rear axle ratio RPO
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 10-12-2005, 02:52 PM   #151
Certified Underage Drunk
bww3588's Avatar
Re: rear axle ratio RPO
Quote: Originally Posted by Gspot
i have an 87 s10 2.8L 5 spd 4x4 with a 3.73 posi, i've broken some of the disks in the posi and theres gettin to be a good build up of shrapnel on the magnet, so im lookin for another rear end, does anyone know if theres any problem with putting in a 83 blazer rear end?
as long as its 4x4 and your 87 dosent have ABS. i think in 87 they started puttin ABS on em. so the 83 wont work if yous has ABS
Old 10-12-2005, 03:58 PM   #152
Gspot's Avatar
i realized that the 83 was a 3.42 ratio, so thats outa the question, but i found an 89' 4.3L blazer 4x4 and the guy says its a 3.73 govnerlock, and he only wants $100 for it. I dont know if its got abs but i'll ask him. if it does, is there any way to make it work in my non abs truck?
Old 10-12-2005, 10:06 PM   #153
bww3588's Avatar
if yours dont have ABS which it should because its an 87 but any rearend will work if it dosent have ABS then your good but if the rear has it just leave it unhooked and take the sensors off from behind the axles before the tube.
Old 11-07-2005, 04:55 PM   #154
bluestreak2.5's Avatar
My 85 has descriptions next to the codes on the sticker, and they're telling me it has front and rear locking diffs with 4.11s.
Old 11-11-2005, 07:23 PM   #155
Special Ed
1slammedx's Avatar
the g80 is an EATON locking diff. It locks when a 100rpm difference is detected between the two side gears-the two spider gears that are splinned to the axle. it also will not or should not lock over 20 mph. it is an interesting little setup in the case. my 02 s-10 standered cab xtreme with a v-6 and a 5spd has the g80 and the 3.08 gears. it is a 8.5 ring and pinion. the same case that is in the fullsize silverados with the 8.5 .the easyest way to tell between the 7.65 and the 8.5 is the diff cover and gasket. the 7.625 is more oval shaped and the 8.5 is circular.
Old 01-27-2006, 07:53 AM   #156
takes 2 balls in our game
s10-den's Avatar
Quote: Originally Posted by RedSpeck_09
i just checked my beater and its says GT5. that just doesn't make sense to me. a 4 banger with a 4:10 ratio? its a 95 2.2 5 speed. can anybody tell me about this?
the 4 bangers need the gears to get them moving
Old 01-27-2006, 07:56 AM   #157
s10-den's Avatar
Quote: Originally Posted by DimeTime
I have a 01 w/ 4.10, and i was wondering how much of a difference it makes in acceleration, and in gas milage, if someone has changed from 4.10 to 4.56
you dont want to do that....you will not tell the difference but you will in gas mileage.by the way,I live here in T-town too.
Old 05-07-2006, 05:42 PM   #158
dreaming of bags
low97s10's Avatar
is there any way to tell what gears you have without the rpo codes and with out pulling the rear cover. my rear end went out a couple years ago and i got one from a junkyard. he said it was the same as mine but it had the third shock and it is a diff ratio. mine had 3.73's and this is lower (3.42 maybe?) speedo reads 50 and im actually around 55
Old 05-12-2006, 02:18 AM   #159
squaredime's Avatar
any reason I have GQ1 AND GU6 on my tag in the glove box? could they not make up their mind between 3.42 and 3.73?..ool
Old 05-13-2006, 06:04 PM   #160
[]D[][]\/[][]D
ok got a 89 s10 2.5L "ID", the codes i got are gq1 gt4, whats the deal.
also i want to put 22 150 spoke knock offs. is it possible or a dream.
Old 05-25-2006, 05:51 PM   #161
mikewiebe1987's Avatar
mines has three codes, gu6 g51 then g80 am i missing somthing retarded simple
Old 06-04-2006, 03:24 PM   #162
1988 2.8L R W and B
Bob35josh's Avatar
i have an 88 x cab 2.8 auto. it has 3.08's according to the codes on here. i also now have an 85 x cab with 2.8 auto. it has no sticker in the glove box and i havent got to drive it yet....still waiting on motor to be dropped. does anyone have any clue what it might be? its like i said 1985 2.8L x cab auto, s-10 tahoe, loaded out, power windows/locks, tilt wheel.
help me, please. anyone....
Old 06-28-2006, 12:12 AM   #163
2003blackchevys10's Avatar
what would it help if i changed my 2003 2.2L 5 spd from 3. 73 to 4.10 ???
Old 06-28-2006, 07:08 PM   #164
bww3588's Avatar
nothing, it would make your MPG drop and 1st gear useless.
Old 07-30-2006, 12:47 PM   #165
Deezer's Avatar
I have a 2002 xtreme truck.Sorry can't seem to delete thread reposting under new thead.
Old 09-13-2006, 12:00 PM   #166
one way to tell what you have in gear ratio is to jack up the rear and mark the drive shaft and tire...now turn the tire one revolution and count the time the mark on the drive shaft goes aroun..it should give you a good estimate if you do it right..(3 time =308) (3.5=3:42)(3 and 3/4 apprx. =3:73) etc..
Old 01-20-2007, 12:11 PM   #167
EP Representin
babyboyfuz8's Avatar
should i stay with my 3.08 gears or switch to 3.42? in my 99' 4.3 gas mileage don't bother me, i want a little more torque, would that be 3.42?
Old 01-21-2007, 06:13 PM   #168
you said that the lower the ratio the better gas mileage... i have a '93 s10 ext cab, with a 2.8l v6 5spd and it has 3:08
gears and revs at like 5000rpm and drives at like 55 max... horrible gas mileage, i went on ALL Data and Mitchells and it told me that truck should have either 3:73 or 4:11 gears, im not sure of the numbers in the glove box but since you said that the 4cyls should have the 4:10's then does that mean i should have the 3:73's?? if anyone can help please email me jon_brown06@yahoo.com
Old 02-27-2007, 08:51 PM   #169
Banned
i have a 95 blazer that says gu6 g80
i remember spinning one tire when ever i took a rite and both on a hard left
sometimes i could lock both on power brakin so does that mean i have a limited slip
id really like to know b/c that blazer was totalled and now i have an s10 w/ just gu6
Old 03-06-2007, 10:47 PM   #170
lstude's Avatar
I put a 2002 Sonoma rear in my 52 Studebaker. I bought it from the S-10 Warehouse but I couldn't remember what the ratio was. This thread sure helps.
Old 03-12-2007, 09:29 PM   #171
aj_111_78
Posts: n/a
User is:
Does anyone know if you can get gears lower than 4.56 for the 7.5 or 7.65 rearend? I am looking for 4.88 or 5.13
Old 03-17-2007, 09:13 PM   #172
Quote: Originally Posted by speedydtp247
i'm lost. exctaly what row/column do i look at to find out what gear ratio i have?
the codes are listed in the glovebox in alphabetical order
Old 04-05-2007, 11:16 PM   #173
G75 mean anything?
Old 04-23-2007, 10:40 PM   #174
ok i swaped out the original diff because the housing was broken from a wreck
so does the axle have an axle tag like ford do
if not how do i find out what it has now
just wondering
Old 05-02-2007, 08:47 PM   #175
Dranko's Avatar
does anybody know the top speeds on these different rearends with the vortec 4300 and auto tranny
Old 06-15-2007, 10:04 PM   #176
Woolford's Avatar
so the G80 is the locking diff, does that mean i have a POSI or i dont?? And i have the 3.08 gears. Im not to familiar with this stuff so are the 3.08 gears good lol??
Old 06-24-2007, 09:05 PM   #177
89-S-Dime's Avatar
Quote: Originally Posted by DoubleDown
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
G80 - locking differential
compare to the codes in your glove box to know which gear ratio you have
Just wanted to add that H04 = 4:11 is found in pre-1994 S10's (most commonly 4x4 Jimmys and Blazers)
Old 06-27-2007, 03:50 PM   #178
does anyone have a 4.3 5 spd w/ 3.42's or 3.73's.. hows the gas milage, and the revs at 100kms/60mph?
Old 07-20-2007, 12:46 AM   #179
Woolford's Avatar
ya i have the 3.73's. Gas is a lil better than autos at like 20mpg but still shitty. And if i can remember i think my rpms are around 2500 at 60
Old 07-27-2007, 05:25 PM   #180
Im Gonna Eat Yo COWNBREAD
sippiwhiteboy's Avatar
I have a '87 2.8 extra cab 2wd. The code says it has 3.73's. Is this why 1st gear is more or less a granny gear? My heap is turnin 4500 rpm at 65-70 mph. Should I change the dif or tranny?
Old 08-22-2007, 02:32 PM   #181
my truck has 2 codes listed it has GU6 and GQ1 so what would my Ratio be
Old 08-29-2007, 11:58 PM   #182
Blublazin's Avatar
My blaze has 3.73 behind a 6sp. With 315 x 35 x 17 tires. Turning about 1800 RPM's @ 75 MPH.
Old 09-03-2007, 04:33 PM   #183
I have a 2002 4.3 5 speed. I want to give my truck some more power/torque. I think my truck has the 3.73 rear end and I was wondering what would happen if i swapped that out for the 4.10 rear end? Is it correct that the 4.10 rear end comes in the 4 cyl s-10?
-Eric.
Trinityaqk@gmail.com
Old 09-06-2007, 11:48 AM   #184
blue blazer ed's Avatar
I have a 83 Blazer with a 2.8 . Im looking to chrome out the rear end.
Going to junk yard to get one so my Blazer wont be down while this is happining. My question witch rear end should I look for , what year to what year to look for, and will the U joints be the same?
Old 09-11-2007, 01:34 AM   #185
xtreme one
sonofavette1's Avatar
ok my code for my x blazer is GU6 and G75 so what the hell is G75
Old 09-11-2007, 03:55 AM   #186
is a fungineer
ka_jd7and1's Avatar
G75 : AXLE REAR, 3.62 RATIO
Heh, I think you got a typo somewhere.
Old 09-15-2007, 07:23 PM   #187
BLAZIN1990's Avatar
will 3rd gen blazer rearends bolt right up to a 1st gen blazer
Old 09-18-2007, 03:33 AM   #188
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
what if there is not a sticker in the glove box how else can i find out
Old 09-20-2007, 08:05 PM   #189
Lifted Member
Rinkrat456's Avatar
Put wheel chocks up front, lift the rear on jack stands. Take the differential cover off and rotate the wheels until you see two numbers marked into the ring gear. Divide the large number by the smaller number (for example, 41 ring gear teeth divided by 10 pinion teeth gives you a 4.10 ratio). This is the sure fire way of knowing what ratio you have. There are others, like turning the wheel and watching how many times the driveshaft goes 'round, but that's eyeball and usually wont get accurate enough to tell the difference between 3.42 and 3.73, and 3.73 and 4.10, since the ratios are close together.
Chances are you needed a fluid change and new gasket anyways. $40 well spent.
Forgot to add the pic.
Here's the numbers I'm referring to. ALL American axles have these numbers stamped into the ring gear. The blue circle is what I'm talking about.
Old 09-25-2007, 08:49 PM   #190
I have a 85 s-10 standard cab extended bed. It has the 2.8 v6 with a 4 speed manual and 2 wheel drive. I dont have a sticker in my glovebox so i was wondering if anyone had an idea of what gears it would have thanks
Old 09-25-2007, 08:54 PM   #191
Lifted Member
Rinkrat456's Avatar
Read the post above yours.
Old 09-28-2007, 01:13 PM   #192
Re: rear axle ratio RPO - Confused
I am confused.
First, I have a 96 SS with 97K GU6 (3.42) G80, and an 01 with 19K GU6 G80.
I was under the impression that the lower the number, the better the acceleration. For example, with the 3.42, for every 3.42 revolutions of the transmission output, you rotate the gear driving your tires 1 time. Likewise if you had a 4.10 you would need 4.10 revolutions from the trans to get the same 1 revolution on that final wheel gear. If that is correct, then the fewer revolutions you need the quicker you can go.
However, after reading this thread, everyone seems to be sayiing the opposite... that a 4.10 will provide better acceleration. If this is accurate, then please help me to understand why this is the case.
Thank you,
~Ryan
btw - this is my first post here.
Old 10-16-2007, 12:52 PM   #193
Its Mr. Kandel to you!
kandel123's Avatar
ok The G80 is a locker. General motors calls it there "G80 Locker" it locks when the weights in the diff sense i difference of 100 RPM. It locks 100% but if you let off the gas it will dissengage. If you power brake the rear end it will not unlock untill you get out of the throttle. When you release the pedal it becomes an open rear end untill it senses a 100 rpm difference
Old 10-16-2007, 06:28 PM   #194
Eddygordo23's Avatar
Question Re: Differentials
Quote: Originally Posted by Nate8727
Ok here is a rundown of the different cabs and engine combos for differentials. I found this out just by building an s-10 on chevy.com
2.2 4cyl- regular cab LS - manual tranny/3.73
auto tranny/4.10
extended cab LS- manual tranny/4.10
auto tranny/4.10
regular cab xtreme- manual tranny/3.73
auto tranny/4.10
extended cab xtreme- manual tranny/4.10
auto tranny/4.10
4.3 6cyl- regular cab LS- manual tranny/3.08
auto tranny/3.42
extended cab LS- manual tranny/3.08
auto tranny/3.42
regular cab xtreme- manual tranny/3.08
auto tranny/3.42
extended cab xtreme- manual tranny/3.08
auto tranny/3.42
Positraction is not available on the 4cyl engines
Positraction is available on either the 6cyl manual or automatic transmissions. I didnt get it in mine, darn it I should of ordered one. Ah crap... oh well, better luck some other time. arrrrrr
ANYWAY ENJOY, IM SURE ALMOST EVERYONE IN HERE WILL
now this says my truck being a 2.2 5spd is a 3:73 but the first post in this thread says the code GT5 is the 4:10 and that is the code i have. so which do i got?
Old 10-16-2007, 06:29 PM   #195
nevermind i got it figured out
Old 10-25-2007, 12:45 AM   #196
Definite Obsessions
Madkaw_16's Avatar
To clarify for some people wanting to change a 3.73 to a 4.10. I changed mine in my '00 4dr. with a 4.3 auto, and it has really good acceleration, but my mpg went from 23, to 18. I'm gonna have some fun with it for a while, but will be changing it back shortly.
Old 10-25-2007, 01:29 AM   #197
I was rear ended and my axle was bent. Instead of replacing the axle I swapped the whole rear end from 3.73 to 4:10. I knew a guy with a V6 who had an extra so it was a cheaper job. I enjoy the faster pickup from a stop sign, my 3.73's were just too slow. I did suffer on gas millage but think it was worth it. 2001 2.2 LS 5-speed
Old 10-25-2007, 09:52 PM   #198
If it feels good, Do it!
ss350's Avatar
Just wanted to update this sticky.
On 98-01 Blazers 7 5/8 ring gear, 28 SPLINE, the length of the axle is 26 3/8".
On 98-01 S10/S15 Trucks 7 5/8 ring gear , 28 spline, the length of the axle is 26 5/8". I had to learn this the hard way.
Quote: Originally Posted by Larry Black
there are two different types of axles used. the number of splines that fit into the spyder gears make the difference. all other spec's are the same. to find a posi, limited, locker, try light line of Louisiana. they have fairly diecent prices. www.lightlineofla.com.
Old 11-07-2007, 11:42 PM   #199
stuck static
lowxpectationz20's Avatar
anyone got some 308s they want to sell?
Old 11-10-2007, 01:21 AM   #200
you got hosed tommy!
jd101proof's Avatar
simple solution.....if you want to know what gears are in your truck without crawling around, or extensive research on the net.....the next time you are cruisin through town, stop at your chevy dealer parts counter with your VIN# and have the parts guy look it up. of course this wouldnt work if someone else swapped your rear, but chances are that they havent since it is a commonly overlooked item. hope this helps! -also, you can find out darn near anything from the parts dept by your VIN#
jd
Page generated in 0.66800 seconds with 31 queries
[Output: 211.63 Kb. compressed to 192.47 Kb. by saving 19.17 Kb. (9.06%)]
