what engines will bolt up to the t-5?
Ok i have a 1993 2.8 5 speed s10. the 2.8 just isn't cutting it any more.
i really don't want to do a 350 swap. i want something that will get decent gas mileage have good torque and be easy enough for a cave man to swap in. I just need to know what engines will bolt up no problem to my t-5? |
Heavy Metal Body Man
Re: what engines will bolt up to the t-5?
the t5 came behind the small blocks in the third gen camaros/firebird/etc, so anything with the old small block bellhousing bolt pattern it should bolt up to
4.3, 305, 327, 350, 383, 400 |
so if i got the same (or close) 4.3 and the engine mounts could i possibly just swap it easy peasy. what all would i need from a donor vehicle or junkyard.
more or less yeah, anything you find is going to be tbi, which means youll need the computer and harness for the engine youre swapping in, so like you said, a complete donor vehicle will make this much easier, dont try to use any of your existing 2.8 wiring, it wont work
i know you said you didnt want a 350 swap, which i assume you mean v8's in general... but take into consideration a tpi 305 out of a camaro/firebird.. its not uncommon to see those get 20 mpg, and being a tpi they make great down low torque which you said you were after, and as long as you have a donor car to pull it from, it would not be any different than the 4.3 swap youre talking about food for thought |
the 305 was actually something i was thinking about. one of my dads friends just swapped out his 305 for a 350 in his camaro. but it is in parts and has no harness with it. what would i need to get the 305 running in my truck with the t-5?
would i need custom motor mounts or special harness? how hard is it to shoe horn a v8 in these trucks? |
You...Tonight
gm never produced a 383. any gm 383 is a stroked 350
im just covering all the bases |
You...Tonight
i'm just sayin 355,377,383 they're all basically a 350 in case the OP doesn't know. simmer down now lol and i wasn't directing the post towards you i was just stating a fact,sorry man
Gettin' ready for V8!
Actually a 377 uses a 400 block... just throwing that out there... |
You...Tonight
a 400 and a 350 block are essentially the same as far as outside architecture and dimensions tho correct? a chevy small blocks a chevy small block really if one fits they all fit
Registered Neanderthal
The 2.8 doesn't have the smallblock bolt pattern, It's a 60* V6 and the smallblocks are 90*V8, so, no smallblock is going to bolt up to your T5 unless you get a bell housing for a small block.
A 3.4 will bolt to it. Last edited by SH-60B : 11-03-2009 at 09:48 PM. |
Camaros had both 60* V6s and 90* V8s. It depends on the motor. IDK if the tranny itself is the same (kinda doubt it), but the bellhousing is different. 2.8L is from the 60* family - a norrow bolt pattern, 4.3L and all smallblocks are 90* - a much wider pattern.
