89 SFA buildup for rocks
Go Back   S-10 Forum > Suspension Tech > Liftin' It
Old 12-11-2007, 04:55 PM   #101
WTF?
02ZQ's Avatar
02ZQ is on a distinguished road
Re: 89 SFA buildup for rocks
Quote: Originally Posted by Donahue
yep, pretty much all of the above. i am using the same spring we used on my brothers sami
Man I like that,looks like it would be fun as hell to wheel.
Old 12-11-2007, 04:57 PM   #102
3 Leaf Fab
Donahue's Avatar
Donahue is on a distinguished road
yeah, the thing weighs 2500 tops.
Old 12-11-2007, 04:58 PM   #103
Registered dumbass
NC4x4's Avatar
NC4x4 is on a distinguished road
yes
Have any particular reasoning behind that?
My truck has the pieces of tubing dropping down from the coil tower that act as bumpstops/retainers.
Not sure how much coils that are retained on both ends will droop, although they will obviously be limited to some extent, but I know mine can flex enough to drop out of the coil tower and start moving down the piece of tubing.
Old 12-11-2007, 05:02 PM   #104
3 Leaf Fab
Donahue's Avatar
yeah, i could do it like that, but they way i made the bracket, it will be better to bolt it in. plus, i think it will still flex more than enough. i have seen my brothers double the spring length from ride height. but if i need more flex, i can always change the design.
Old 12-11-2007, 05:07 PM   #105
Registered dumbass
NC4x4's Avatar
Gotcha. Those springs do look like they will extend without much coercion.
What length and type of coils are those? I'm assuming you are getting a larger lift spring because of the weight difference?
Old 12-11-2007, 05:19 PM   #106
3 Leaf Fab
Donahue's Avatar
no, same exact spring. they are just take offs from a tj wrangler. they will be a touch soft for me, but i am ok with that.
Old 12-11-2007, 05:47 PM   #107
Registered dumbass
NC4x4's Avatar
Is it a full set (f & r) of stock tj coils or what?
Have any idea of their uncompressed measurements?
Old 12-11-2007, 05:50 PM   #108
3 Leaf Fab
Donahue's Avatar
two sets of front springs. they are a 5" diameter spring, about 17" uncompressed. ive got one in my hand here.
Old 12-11-2007, 06:07 PM   #109
Tim99Zr2's Avatar
Tim99Zr2 is on a distinguished road
im whoring..
since i have a Z, would the d44 be too narrow?.
i doubt i will sfa, but just a thought
Old 12-11-2007, 06:16 PM   #110
Registered dumbass
NC4x4's Avatar
Oh ok, cool.
Without incorporating the coil rate factor, I'm figuring you will need to put your bucket/tower about 3-4"+ lower than mine is, although not sure how much further than mine you can go really.
Your coils - 17" uncompressed, mine - 22.5
My frame is ~ 23-24" from the ground, although with my body lift, the body is higher than it would normally be.
22.5 - 17 = 5.5" lower than my bucket
5.5" - approx. .5" your tires, net over mine @ full psi = 5"
There's some redneck "figuring" for you, but that doesn't include a higher or lower rate coil, which I would assume mine would be a little higher because of the lift and application they are designed for.
Is there a spot you already have picked up for the bucket?
Old 12-11-2007, 07:00 PM   #111
gusdaman's Avatar
gusdaman is on a distinguished road
NC
are your coils retained at the axle with anything or just at the top with the tubing?
GUS
Old 12-11-2007, 07:08 PM   #112
3 Leaf Fab
Donahue's Avatar
Oh ok, cool.
i have a general idea of where the buckets are going. but i will have to do a little cutting and fitting to get them right. the springs are going to be about half way up the frame rail or so.
Old 12-11-2007, 07:15 PM   #113
3 Leaf Fab
Donahue's Avatar
im going to take some more pics to show you.
Old 12-11-2007, 07:15 PM   #114
3 Leaf Fab
Donahue's Avatar
Quote: Originally Posted by Tim99Zr2
im whoring..
z's are wider in the body, just the axles.
Old 12-11-2007, 08:34 PM   #115
3 Leaf Fab
Donahue's Avatar
ok, here are the pics of my setup:
Old 12-11-2007, 09:36 PM   #116
i love my chevy
19914x4blazer's Avatar
19914x4blazer is on a distinguished road
you said you are keeping the 2.8 is that going to have the hp to move all that weight
Old 12-11-2007, 10:07 PM   #117
Registered dumbass
NC4x4's Avatar
You will have a little more room since you are moving up the frame, to where it droops a little more, so you will probably get fairly close to being 5" below mine, but I'm just taking an educated guess at this point.
Old 12-11-2007, 10:15 PM   #118
3 Leaf Fab
Donahue's Avatar
not on the street. it wouldnt do 65 with just the 32's on it. but this is probably a trailer queen
Old 12-12-2007, 03:06 PM   #119
i love my chevy
not on the street. it wouldn't do 65 with just the 32's on it. but this is probably a trailer queen
what about the the power to pull or climb over rocks? is their any benefit to keeping the 2.8?
Old 12-12-2007, 03:22 PM   #120
3 Leaf Fab
Donahue's Avatar
it will definitely have power off road, because i have doubled up t-cases. i will be at 135:1 crawl ratio, which if you guess my 2.8 puts out 150 lbs of torque, puts me at just over 20k lbs of torque to the ground. thats more than just about any non doubled truck with a v8. the benefit to keeping the 2.8 is that it is already in the chassis. it also runs great, and has a known history. i also know that i probably cant break my t5 trans with it, nor anything else except for probably my front axle in double low. i guess the thing to remember is that i primarily rock crawl, where HP is not king but gears are. i wont be mud bogging it, maybe once in a blue moon.
Old 12-12-2007, 06:19 PM   #121
3 Leaf Fab
Donahue's Avatar
well, i have some numbers. i have asked for and gotten a few measurements off of other stock blazers. it looks like i am running at 7" of lift. if any of you want to confirm this better, i have about 15" between the axle tube and the frame rail. i have heard twice now that 8.5 is stock, then you add about 3/8" or 1/2" for the tube diameter difference.
Old 12-12-2007, 11:51 PM   #122
gusdaman's Avatar
Donahue,
I was reading your ring gear post on pirate and have this picture for you so you know why you need to decrease backlash.
From here: http://www.pirate4x4.com/articles/te...sta/Gear_Setup
Old 12-13-2007, 12:19 AM   #123
3 Leaf Fab
Donahue's Avatar
Quote: Originally Posted by gusdaman
Donahue,
i see, though i dont think you properly remote linked the pic. i guess i will just have to wait till i setup the gears.
Old 12-13-2007, 01:09 AM   #124
gusdaman's Avatar
No i didnt know how to do it right. sorry
GUS
Old 12-13-2007, 03:16 AM   #125
i love my chevy
i was just asking because my buddy jay has a 2.8 in his s10 and it is a dog in the mud and trails
Old 12-13-2007, 03:29 AM   #126
3 Leaf Fab
Donahue's Avatar
yeah, in the mud mine would be a dog too. but trails and rocks it should kick ass.
Old 12-14-2007, 03:18 AM   #127
3 Leaf Fab
Donahue's Avatar
updates
i did a little cut and burn on my real estate. now where there was once wedge bushings and panhard bar mounts and leaf perches, there is clean!
let me tell you, there is definitely a right way and a wrong way to take the wedges off. i think i found all of the wrong ways before i found the easy way. it seems they are only welded at the very top and the very bottom, not around the tube at all. so all you really need to do is cut the welds off, and they fall right off. and of course my 14b had the cast perches, i guess that is what i get for saying they were a piece of cake to take off. anyways, they put up a little fight but i won in the end.
getting back on topic, the night was still young so i kept on working. i threw my spring up for those that were wondering. just imagine it a little more off the axle tube height wise.
anyways, i busted out the old sharpie and tape measure and started mapping out where everything was going. my spring plates are about as wide as they can be on the axle, they are touching the welds for the inner c. i did this so i can have room for my upper link tower on the drivers side next to the pumpkin.
i soon realized that i still didnt have much room on the short side, so i made a executive decision to run the link tower partially on the cast pumpkin. i did this so i would have good room to get good welds on all the components.
this meant that i had to fit one of the link tower sides to the housing. i used a piece of cardboard to make a template.
here is the final shape
here it is fitted to the housing
i went ahead and started tacking things on to get a better idea of how it will all work together.
you can see my caster and my pinion angle in the last pic, that is how it will be in the truck. caster is dialed in at 6* and the pinion points up nicely.
Old 12-15-2007, 02:22 AM   #128
3 Leaf Fab
Donahue's Avatar
well, i decided to tackle the gear boxes tonight. i needed to get my doubler in before i can figure out my rear pinion angle. anyways...
so i had a spare t5 ready to put in when i had the chance because my old one grinds a lot in 4th. well, i broke it (the spare one) trying to put it in after inspecting my clutch. i didnt have the angle quite right, and when i was trying to draw it in, i broke the pilot bearing portion off. on top of that i also broke an ear off of the bell housing.
the good news was my clutch as in good shape.
anyways, i ended up slapping the old trans back in with a spare bell housing i luckily had. then i went ahead and put the doubler in place. i still need to clock it up more, but this gives me a good idea of the condition of the rear drive shaft. it looks like it will be really short, about 26" from u-joint to u-joint.
and finally, my rear shaft angles
Old 12-15-2007, 11:17 AM   #129
WTF?
02ZQ's Avatar
Looking good man.
Old 12-15-2007, 12:51 PM   #130
