#101 |
Re: rear axle ratio RPO
I've read that there are three different types of rear ends fitted intot he 96' style s-10? what is the difference/what is the best way to find out which rear end I have? buy rear end I'm speaken of the pumpkin.
#102 |
Hello there!
oops
#103 |
#104 |
V8 Member
thanks buddy,
#105 |
I still can't figure out what the rear end on my 84 s10 2.8 4x4 is... all I see here on the build sheet is GQ1, nothing that says anything about a GU???
u guys tell me... ![]() |
#106 |
I believe that this is the wrong sticker to be looking at to find the numbers ur looking for. But don't know about everyone but mine is located on the bottom side of the glove compartment. Is it possible ur sticker has been pulled or something?
#107 |
that is the sticker (and the only one in the truck) that was at the bottom of the glove box... all the options match the truck, and so does the VIN #...
#108 |
This is the way I live
heres a site with a list of all the RPO codes http://www.wiu.edu/users/muwtj1/rpocodes.htm
#109 |
4 wheel drive junkie
Just a bit of clarification about the "locking differential" in GM trucks:
It is dubbed "Gov Lock" It should *not* be confused with a GM car-type "PosiTraction" unit. They are two different designs all together. A "Posi" uses clutches pushed together by an "S" shaped spring to get the friction between the clutch packs. The truck unit is in fact a locker. It gets it's nickname from it being developed for government-vehicle use. GM supplied many 4X4 truck to the US military, but the government mandated a locking differential be employed. To reduce costs in the long term, they colaborated with the Eaton Corp. to produce a locker with open differential characteristics, but full-on locking capabilities. It is a complicated diff unit, much more so than normal gear actuated lockers. It acts as a weak limited slip, until a predetermined amount of difference is achieved, then the unit locks by using a series of centrifugaly(SP?)-activated springs that allow levers to move into position to their coresponding vallies in the diff-thus providing full lock up. A regular locker (Detroit Locker, EZ Locker, Lock Right, Etc.) uses torque from the driveshaft to lock the diff. What happens here is the driveshaft applies torque to the pinion, the pinion to the ring gear, and the ring gear to the carrier, carrier to the carrier pin. When this force is applied, the carrier pin "loads" the gearset of the locker, putting outward pressure on the inner gears, pushing them outwards onto the outer gears (keep in mind that this is all happening *inside* the carrier). When no force is applied, the gears will slip past one another, and the result is the characteristic "clicking" sounds you'd get while rounding a corner. This allows some differentiation of the tires, and significantly reduces tire wear (unlike the welded diff I run ).So, in essence, some of you are right, and some of you are wrong. The term "Limited Slip" does not really apply in this case. Now, welcome me to the boards. I'll be getting a '95 S-10 4X4 tomorrow, and I've already got a '92 GMC Jimmy -Later! |
#110 |
Quad-Turbocharged Blazer
Great explanation UserName and welcome to the forum.
#111 |
Glad to be here!
#112 |
#113 |
There is a simple calculation that you can do to figure out the correct ratio to run that will be closest to the stock setup when you swap to a larger tire. I can't seem to find it right now, but I will search around a bit and post back with the info.
#114 |
Here you go!
Don't forget to get an ACCURATE measurement of the tires you will be using vs. an accurate measurement of your current tires. Use the "specific gear" calculator to figure out what you'll need to get (just keep trying different ratios until you get to the closest set-IE:4.27,4.56,4.88,etc.). And also remember that if you have a 5 speed that the overdrive gear is approximately "0.75", so enter that as the specific gear to get an accurate highway RPM calculation.:thumbup: http://ringpinion.com/content/calculators/RPM.asp |
#115 |
Does anyone know what comes in a zq8 reg cab with a 4cyl 5spd
#116 |
check your RPO codes in your glove box and compare it to the list at the begining of this thread - most likely they are 3.73's
#117 |
I dont have a zq8, but I just picked up some zq8 wheels with smaller tires
#118 |
i have a 4.10 and i want to change it what should i change it to
#119 |
depends... which engine do you have?
#120 |
Certified Underage Drunk
#121 |
#122 |
Location: mesa, az (otherwise Known as Hell) User is: OffLine |
to all that claim the factory g80 diff., is not a locking diff.(go to tthe link)
http://www.traction.eaton.com/prod2.htm it is a auto locking diff. |
#123 |
Lurch
how can i tell the difference btwn a 7.5 rear end and a 7.625 rear end? if it involves crawling under the truck to measure then what you do measure? only need the info to order lsd/posi. thanks.
chris |
#124 |
#125 |
Lurch
#126 |
#127 |
#129 |
what would a mid 80's longbox auto v6 have in it for gears? i picked up the whole rear end from a friend today
#130 |
the youngest has been
how the **** should we know
it would help if we new waht motor and trans you had check the rpo codes |
#131 |
for one thing i asked a simple fockin question and you reply like that? fock you tippmann!
there was no rpo codes on the truck, longbox, 2.8, auto |
#132 |
take the last 8 numbers inb teh vin and call a dealer or there is suposed to be a id number on the rear
#133 |
Can i put a G80 posi and 4.10 gears in my truck that has 3.43's before?
#134 |
also where can i get the G80 at?
#135 |
yes you can put in a g80, but if your gonna put posi in an open diff i would get something a little better thana a g80 and gears have to be installed by a pro, the tolerances have to be perfect adn if they are not, you will eat up gears
#136 |
#137 |
can i get the get the gears from a gm dealer?
#138 |
ConvincedEVERYONEisondope
Location: barack hussein obama mmm mmm mmm User is: OffLine |
I LOVE these kind of informative type threads!
Thanks guys,I had questions about my 3:42 G80 S-10 and well.........now I dont!!! Dont get me wrong you Limited slip(or w/e you call it)guys,I love the one wheel peel,this is my first"locker". Keep posting and I'll keep reading! Im a newb too this code searching thing! |
#139 |
What axle does my 93 have in it?
#140 |
#141 |
lost
Im wantin to put a trans brake on my 93 4.3l S10 can it be done and can my trans take the punishment
#142 |
I have been playing with the caculators on http://www.machperformance.com/calculators.html and im messing with the mph for rpm rance one. The truck is a 97 4.3 5spd ext cab. z85. The code in the glove box is gu4 3.08's but when i got to messing with that caculator it dosant add up. i am at 2450 rpm's at 70mph in 5th gear (.78 OD right?) That adds up to a 3.43 rear end?!!! I have the stock tire size on it. If i did have 3.08's id be going 70 mph at like 2150 rpms
I Cant make the numbers add up, what overdrive dose my trans have? |
#143 |
#144 |
Thanks for the overdrive # but that dident make a diffrance. im at 1500rpm in 4th gear at 35 mph. what makes peferct sence is is that i somehow got 3.43's with an open diff but with the gu4 in the glove box. If you use the caculator with 3.43's and a .83 od I turn 2460 rpm at 70 mph, My spedo is dead on. So where is the id numbers on the rear end at?
#145 |
#146 |
so theres nothang on the outside of the case?
#147 |
#148 |
Heres the numbers on the right side axle tube AA1 K 348 2
I have a full set of service manuals for a 99 but they dont show the AA1 paart that tells you the gears |
#149 |
Anyone?
#150 |
Location: Saltspring Island, B.C. Canada User is: OffLine |
i have an 87 s10 2.8L 5 spd 4x4 with a 3.73 posi, i've broken some of the disks in the posi and theres gettin to be a good build up of shrapnel on the magnet, so im lookin for another rear end, does anyone know if theres any problem with putting in a 83 blazer rear end?
