4blow
Vibration Question.
i got a 4/5 drop on the truck and about to be bags on front and 6" drop in back. i got a small vibration now. looking at getING a shim kit . dont know nothing about this topic. can i get some help. am looking at a geting this form a guy on a forum. It comes with a 3/4" thick billet aluminum transmission mount spacer, and longer mounting bolts to raise the transmission 3/4". 1" thick billet aluminum center-support bearing spacer, and longer bolts to raise the center support bearing 1". Billet steel pinion alignment shims, and new mounting bolts. THE SHIMS ARE 4 DEGREES. This kit is from jags that run..WILL THIS ONE WORK.
Knowledge is power.
Re: Vibration Question.
u using angled blocks?
4blow
no. it is a 4in drop leaf spring and 2 in flat block
Knowledge is power.
yeah u need an angled block with that much drop . if you look under your truck you axle shaft with be arching upwards at the yoke
4blow
well its a 2000 s10 ext cab. with the 4/5 i have now. (gonna be bag/6). looking at it everything looks prety dead evan stright. and it got a small vabration and it eat u-joints like nothing.
Knowledge is power.
ext cab need angled blocks all trucks are diff. the slightest degree diff can be bad
