4X4 S10 Lift Kits
Lift kits available for your IFS 4x4 S-series
Superlift 2" lift kit: This kit comes with new torsion bar adjuster keys that attach to the rear end of the torsion bars. These load the torsion bars and determine vehicle ride height. Replacement tubular, upper control arms make realignment possible. For rear lift, the options are add-a-leafs and/or shackles. This lift is known to cause premature wear of CV boots, ball joints, idler arms and pitman arms due to the more severe angles created by the upper a-arms and t-bar crank. Although 2" to 3" can be achieved using this lift, that is the maximum and will increase wear. Rough Country 2" lift kit: This kit is very similar to the Superlift 2" lift. It also comes with new torsion bar adjuster keys to lift the front and new upper control arms. For rear lift it provides shackles. Also included are front shock relocation brackets and polyurethane bushings. Trailmaster 5" lift kit: This kit comes with differential drop bracketry which helps maintain factory C.V. joint angles. It includes new steering center link tie-rod extensions and shocks. However, because it utilizes stock upper a-arms, you need to cut them for shock clearance. Rear lift is achieved by relocating the leaf springs from bottom to top of axle. This lift is also not without problems, in some trucks there doesn't seem to be enough camber adjustment, which causes the insides of both front tires to wear VERY badly due to the tops of the tires are still laid in about 2.5 degree's. This is caused by the way in which drop brackets are mounted. If they are a fraction of an inch off it could cause this problem. The best correction is adding the upper control arms from the Superlift 2" or Rough Country 2" lift. Depending on the amount you go off-road, you will see premature wear of idler arms, pitman arms and halfshafts. If you use the kit with stock, cut upper control arms they may break. BDS 5" & 6" lit kits: These kits also use differential drop bracketry. However, instead of tie-rod extensions, a dropped center steering link is supplied as well as new upper control arms for appropriate shock clearance. Also included are brake line relocation brackets and one-piece front & rear cross members that increase frame rigidity and are locked together with a differential skid plate. Rear lift is achieved by rear spring over axle conversion. Superlift 6" lift kit: This kit comes with bracketry that lowers the factory upper & lower control arms 6". Both front & rear ‘legs’ of each upper control arm are captured by a single bracket then additionally strengthened with cross members. Rigidity is further increased by a unique belly-pan that connects the two lower control arm cross members. A new "dropped" centerlink and Centerlink Stabilizing System to support the centerlink, prevent premature pitman and idler arm wear. Front CV axle angles are addressed by lowering the differential 5 1/2". Rear lift is achieved by relocating the leaf springs from bottom to top of axle. Body Lifts are the cheapest way to lift your S-10; by lifting your S-10 you gain extra room for bigger tires. Pros of body lifts include stock ride characteristics and a taller stance. Some people don’t like body lifts because the frame is exposed, this can be corrected by installing Nurf Bars and Gap Guards. 2” body lifts are available for 84-04 S-10’s and 3” body lifts are available 84-94 S10’s and one company makes 3” body lifts for S-10’s up to 97 and this kit can be modified to work on late model S-10’s as well. For more lift, you can do a solid axle swap. Most people opt to fabricate their own SAS. There is one place that provides somewhat of a SAS Kit and this would be Fabritech Motorsports Fabritech SAS (Solid Axle Swap) For 9 or 11 inchs of lift. It provides a Dynatrac Dana 44 that is setup externally like a Dana 30 Cherokee front end. For the rear, the kit includes nothing, as they recommend a spring over relocation and lift blocks. The front coils, steering, and brake lines come with the kit. You will have supply the front shocks, housing, and all the rear suspension components. The kit includes the following: Driver's and Passenger's Coil towers w/ bump stop assys., Adj. trac bar and adjuster, Coil tower support bar, Upper and Lower 4 link bars, Rear 4-link mounting brackets, Rear trans. x-member, Upper 4-link mounts, Coil retaining hooks, Front coils and brake lines, Pitman arm, Tie rod assy., Drag link assy., Bushings and Hardware. FYI-They DO NOT sell to individuals, only to 4wd/speed shops. For more info, see: www.setstr8.com What tires will fit? No lift or Torsion Bar tweak Torsion bar tweaking can gain you 1-1.5 inches. If you get more it means your torsion bars were sagging or low from the factory (typical with the Sport package). 205's (standard tire size) 235's (optional tire size) 30's should clear all but the ones with sagging torsion bars 31's should fit with minor trimming/reshaping, anything larger needs lift. Tire Sizes with 2-3" of lift 31's should fit, if using stock wheels expect the tires to rub on the frame and sway bar at full lock 32's should fit with minor trimming 33's should fit with massive trimming Tire sizes with 5-6" of lift 32's should easily clear, if using stock wheels expect the tires to rub on the frame and sway bar at full lock 33's should fit with minor trimming 35's may fit with massive trimming Tire sizes with 7-8" of lift 33's should fit easy 35's should require minor trimming with 8 inch wheels, more if 10 inch wheels are used 36's would require massive trimming to be done. 9" lift (SAS) 37" tires should fit easy 38.5" tires may fit with a body lift or trimming. Last edited by orangesonoma : 02-19-2007 at 10:18 PM. |
Re: 4X4 S10 Lift Kits
Good info,
thanks for posting this. |
Gyro eatin fool!
Nice post, but I like to add to the Fabritech part. It is not sold anymore and it was overpriced junk.
Is in Austraila.
Thanks for the info.
My 2" body lift is in the mail coming to me as i post this ![]() |
Quad MX racer #24
I vote for that to be a sticky!
Thanks........I wish I could edit the post........i have some things to add
Is in Austraila.
just add it in an other post
So it seems like the SuperLift 6" kit is the best way to go???? Does that kit come with the brackets to lower the front diff?...or do you have to fab your own?
Is in Austraila.
but it his the highest. |
I want it up there but dont want to have to replace a bunch of parts every few thousand miles either. |
Gyro eatin fool!
Lift kits, most of the time, do not cause the extra wear and tear on your truck. It is the tires/wheels you pick and how you drive it thats going to cause the extra wear.
Forester
yah nice post. this is all the info i've ever wanted on lifts in one place. one good thing about the server going down is posts like this one that organize all the data into one place. i vote for a sticky too!
ZR2 mini-truckin'
I was thinking bds 5'' lift on a reg cab 4x4 with 31-32 inch tires no wider than 235 on stock rims, I'm willing to trade parts that come in the BDS kit for better ones, just want something relible and strong, I'm picking all my stuff out then just saving up for it, got $3000 saved up now (lol 6 months of saving) I hope I wont need any money to trade my 2wd in for a 4x4 s10, my 2wd truck should be a good down payment to keep my payments around the same they are now.
Was thinking of getting fabtech upper control arms, uniball ball joints etc. I didn't want the Trailmaster because I didn't like the axle flip in the rear, but my friends jeep had a lift this way and it was pretty good. |
also like to add superlift has a 6 inch
I third that decision
cool to the tool
4th
Dangerous
and then
Mr. Sparkle
sticky plz
seriously this deserves a sticky
forum idiot
done
#24 |
forum idiot
#25 |
#26 |
Offroad4Life
This kit comes with differential drop bracketry which helps maintain factory C.V. joint angles. It includes new steering center link tie-rod extensions and shocks. However, because it utilizes stock upper a-arms, you need to cut them for shock clearance. Rear lift is achieved by relocating the leaf springs from bottom to top of axle. This lift is also not without problems, in some trucks there doesn't seem to be enough camber adjustment, which causes the insides of both front tires to wear VERY badly due to the tops of the tires are still laid in about 2.5 degree's. This is caused by the way in which drop brackets are mounted. If they are a fraction of an inch off it could cause this problem. The best correction is adding the upper control arms from the Superlift 2" or Rough Country 2" lift. Depending on the amount you go off-road, you will see premature wear of idler arms, pitman arms and halfshafts. If you use the kit with stock, cut upper control arms they may break. This is the one on my truck,I go offroading quite frequently,the best thing I did to avoid premature bushing wear was buy a set of poly's from LMC truck. |
#27 |
Just to save George and Crazy91S10 the trouble
#28 |
"No lift or Torsion Bar tweak
Torsion bar tweaking can gain you 1-1.5 inches. If you get more it means your torsion bars were sagging or low from the factory (typical with the Sport package). 205's (standard tire size) 235's (optional tire size) 30's should clear all but the ones with sagging torsion bars 31's should fit with minor trimming/reshaping, anything larger needs lift." Can you correct a sagging torsion bar by cranking it out more, or is it a different part that is used on the sport models? |
#29 |
Gyro eatin fool!
Yeah you can...Just watch your CV angles and that should give you a good idea of when to stop. You dont want too much of an angle on them. Check out a thread for torson bar cranking. There was a lil howto somewhere I thought.
#30 |
#31 |
95 S10 4x4 5" BDS Lift
95 S-10 4x4 4.3 5" BDS Suspension Lift on 32x11.50 BFG AT's
My 16 year old son and I (i'm a carpenter, not a mechanic) installed the kit ourselves in the driveway. Pretty straight forward for the most part. Took us about 30-40 hours. Here's a before and after, and a couple shots of what happens when you are 16 and zig instead of zagging in the dunes! ![]() |
#32 |
