trans problem
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 09-17-2008, 12:26 AM   #1
.::Custom User Title::.
tscustoms's Avatar
tscustoms will become famous soon enough
trans problem
i went to take the truck for a test drive the other day to see how it ran after the body drop. the trans shifted from first to second great, then when it was trying to go into third, it acted like it was in neutral. could it be the third-fourth clutches out, or maybe a valve not opening letting in fluid to change to third? someone also told me that there was a cable going to it that needed to be adjusted right for it to go into higher gear. i changed it from a 5 speed to an auto and didnt know that there had to be a cable, what could it be? thanks.
Old 09-17-2008, 10:11 PM   #2
goin broke but n style
S15vortecpwr's Avatar
S15vortecpwr is on a distinguished road
Re: trans problem
if you swapped in a 700r4 you have a kickdown cable. if that cable is not hooked up you CAN and WILL damage the tranny
Old 09-18-2008, 01:15 AM   #3
tscustoms's Avatar
Re: trans problem
i got the cable hooked up but i didnt have it adjusted
Old 09-18-2008, 01:34 AM   #4
easterwabbit
fastr68's Avatar
fastr68 is on a distinguished road
Re: trans problem
ok well firstof all its not a kickdown
700r4 cable is a throttle valve cable
it runs your shifts and if itsnot set properly you can kill that trans pretty quickly in short order
to set it properly push the lock button on the cable housing at the throttle cable bracket on the intake manifold
pull the cable hopusing itself all the way forward as it will go,towards the throttle unit
now open the throttle linkage all the way by hand under the hood until its all the way open
you will hear a couple clicks
this is the cable setting itself
let go of throttle now
done
thats it
it is now set correctly
it should make for noticeably quicker firmer shifts
if the tranis is stillnot shifting at all or correctly
then it may be too late
try fluid seal conditioner bottle asap
sometimes funny acting trannies stop acting funny with seal conditioner added to them
i use the stuff in all my trannies regardless if they are working fine or not
good insurance for them
good luck
Old 09-18-2008, 10:22 AM   #5
tscustoms's Avatar
Re: trans problem
done
thats it
good luck
thanks for the help man!! the way i was told to set it was to push the pedal down, push in the button on the cable, pull it all the way out and let let go, but i didnt hear no clicks that way, gonna try it, much appreciated man!!
Old 09-18-2008, 06:30 PM   #6
tscustoms's Avatar
Re: trans problem
i got the cable pulled all the way out and it acted like it wanted to go in third, but still didnt, anything else?
Page generated in 0.09547 seconds with 12 queries
