Ok guys i have a treat for you all. i stumbled upon a COMPLETE service manual for the S-series trucks a while back. i believe these are GM manuals as they go into crazy step by step detail with full procedure and torque spec documentation. the PDF files were broken up into sections so i will post them in the appropriate sections. if the following links do not work, let me know and i will try to correct it. just make sure you have flash/java and all that updated on your browser.
here is a link to the complete service manual that i uploaded. this includes everything from electrical, to engine, and suspension as well as body.
https://skydrive.live.com/redir?resi...CQUOw603XC--lY
Complete 4L60E rebuild/overhaul. full torque specs, exploded parts view, and procedure inside.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!124&authkey=!APRtSZrBztcG8Vc
4L60E SERVICING
https://skydrive.live.com/redir?resid=5429672B1FB043B7!129&authkey=!AP0TsvS0K-w2LwM
NV1500 REBUILD
https://skydrive.live.com/redir?resid=5429672B1FB043B7!151&authkey=!AEMAotCHCQpSbYo
NV3500 REBUILD
https://skydrive.live.com/redir?resid=5429672B1FB043B7!149&authkey=!ADlrfxyNQHciQmY
SHIFT LOCK CONTROL
https://skydrive.live.com/redir?resid=5429672B1FB043B7!154&authkey=!AHa-FwbbIKcF3Sg
MANUAL TRANSMISSION SERVICE NV1500 AND NV3500
https://skydrive.live.com/redir?resid=5429672B1FB043B7!153&authkey=!AM7Sj29QoXxl6Qo
REAR SUSPENSION
https://skydrive.live.com/redir?resid=5429672B1FB043B7!152&authkey=!AEujguhWaaH-vdo
REAR DRIVE AXLE. goes into rebuilding the rear end.
https://skydrive.live.com/redir?resid=5429672B1FB043B7!158&authkey=!AO0jrPEILm5jYuo
FRONT AXLE (4x4) rebuild
https://skydrive.live.com/redir?resid=5429672B1FB043B7!143&authkey=!AC4sS6HZL2AbQdg
4L60E SERVICING
NV1500 REBUILD
NV3500 REBUILD
SHIFT LOCK CONTROL
REAR SUSPENSION
