Sway in truck
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 08-24-2008, 02:17 PM   #1
2_Sweet's Avatar
2_Sweet is on a distinguished road
Sway in truck
ok i have a 99 extended cab sonoma and it has some sway in the rear end. it only happens between gears or when u let off the gas and then go back in it. just trying to get some ideas of what it might be.
Old 08-24-2008, 02:29 PM   #2
bellcranks no more
greencactus3's Avatar
Re: Sway in truck
loose axle ubolts or broken main leaf or shackle will cause that
Old 08-24-2008, 02:32 PM   #3
the youngest has been
tippmann243's Avatar
tippmann243 is on a distinguished road
Re: Sway in truck
my old truck did the same thing. of throttle it would track straight. on throttle it would dog leg.
turned out to be bad leafspring bushings
Old 08-24-2008, 02:55 PM   #4
2_Sweet's Avatar
Re: Sway in truck
aight i will try to look at the leafsprings, i put 3" blocks in there bout 4 years ago, so that could be the problem
Old 08-24-2008, 03:39 PM   #5
bellcranks no more
Re: Sway in truck
or in that case the locating pins may have sheared too.
but remember, the ubolts need torqued to 80ft lbs. not hand tightened
Old 08-25-2008, 10:42 AM   #6
Ex-Import Lover
Nate_C is on a distinguished road
Re: Sway in truck
try tightening the u-bolts, thats what was causing it on mine, and for the time being you might not have to pull everything apart if thats the case.
Old 09-02-2008, 02:02 AM   #7
2_Sweet's Avatar
Re: Sway in truck
thanks for the help guys, turns out that it was the u-bolts, they were pretty loose so i tightened them up.
Page generated in 0.08545 seconds with 12 queries
