Dodge in my truck now and it has had some International, Jeep, and Cadillac in it in the past.
Old 08-22-2008, 12:21 AM   #67
wrekd's Avatar
wrekd is on a distinguished road
You were just softening it up for a little more flex, thats all
Im guilty of doing the same thing a couple times
Old 08-22-2008, 01:11 AM   #68
3 Leaf Fab
Donahue's Avatar
i've got ford, jeep, and of course chevy in my truck. i've also got pickup, van, and SUV parts on my ride.
Old 08-22-2008, 10:11 AM   #69
bodydroppeds10
It doesnt really matter to me as long as it all works and I can take it out and go wheeling with it. Im ready to go play! LOL
Old 08-22-2008, 08:50 PM   #70
bodydroppeds10
Found out some good news today. A mechanic told me that I will be fine using the stock transmission and 85 s10 blazer transfer case without the VSS. He told me that I just wouldnt have a speedometer, which is no big deal cause I can run a mechanical speedo. Also all my steering stuff came in except my steering block which should be here tomorrow. Now just waiting on finishing up the brakes and should be done.
Old 08-22-2008, 09:25 PM   #71
Street Vandals
i still like the ford in a chevy thing just because you blow me so much shit about my ford truck. i mean you already got ford axles, drop pitman arm and steering block so why not just finish it off right. ford powertrain and it might actually go through the mud lol.
dont shoot guys im just messin with him. you have no idea how much crap i get about my ford in his garage. i was the one pushing to do the swap in the first place. he wanted to do it and i just forced the issue alittle sooner than he was planning. i mean what are friends for except peer pressure and to be there to laugh and then make sure your ok after you injure yourself. both of which happen often in his garage.
Old 08-23-2008, 10:06 PM   #72
bodydroppeds10
What does anyone recommend on steering? I am not sure if what I have will work or not exactly. Just wanted to get some ideas
Old 08-23-2008, 10:09 PM   #73
3 Leaf Fab
Donahue's Avatar
just run what you've got, drive it around for awhile. if you dont like it, then convert it to inverted T. if you dont like that then you will have to spend more money and convert to conventional crossover. while you may have problems with this setup, there is no reason to be preemptive and spend money fixing a problem that may not exist.
Old 08-23-2008, 10:19 PM   #74
3 Leaf Fab
Donahue's Avatar
nevermind, i got confused with a different thread.
i would go with crossover obviously. have you seen my steering?
Old 08-23-2008, 10:59 PM   #75
bodydroppeds10
No I havent seen your steering. I have the stock box with a dropped pitman arm, raised steering arm and 3 inch steering block. But my thing is I dont think it will work cause of how the draglink is setup with it. I thought about just selling the brand new steering arm and doing the crossover steering.
Old 08-23-2008, 11:15 PM   #76
Slightly Over Built
DieselS10's Avatar
Does the front axle that you have have flat top steering knuckles?
Old 08-23-2008, 11:20 PM   #77
wrekd's Avatar
Heres my setup:
I have an astro van steering box, 4"drop Ford pitman arm, knuckles milled drilled and tapped for high steer, and a Sky Manufacturing Dana44 tall arm.
Old 08-23-2008, 11:36 PM   #78
Slightly Over Built
DieselS10's Avatar
^^^^ that is exactly why I was asking. Wrekd has the perfect steering setup that you are looking for.
Old 08-23-2008, 11:44 PM   #79
bodydroppeds10
Cool thanks for the info. Yes it does have flat top knuckles. Im prolly gonna take the knuckle off tomorrow and get it sent out to have it tapped and stuff. I have 2 raised steering arms if anyone is interested. One is brand new not even installed and the other is used
Old 08-24-2008, 01:47 AM   #80
3 Leaf Fab
Donahue's Avatar
my steering is a bit different. i have a astro box with a ford drop pitman arm. i do not have the conventional "flat top" knuckle, i used the drivers side chevy knuckle on the passenger side. its already designed for a steering arm from the factory. flipping my knuckle allowed me to run my tie rod behind the axle, which helps keep it protected. i used sky's tall arm designed for highsteer. i also had to run my pitman arm 180* out to get the tires to turn left when the wheel was turned left. i used the same TRE throughout (ES 2234R's) which caused my draglink to bind (because i didnt use a DLE which has more range of motion), so i had to bend the drag link. i've got about 12" of lift.
Old 08-24-2008, 01:58 AM   #81
4wdjoey's Avatar
4wdjoey is on a distinguished road
thats a cool setup
Old 08-24-2008, 02:11 AM   #82
wrekd's Avatar
Donahue, dont the DLE's have a bigger taper too? I think I got one one time and it wouldnt fit in my high steer arm. Just wanna make sure he doesnt get the wrong parts.
Oh yeah, my truck has about 10" of lift.
Old 08-24-2008, 02:20 AM   #83
4wdjoey's Avatar
