Replacing Broken Wheel Studs??? - S-10 Forum
post #1 of 22 Old 09-18-2005, 04:47 PM Thread Starter
User is: haymaker11 is offline
HELP PLEASE!!! broke three wheel studs on one of the rear wheels of my 95S10. how do i replace/ change them? anyone know how? is it hard? easy>? how is it done?
post #2 of 22 Old 09-18-2005, 06:43 PM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
Re: Replacing Broken Wheel Studs???
pull the drum off and beat them out then use a lug nut and an impact to pull the new one in place
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #3 of 22 Old 09-18-2005, 08:24 PM Thread Starter
are you sure it's that easy??? there is a big plate that covers the backside of the drum/hub area .... you can't see the back of the studs at all. check this link to see the plate i'm talking about look at the pic: http://www.s10forum.com/forum/attach...55772&viewer=1
post #4 of 22 Old 09-18-2005, 08:27 PM
No more switches
CustomS10's Avatar
User is: CustomS10 is offline
Send a message via AIM to CustomS10
i thought u had to take the axle out to get them out.
-Ben-
Dime sold...but not forgotten
post #5 of 22 Old 09-18-2005, 08:56 PM Thread Starter
i had feared that. this pic shows that plate that covers the drum.hub area
post #6 of 22 Old 09-18-2005, 09:07 PM
Getting faster
ZZ4Blazer's Avatar
User is: ZZ4Blazer is offline
Send a message via AIM to ZZ4Blazer
I had enough room to get them in from behind the axle when I broke mine. All I had to do was pull the drum off. Air hammer will usually make short work of them as well.
Jim 94 Stepside
New v8 combo coming
5/6 drop QA1/hotchkis
ATS tall spindle/14" Z06 brakes
6 speed / 8.5" rear
post #7 of 22 Old 09-18-2005, 09:31 PM Thread Starter
i can't see the studs even because of the plate that seems to cover the backside of the drum.hub as it shows in the pic i supplied. maybe there is a way to remove this plate?>
is yours a second gen?
post #8 of 22 Old 09-18-2005, 09:40 PM
Getting faster
ZZ4Blazer's Avatar
1st or 2nd, shouldn't be any difference. Your not gonna be able to see the backside of it. Yank the drum off, you'll see the axle flange, and the studs.
If you busted the studs, theyr'e short enough to just about fall out the back of the axle. You'll need to spin the axle around and find the most clearance around the brake stuff to fit the new stud back into the axle flange.
Just need to take 2 minutes and work it in there.
Trust me, theres enough clearance. I've done it myself. Took me maybe 30 minutes to replace them.
Jim 94 Stepside
New v8 combo coming
6 speed / 8.5" rear
post #9 of 22 Old 09-18-2005, 11:09 PM
import killer
syclonekid43's Avatar
User is: syclonekid43 is offline
Send a message via AIM to syclonekid43 Send a message via Yahoo to syclonekid43
x2. the picture that was posted was the backing plate. that hold the shoes,springs,and wheel cylinder. it has nothing to do with the wheel studs.
91' syclone (0465)
88' tuneport gta
93' 4dr jimmy
93' blazer
88' s-10 blazer (2 wd)
01' raptor
97' mxz 670 yamaha ysr 50 with a 125 cc 6-speed
THE SURGEON GENERAL WARNING NEVER SAID ANYTHING ABOUT SMOKING A FORD
post #10 of 22 Old 09-18-2005, 11:12 PM
pvfjr's Avatar
User is: pvfjr is offline
Don't ever do that. You're supposed to used a press. Drawing them in by the threads is a very bad practice, any good mechanic will tell you that. It's easy to do it that way, but the torque required to seat them properly will over stress the studs. Either that, or they won't be seated properly. I'm guilty of doing it wrong too, until someone who knew better educated me.
pvfjr is offline
post #11 of 22 Old 09-19-2005, 02:05 PM Thread Starter
actually it does. read my posts, i said the backing plate covers the entrie hub where the studs are located, making it impossible to get at them from the back end with that in place. you have to remove the drum, shoes etc..to be able toi see the hub and stus. there isn't much room back there champ. post something i didn't already know next time.
post #12 of 22 Old 09-19-2005, 02:13 PM
NO H-body, New Dime
User is: IceDime is offline
Send a message via AIM to IceDime
just take the axle out, its a slam! Remove the wheel and drum. Then remove your pumpkin cover and spin the axle till you see the pinion shaft in the middle of the gears. There is a small bolt going through it. Remove that bolt and the pinion shaft will literally fall out. Then there is a c clip that just falls out if you push the axle in towards the gears. Then you can just slide the axle out. Its really easy. remove bolt, shaft, c clip, then pull axle out. SLAM. Then you can take it somewhere and get it pressed in or use the lugnut method. If you use the lugnut way go to lowes and get 3 or 4 grade 8 washers and put them between the lugnut and axle. This will spread out the impact from all the torque so you damage the axle flange or the stud. good luck buddy. PM me if you need help.
Bagged 2000 s-10 built to DRAG for trade for STOCK or close to it daily
http://www.s10forum.com/classifieds/...&cat=22&page=1
Vertically-Challenged Alabama Chapter V.P.
IceDime is offline
post #13 of 22 Old 09-19-2005, 04:26 PM
Getting faster
ZZ4Blazer's Avatar
You don't need to go through all that. I busted one of mine right before I was leaving to go racing one night. They won't let me race with a stud missing. It took all of maybe 30 minutes to replace it in mine.
All you have to do is pull the drum off. And spin the axle for the most clearance.
Jim 94 Stepside
New v8 combo coming
6 speed / 8.5" rear
post #14 of 22 Old 09-19-2005, 04:54 PM
been doing it this way for years and never had one problem
-mark
post #15 of 22 Old 09-20-2005, 05:36 PM
Sky.... here i come
User is: sonoma-project is offline
Send a message via AIM to sonoma-project
How much different would it be to change the front stud in my 1997 S10 4WD?? I snapped one off putting my tires on last night.
1997 S-10, Black, 4x4, V6, 32" Wild Country's
Just got shackled 3/2/05, full 2 inches all the way around
Keyways, 8/15/05, 1 more inch
9/10/05 Body lift, full 5 inches of lift
9/19/05 32x11.5x15 Wild Country TXR's
post #16 of 22 Old 09-20-2005, 05:44 PM
my hoopty
5timedime's Avatar
User is: 5timedime is offline
Send a message via Yahoo to 5timedime
x2. no problem. just make sure you got an extra lugnut or two and some type of spacer between the nut and the axle. I used to use old fwd axle shaft nuts.
If nothing else, go ahead and knock out the broken ones, and then you will see how much room you have to work around the inside of the brake shoes.
'89 x-cab 4.3 auto. dime number 6
post #17 of 22 Old 09-21-2005, 01:53 AM
Pushrod for life!
pare_john's Avatar
User is: pare_john is offline
Send a message via AIM to pare_john Send a message via MSN to pare_john
any mechanic who says that has too much time on their hands. you do not need to go through all that. pulling them through with a lugnut works just fine. i have been doing it that way for yearsand never had a problem
1992 Chevy S10, 3.1L V6 5 speed. Bored .40 over, 272 crane cam, heads ported,polished,plained. Decked block. Port matched intake.
Valve job. High compression pistons. Roller rockers. AFPR. Compression 9.5/1. 3.43 rearend. 2/2 drop. Taurus E-Fan
www.s-series.org
post #18 of 22 Old 09-22-2005, 10:35 AM
but then again what would i know im not ASE certified or anything
-mark
post #19 of 22 Old 01-07-2015, 07:05 PM
User is: 0Evil1 is offline
Thanks everyone.. I get to replace some on my new 90' s-10 2wd... I will let y'all know how it goes for me in 0 degree weather!... got to love not having a garage!
0Evil1 is offline
post #20 of 22 Old 01-08-2015, 01:20 AM
I will say, the hammer/heat/pb blaster.. I have replaced two... its 0 degrees with a wind chill of -14 right now so im giving up for the night.
0Evil1 is offline
post #21 of 22 Old 01-08-2015, 05:39 AM
Dichotomy In One
Blazed5spd's Avatar
User is: Blazed5spd is offline
Nobody mentioned it but I wouldn't pull them in dry, when I pulled the new ones in with the impact I used a buttload of grease on the threads and around where they slide into the axle face....
post #22 of 22 Old 01-08-2015, 08:07 AM
BLU BALLER
xskarekrowx's Avatar
User is: xskarekrowx is offline
I've never used grease, always done it the way most others. Knock em out from the front, then push the new one in from the back, stack some washers, install lug nut, impact, done. Just realized this thread is from 05', glad it helped ya though.
95 S10 LS 2.2 5spd
Fully bagged, caddy tails, fully shaved, and more shit.
Built not Bought
http://www.s10forum.com/forum/f30/pr...nished-667738/
