Symptoms of a bad torque converter - S-10 Forum
post #1 of 23 Old 06-27-2013, 03:54 PM Thread Starter
boomnblzr's Avatar
User is: boomnblzr is offline
I think I may need a new one. Just seems it has no balls/horsepower at times. Would like to know what else could lead me to believe it's this part and not something else.
post #2 of 23 Old 06-27-2013, 05:27 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: Symptoms of a bad torque converter
I've had alot of automatics over the years and I've never had a torque converter failure. I have had some get contaminated from a transmission failure tho and replaced both. You need to look at the motor and other parts of the truck and eliminate them as a possibility. For instance, a general lack of balls could be caused by a restricted exhaust, like a cat converter blocked inside from broken honeycomb, a clogged fuel filter or intake filter, stuck brake caliper, etc.
Teamsters Local 1150
SH-60B is offline
post #3 of 23 Old 06-29-2013, 10:03 PM Thread Starter
boomnblzr's Avatar
Hey wait a minute....do you work for Sikorsky?? Looked up that teamsters local 1150 and saw they laid off some people...?
Anyway, I got a new cat converter last summer. Fuel filter was changed within a year.
post #4 of 23 Old 06-30-2013, 06:45 PM
goin broke but n style
S15vortecpwr's Avatar
tell us what type of vehicle you have. there can be several things that can cause a vehicle to be sluggish.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #5 of 23 Old 07-01-2013, 05:45 AM
It's "Neanderthal"
SH-60B's Avatar
Yes, latest rumor has July 3 as a layoff.
When you say it has a lack of power sometimes leads me away from the torque converter, I think that would be 100% of the time accompanied by some noise.
SH-60B is offline
post #6 of 23 Old 07-02-2013, 04:10 AM Thread Starter
boomnblzr's Avatar
Sucks. Sorry to hear. I've been thru many survival layoffs before. But I ask because we do some Sikorsky work at my job. We're a offload/vendor aerospace shop.
Anyway, back on topic, I got a '92 s10 blazer....2wd 2 dr. Sounds as if something in the muffler/piping/cat converter. I hear a "pop" every now and then. I think too the Torque converter is out. Is there a way to test the muffler w/o cutting open with a welding torch?
post #7 of 23 Old 07-02-2013, 12:56 PM
"POP" could mean you are running lean. running lean will cause you to losoe power.
pull a plug out from each bank and see what they look like. if they are ghost white, than you are lean.
post #8 of 23 Old 07-03-2013, 03:10 PM Thread Starter
boomnblzr's Avatar
I'll look into it also. I should mention that I gave it a tune up, done myself, within a year ago.
post #9 of 23 Old 07-06-2013, 12:13 AM Thread Starter
boomnblzr's Avatar
So...I removed a few spark plugs and have a little brown around the sparking area, and a little whiteness...nothing seems too concerning tho. And I have what looks like oil around the spark plug threads. Seen it before when I change them out.
post #10 of 23 Old 07-07-2013, 10:05 AM
"factory freak"...
Crew Cab Sonoma's Avatar
If it seems like a lack of power from a stop or very low speeds, it could be a broken
sprag clutch for the stator in the converter. It will cause a loss of torque multiplication
that the converter produces under high stall conditions, such as accelerating from a stop.
Once the vehicle is up to speed, it feels fairly normal again.
95 S-10 2.2. Soon to be DD
post #11 of 23 Old 07-10-2013, 04:05 PM Thread Starter
boomnblzr's Avatar
*Sigh* Anything is possible I guess. I changed out the oxygen sensor the other day. But that's all I'm gonna do. It obviously didn't fix the problem. Not gonna sink anymore $$ into it right now...needs a new owner.
post #12 of 23 Old 07-13-2013, 04:03 PM
The Dave Inc.
xxosiris9xx's Avatar
User is: xxosiris9xx is offline
hmm im curious about this too. mine seems to fluctuate/flutter about the 40-60mph/2k-2.5k rpm range (when it normally is hittin 4th or in 4th and the rpms normally drop just a bit more) and then eventually evens out under part throttle but has pulled just fine 3/4-wot.
THE DAVE|2003 S10 PNEUMATIC
post #13 of 23 Old 07-14-2013, 11:24 AM
"factory freak"...
That sounds more like a converter clutch issue,
or possibly a problem with 4th gear.
post #14 of 23 Old 07-15-2013, 02:27 AM Thread Starter
boomnblzr's Avatar
Mine is automatic.
post #15 of 23 Old 07-21-2013, 06:40 AM
Drege's Avatar
User is: Drege is offline
my 87 2.8 is crap at red lights and such, once I hit OD+35 its great, OD -35 and off tha line it almost feels like its gonna die -- no bucking or hitching, just a hesitation, like a dead space in the accelerator cable, as if it were a electronic slide rather than a cable and butterfly. old/bad/dirty injector nozzles maybe?
Anyway, I thought maybe my TC was bad too, but the tranz fluid is beautiful, nothing leaks and it passed California smog with flying colors - not bad for 198xxx miles (but I suspect a rebuild/reconditioned motor fairly recently)
Drege is offline
post #16 of 23 Old 07-21-2013, 12:28 PM
User is: transbuilderguy is offline
you could have no low end power due to a freewheeling stator...also a locked stator will give you good low end but fall off durung cruising speeds...converter clutchslipping usually you will have a blue converter from heat buildup and if you can also have no movement at all in any range.
post #17 of 23 Old 08-08-2013, 08:57 PM Thread Starter
boomnblzr's Avatar
You mind telling me what the hell a stator is?? And also I have no clutch...it's an automatic. This happens in drive gear only.
post #18 of 23 Old 08-08-2013, 09:49 PM
crankz1's Avatar
User is: crankz1 is offline
crankz1 is offline
post #19 of 23 Old 08-10-2013, 11:42 PM
lol as above and yes the converter has a lockup clutch inside the converter which is like a manual clutch it provides a direct coupling from the engine to the input shaft at cruising speeds
post #20 of 23 Old 10-21-2013, 12:45 AM
Drege's Avatar
Seems mine was a dirty barrel and inteke manifold throat, I got some carb/choke cleaner for the hell of it and emptied it in the TBI a few spurts at a time, revving it after each jet.
Ain't hesitated since.
Also just drove to east Texas 100% problem free, Learned that any significant hill or mountain pass I godda be doin minum 75, anything less and I'm crawling up it at 35 - 45 but that may just be me, wasn't tryna push it and blow the engine, it shows 201k now.
87 S-10 Blazer 4x4 - 2.8l 4spd automatic - 2door - - 206xxx = possible rebuild
87 Toyota Tercel 4wd wagon - 3a 1452cc (1.5l) SOHC - 5spd standard - - 221xxx
78 Dodge M500 (10 ton HD chassis) 30 foot RV - 440-3 4bbl - 727 loadflite high torque 3 spd auto - - 29xxx miles
80% of time is working, 12% sleeping, 4% eating, 3% dreaming and 1% enjoying the fruits of 99% of my time.
Drege is offline
post #21 of 23 Old 10-25-2013, 08:48 PM
User is: s10rac3r is offline
i am having a similar issue. I have a 92 s10 350 swap with th350 auto trans with manual valve body. I noticed this before but thought it was my brakes but there is a rapid clicking when im accelerating and as i slow it goes away and stops. I also noticed when driving if i go from drive to neutral the clicking stops almost instantly. Along with clicking it seems a recent loss in acceleration and horsepower.the only changes i have done recently is front wheel bearing change.
s10rac3r is offline
post #22 of 23 Old 10-29-2013, 01:02 AM
i saw what you did there!
fast68chevy's Avatar
its amazing that ppl dont know that there are at least 5 clutches in auto trannies
manual trannies only have one clutch
ppl are amusing lol...
clutch doesnt mean manual
at all
clutches are actually almost always automatically controlled
instead of manually, by the operator
a/c compressor clutches are kind of controlled both ways
when you tur on the a/c manually you are turning on auto control of said clutch, via the pressure switches and a relay
then theres a clutch o the mechanical engine cooling fans
and so on
theres a billion clutches on a vehicle
post #23 of 23 Old 10-29-2013, 09:58 AM
Drege's Avatar
I think you need to reread the basic operations of integral drive systems fast68, you'r a little misinformed.
Furthermore check your grammar and punctuation, you've missed a few slightly important textual grammatical annotations for a proper and concise post reply.
Drege is offline
