Slave cylinder leaking? Replacement? - S-10 Forum
post #1 of 5 Old 01-13-2005, 02:21 PM Thread Starter
User is: snobordr is offline
Hello all, I have a 1996 S10 Vortec V6 (code W) and the 5 speed manual transmission. My clutch system is currently leaking I believe as it is taking fluid and still going soft in the pedal on me on occasion. I think it is the slave cylinder (most likely suspect) and want to know how difficult this is to replace. I have heard that you need to pull the tranny in order to access the slave cylinder, is this true?
thanks in advance.
snobordr is offline
post #2 of 5 Old 01-13-2005, 02:31 PM
Strictly Domestic
PEKO's Avatar
User is: PEKO is offline
Send a message via AIM to PEKO
Re: Slave cylinder leaking? Replacement?
Yes the slave cylinder is inside the transmission. So the transmission will have to be taken out
AMP/NATIONAL GUARD BABY #88
PEKO is offline
post #3 of 5 Old 01-13-2005, 02:37 PM
Strictly Domestic
PEKO's Avatar
I couldnt get any pics up but hope this helps. This is straight from GM.. Concentric cylinder is another name for the slave. This is for a 2000 but the slave is the same as a 96 so the instructions should be the same. Also dont forget to remove the hydraulic line from the slave :-)
Remove the transmission. Refer to Transmission Replacement in Manual Transmission - NV1500 or Transmission Replacement in Manual Transmission - NV 3500.
Remove the 2 bolts securing the concentric actuator cylinder to the clutch housing.
Remove the actuator cylinder from the transmission input shaft. If required, the bearing can be removed from the actuator cylinder for replacement.
Installation Procedure
Position the actuator cylinder to the transmission input shaft. Ensure that the bleed screw and the coupling are positioned toward the transmission ports.
Notice: Refer to Fastener Notice in Cautions and Notices.
Secure the concentric actuator cylinder to the clutch housing with 2 bolts.
Tighten
Tighten the bolts to 8 N·m (71 lb in).
Install the transmission. Refer to Transmission Replacement in Manual Transmission - NV1500 or Transmission Replacement in Manual Transmission -
PEKO is offline
post #4 of 5 Old 01-13-2005, 02:45 PM Thread Starter
Thanks a lot Peko, appreciate the info. I will have to take it to the garage as I do not have the facilities to remove the tranny, was kind of hoping it would be easier than that.
snobordr is offline
post #5 of 5 Old 01-13-2005, 08:12 PM
Long Bed Member
92S10LB's Avatar
User is: 92S10LB is offline
Send a message via AIM to 92S10LB Send a message via Yahoo to 92S10LB
moved to proper forum.
on topic that really sucks cuz my 97 is doing the same exact thing, but i really dont feel like dropping the trans right now.
97 S10 ext. cab 4.3 5spd, clears, intake, exhaust, system, slammed 6/7
94 Blazer - 4dr 4x4, lowered 3/3, cowl hood, billet grille, rollpan, exhaust
70 Chevelle - Pro-Touring project, 468 BBC,th400 for now, full global west suspension, 4wheel LS1 disk brakes, 17" billet rims for now.
my S10F gallery
92S10LB is offline
