89 SFA buildup for rocks
Old 06-27-2008, 09:18 PM   #301
95BlazerLT4wd's Avatar
95BlazerLT4wd is on a distinguished road
Re: 89 SFA buildup for rocks
your blazer is my blazer's idol.
Old 06-29-2008, 12:31 PM   #302
bodydroppeds10's Avatar
bodydroppeds10
I have a 95 4 door Blazer that I am getting ready to do a solid axle swap on and puttin 38's under it. I will try and get pics when I am done. Your blazer looks good though. Great work!
Old 07-01-2008, 06:20 PM   #303
Baggey22's Avatar
Baggey22 is on a distinguished road
Hey Donahue can you get me some closer pictures of your front bumper? I want to do SOMETHING like that with mine but with square stock. Like how/where you mounted it. THANKS!
Old 07-01-2008, 07:03 PM   #304
Shawn-GMC's Avatar
Shawn-GMC is on a distinguished road
thats pretty sick, but one thing, do your neighbors think your native? haha scattered car parts all over the front yard :P
Old 07-04-2008, 04:22 PM   #305
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
yeah, i can try and get some. its just welded right to the stock mounts. we did that in about 30 mins at midnight the night before we left for the rubicon.
Old 07-04-2008, 04:39 PM   #306
Tim99Zr2's Avatar
Tim99Zr2 will become famous soon enough
so howd it do at rubicon?
Old 07-04-2008, 04:47 PM   #307
3 Leaf Fab
Donahue's Avatar
well, i will be starting a thread on it later, but i will say that it walked over everything that i did. i was unable to do the little sluice though, my rear suspension tweaked and i didnt want to push it.
Old 07-04-2008, 04:52 PM   #308
Tim99Zr2's Avatar
puss!! ill be waiting! at least the front did good!
Old 07-05-2008, 12:34 AM   #309
Slightly Over Built
DieselS10's Avatar
DieselS10 is on a distinguished road
Can't wait to see it in action!
Old 07-05-2008, 02:18 PM   #310
3 Leaf Fab
Donahue's Avatar
does this work?
Old 07-05-2008, 03:26 PM   #311
local12hand is on a distinguished road
looks like the winch tweaked the front cross member a little?
Old 07-05-2008, 03:46 PM   #312
3 Leaf Fab
Donahue's Avatar
yep
getting pulled by the winch line for a few miles of jerky, bouncy trail when i had to pull the rear driveline. we will be adding material back to the rear of the crossmember (thats where it tweaked) for the next ones we make.
Old 07-05-2008, 03:53 PM   #313
sweet...Well im in the market for one of those whenever you get one done...And a tranny x-member too if you get one worked out...
Old 07-05-2008, 06:24 PM   #314
3 Leaf Fab
Donahue's Avatar
yeah, there will probably be an option for a trans crossmember. it might go under the driveshaft like mine does though, we will see. it will likely be made from round tube.
Old 07-06-2008, 12:29 AM   #315
git r done and i'll buy one cause yours looks cooler than one i'd build
Old 07-08-2008, 11:10 PM   #316
93Vortecon30s's Avatar
93Vortecon30s is on a distinguished road
awesome build, ill be going in that direction with mine shortly.. a few questions for u... i know u have 57" ford leafs, but out of what?? and your steering behind the axle, did u do that because of moving your axle forward?? or to keep it away from rocks?? ill be moving my front forwad about 5-6" Thx Mike
Old 07-08-2008, 11:49 PM   #317
Slightly Over Built
DieselS10's Avatar
does this work?
Now I may be wrong, but those pics kinda look like a "3 LEAF FAB" plug .
Old 07-09-2008, 10:36 AM   #318
3 Leaf Fab
Donahue's Avatar
mine came out of an 88 F150 rear, 4wd. the 4wd ones are 3" wide and the 2wd ones are 2.5" wide. i did the steering that way to keep the linkage protected and because it was cheaper because i didnt use a conventional "flat top" knuckle. i am still runnning an astro box however, so the forward thing is probably a must if you wanted to run it similar. i think mine is somewhere about 4-5" forward and my rear is about 1-2" rearward from stock.
whether it is or isnt, it still is right?
Old 07-10-2008, 02:03 AM   #319
pvfjr's Avatar
pvfjr is on a distinguished road
I'd like to add that the S10 did freaking awesome on this trip, and the SAS kit available to you guys will be bullet proof. The only weakness was brought on by getting yanked by a big K5 over some rough stuff. It was very jerky, and not a good practice. A person should always tow someone with a strap, instead of cables or chains. Anyway, this weakness was recognized, addressed, and will not be an issue on the kits available to you guys.
Old 07-23-2008, 01:19 AM   #320
Drifting Nomad
Outlawz24's Avatar
Outlawz24 is on a distinguished road
Def gonna be keeping tabs on this to see how development of the kit progresses from it.
Old 07-23-2008, 08:54 PM   #321
3 Leaf Fab
Donahue's Avatar
sounds good
Old 07-23-2008, 09:05 PM   #322
Drifting Nomad
Outlawz24's Avatar
Just wondering but have you considered offering a kit to replicate your 4 link setup in the rear? I realise there would need to be welding done on the axle but possably having the frame mounts for the link bolt on? I could be taking a completely wild swing on this one..
Old 07-23-2008, 09:22 PM   #323
3 Leaf Fab
Donahue's Avatar
i ripped my frame where mine is welded on. so my setup needs to be re-inforced quite a bit, and it is still a ways away from being producible as a kit. this was also my first 4 link, and i still havent worked out all the bugs yet.
Old 07-23-2008, 11:36 PM   #324
98-LS-lifted's Avatar
98-LS-lifted is on a distinguished road
but it looks cool, thats all that matters. who cares about bugs as long as it looks good.
coming along good, by the time youre done I will be thru 3 more trucks and then have a blazer
Old 07-28-2008, 12:53 AM   #325
DIMES MAKIN DOLLARS
project87sdime's Avatar
project87sdime is an unknown quantity at this point
lookin good sold my blazer so no more shackles...but after my other truck and jeep get further along i would like to get a 4x4 s10 pick up and i will def. order the kit.
can i get some 3 leaf fab lift shackles for my jeep now? lol
and did stickers ever get made?
Old 07-28-2008, 01:01 AM   #326
3 Leaf Fab
Donahue's Avatar
no stickers, and our shackles should fit jeeps too. just find out how wide the bushings are at the spring eyes, our shackles are designed for 3" wide bushings with a 9/16" bolt. they come in 7", 8", and 10" long so you could figure out how much lift you wanted.
Old 07-28-2008, 01:03 AM   #327
DIMES MAKIN DOLLARS
my leaf springs are 1.75 wide..
Old 07-28-2008, 01:10 AM   #328
3 Leaf Fab
Donahue's Avatar
i take it not an XJ? what kind of heep?
Old 07-28-2008, 01:18 AM   #329
DIMES MAKIN DOLLARS
61 cj5
Old 07-28-2008, 01:36 AM   #330
3 Leaf Fab
Donahue's Avatar
61 cj5
well there's your problem...
Old 07-28-2008, 02:38 AM   #331
DIMES MAKIN DOLLARS
ha ha grandpa had 3 jeeps and i wanted one vs watchin it go..had a 350 vs the other one he wanted to sell with ford 5.0 motor..
im just really tossed on if i wanna spring over or get actual lift springs...and found a d44 for the front to get rid of the drum front brakes..and thought id keep the d44 in the rear..
also have d44 and d60 hd out of a 70's something ford truck that came with my jeep when we go it but i dont know if i want it that wide...what you think
Old 07-28-2008, 10:05 AM   #332
Big Bully
AVdime's Avatar
AVdime is on a distinguished road
Not normally a 4x4 guy but i just wanna say
Tha fab work is top notch and outta this world!
