Replacing Valve body. - S-10 Forum
post #1 of 8 Old 11-25-2004, 01:45 PM Thread Starter
Low Standardz 1's Avatar
User is: Low Standardz 1 is offline
I have had problems with a hard shift between 1-2 gears and the P1870 code being set. I found a service bulletin on the problem. There was a problem with the valve body on the 4L60E transmissions used on the 1996-2000 model year trucks. They say just to replace the valve body with the new design and that fixes the problem. Is this easy to do while the tranny is on the trucks lifted up or do I have to pull the tranny. I don't really want to pull it. Has anyone done this.
post #2 of 8 Old 11-25-2004, 06:22 PM
Got spray? Got boost? (y)
hellbents10's Avatar
User is: hellbents10 is offline
Re: Replacing Valve body.
You do not have to pull the trans to do it. Just need a filter kit, gasket, valve body gaskets. You can also try a Superior shift correction package ment to eliminate this problem. I have done this to one and succesfully fixed this problem. The harsh 1-2 shift is becuase of the code the computer commands increased line pressure to help prevent trans falure. Rember there is 4 different sized bolts in the valve body, putting one in the wrong place can make the whole trans lock up.
DD 2003, 5.3 mp112, e85....11.8@123
post #3 of 8 Old 11-26-2004, 01:33 AM Thread Starter
So it is not hard to do, it just takes some time to fix. New filter and new fluid is what I will also do, but the problem is the valve body according to the tranny shop, and General Motors.
post #4 of 8 Old 11-26-2004, 03:05 AM
Quad-Turbocharged Blazer
nystateofmind27's Avatar
User is: nystateofmind27 is offline
Send a message via AIM to nystateofmind27
More info on the Superior shift correction kit please. I have a fully built tranny which shifts a hard 1-2. How difficult do you think it would be to install this kit?
Originally Posted by LunaticSVT
It is starting to look as if intelligence is not a strong point with people on these forums
post #5 of 8 Old 12-12-2004, 12:00 PM
autotech's Avatar
User is: autotech is offline
removing the valve body is more or less straight forward, just have to have the check ball location perfect...http://www.atraonline.com/manuals/se...7/1997_052.pdf, you will need to go to a trans shop ad get alittle trans lubew for holding the balls in place, reg. grease will plug the valve body.
and with the use of a 10 and 8mm, I think it is 8-12 ft/lbs reinstall the torque,
with my experience the TCC solenoid should also be replaced ( the thing that is up by bellhousing passenger side)
autotech is offline
post #6 of 8 Old 12-12-2004, 12:02 PM
autotech's Avatar
if you are having other questions, email me www.120244602@fvtc.edu
I will walk you along, I do this shit for a living and for fun(wife thinks I'm nuts)
autotech is offline
post #7 of 8 Old 12-13-2004, 02:56 AM
User is: 99church is offline
i purchased the sonnax 4l60e sure cure kit, for out 99 blazer. its supposed to address most/all of the problems with the 4l60e, and i've been told by someone who installed it that it took them 3 hours, didn't have to drop tranny. will let you know how it goes
99church is offline
post #8 of 8 Old 12-13-2004, 02:12 PM
Nice Jorb
cavymeister's Avatar
User is: cavymeister is offline
Send a message via AIM to cavymeister
Most built tranny's are designed to shift hard from 1-2. It's not an actual problem in your case.
The B&M shift kit I installed said to use vasoline. It disolves in transmission fluid.
Also, when you do this, just make sure you keep everything clean and pop a drain plug in the pan to make future fluid changes easier.
Originally Posted by Shaw
"The problem with her is that she lacks the power of conversation, but not the power of speech.."
