th350 problems
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 08-12-2008, 08:09 PM   #1
Have you seen my kitty??
dre0227's Avatar
dre0227 is a glorious beacon of lightdre0227 is a glorious beacon of lightdre0227 is a glorious beacon of lightdre0227 is a glorious beacon of lightdre0227 is a glorious beacon of lightdre0227 is a glorious beacon of light
th350 problems
Got a th350 in my bro's 70 nova. The tranny worked great when we had the sbc in it. about a week ago we pulled that motor and put in a 454. We put a 2800 boss hog stall in the tranny.(tranny had shift kit in it already) Also hooked up a b&m rachet shifter with it. Now here comes the problem. The tranny works great when you shift through all the gears manually using the rachet shifter and hammering on it. when you just drive it normal it shifts great into all the gears. once it is in 3rd gear and your going down the road it seems like it almost goes in to nuetral. but than if you shift it into nuertal than back into drive 3rd gear works fine for a few miles than does it again. We pulled the stall and put the stock convertor back in it same problem. anybody have this problem before. Any ideas how to fix it. Tranny fluid is new and full. not over full either. thanks
Old 08-12-2008, 08:13 PM   #2
I'm slap happy, bitches!
Deeze49686 will become famous soon enough
Re: th350 problems
when it gets hot, put it in reverse really quick,does it go in good, or does it slide? sounds like you glazed or burnt direct clutches when you dropped a BB in ft of it.
Old 08-12-2008, 10:44 PM   #3
dre0227's Avatar
Re: th350 problems
Did that. goes in the same if it was cold. Its just weird how you can slam through all the gears right into third and stay on the throttle and it doesnt act up at all.
Old 08-12-2008, 11:08 PM   #4
camaro1 is on a distinguished road
Re: th350 problems
when you are at wot you have no vacuum at the modulator so your line pressure is higher
if it is slipping when you are just cruising i would say you need a rebuild
just make sure your linkage is set up correctly,,, i have seen so many people try to set there shifter using park position to set the cable, WRONG
have the cable removed from the trans, always place the trans in 1st(low) gear, then place the shifter in 1st(low) gear,, then adjust the cable length to slide the cable into the trans linkage
Old 08-13-2008, 12:22 AM   #5
Re: th350 problems
in the 350, you have 2 different oil paths for the direct clutch. one in reverse
and one in 3rd gear, thats why they have that damn lipseal flipped upside down in the drum. if you dont have any slippage in R when hot, it means you have a pressure loss in 3rd gear. and the fact that when you tromp it down, it holds means that its more than likely in the drum (lipseals) or the sealing rings on the pump. either way its destined for a rebuild.
Page generated in 0.07936 seconds with 12 queries
