Replacing Oil Pan gasket - S-10 Forum
post #1 of 4 Old 05-10-2010, 07:04 PM Thread Starter
User is: motoxxxloak is offline
Hey there Im new to the site and to the S-10 world...I just bought an S10 a few days ago, and i notice its leaking from the oil pan (bad gasket I assume) so I took it to a shop and they threw it on the lift and I could see that it was a bad gasket. In order to change the gasket, they told me they had to pull the motor...is this true? how hard would it to DIY...???
oh and its a 98 S10 4cyl 5 speed (i think a 2.2)
post #2 of 4 Old 05-11-2010, 02:03 PM
User is: Freezeman is offline
Re: Replacing Oil Pan gasket
u have to do an engine lift to get to the gasket cuz the pan sits right on the front axle. my uncle replaced his oil pump by putting 4 4x4's on the engine mounts but he had take out the old pump and put in the new pump blind. so yes u can probably DIY but its easier if u just pay to have it done i think.
post #3 of 4 Old 05-13-2010, 05:50 PM
i saw what you did there!
fast68chevy's Avatar
yes espcailly a 2.2L
this is a big job and you gotta remove alot of parts and more to get the pan off these things evne getting the starter off these is a huge ordeal its not fun at all. the exhaust is right in the way and all the brackets and engine mounts need bolts pulled and wow.....
seal conditioner in the oil and tighten up the pan bolts, then see how it is
are you sure its not the RMS leaking?
or the FMS?
post #4 of 4 Old 05-31-2010, 06:04 PM
2ToeRacing's Avatar
User is: 2ToeRacing is offline
don't 2.2's have a aluminum oil pan? if so you can lower the pan replace the (O ring) type gasket.you can stretch it around the OUTSIDE of the o/p and slip it into the slot,put it up and tighten the bolts. My 4.3 has a o ring type.
Thanks
2ToeRacing
Blue 98 X-cab,factory ZQ8,3:42 Alburn posi,SS brake lines,Floor shifter.
Thats me In my avatar doing a happy face burn out in front of my house.
Life is like a sh!t sandwitch,the more bread you have,the less sh!t you'll have to eat
