#51 |
I have a code GQ1 and then GU6 in my 86 auto extended cab. What does that mean....is it a 3.42 or a 3.73?
#52 |
CHANGE YOUR EMAIL ADDRESS
m=y truck came with a 2.5 and a 5 speed tranny dont have glove box codes it most likley has a 3.73?????????
nuke |
#53 |
8majik
#54 |
Location: mesa, az (otherwise Known as Hell) User is: OffLine |
![]() Last edited by 350*s-blazer : 08-23-2003 at 10:37 PM. |
#55 |
on my 89' s10 blazer 4.3l 4x4. in the glove box on the second row of codes the last 3 sets of codes read:
GQ1 GU6 G80 So Im asuming Its the GU6(3.42) and a locker(G80). So what does GQ1 stand for cause It can't stand for a ratio cause you cant have 2. Is one of them the t-case ratio? The reason I think the GU6 is a ratio code is cause every almost everyone ahs stated they have something other than GQ1 as there ratio(i'm not saying they don't have that code just that they probly found one of the axle codes on the first list ) the other codes follow sequence GU2,GU4,GU6...GT4,GT5... AND ONLY ONE GQ, the GQ1. so I think its another drive train option that someone has mistaken for a ratio code. question is what does it stand for? if it wasn't saturday night id call the dealer. ![]() Last edited by 350*s-blazer : 08-23-2003 at 10:35 PM. |
#56 |
Looked around with google GQ1=standard axle ratio(came standard on the vehicle)
http://www.polariswebdesign.com/GMRPOCodes.pdf Last edited by 350*s-blazer : 08-23-2003 at 11:30 PM. |
#57 |
#58 |
tight ass S10
i have a 88 2.5 5speed reg cab with a gt4 3.73 .im fixing to do my v8 con will the 3.7 10 bolt hold up to 450 hp with a turbo 350 tranny
#59 |
ok ya'll. none of ya'lls trucks have a locker, unless under any given condition, both rear tires spin. limited slip is a term when power is transfered to the wheel with less traction. if each tire has equal traction(or somewhere close) then both tires will transfer power. a true locker locks both rear tires under all conditions. ask any educated person in the offroad world, and they will back me up on this. they are the ones who know everything about lockers. they are the ones who basically came up with the idea of a locker. a locker does exactly what it says, locks the tires together. and there are different kinds of lockers, full time lockers, air lockers, or gearless lockers. some trucks come with gearless lockers(which are crap).
#60 |
4bangn, the 7.5" ring rearend you have will eventually break with 450hp v8. especially if you get on it alot. they put it in f-bodies, but it's only made to take about 300hp or so.
try to find one out of a zr2. those are 8.5 ring. not sure of the ratio, but it will bolt up. otherwise, you can put anything you want in there with enough work and/or $$'s. sign_in_name, you are basically correct, except that limited slip transfers power to the wheel with the MOST traction, not the least. if it was otherwise, the tire with no traction would just spin 'till it gives up the ghost, and you would be stuck in that mudhole. i'm sure you knew that, and just wrote it backwards, but for those others reading, it's power to traction, not power to slippage. the best advantage of a limited slip over a full time locker is cornering. when you take a corner, the outer wheel takes more revolutions to get around the bend. you really don't need positraction (limited slip) for regular street driving, unless you tend to have a heavy foot, and spin one wheel, or you just like the look of a true burnout. one wheel burnouts dont count. "never attribute to malice that which can be easily explained by stupidity"-anon- click if you hate pidgeons : http://perso.wanadoo.fr/chuu/Trucs/Final_Bird.mpg Last edited by birdgears : 09-09-2003 at 09:06 AM. |
#61 |
forever flames
i got a form from gm that states that i have the limited slip rear-end which makes sence considering that my truck had the towing pkg. and a 5 speed, but it says gt4 in the glove and i know its a limited slip cause when i go to the track and go straight its always 2 wheels, can somebody explain cause my story has been contricted somewhere above... ???????
#62 |
![]() Last edited by 350*s-blazer : 09-24-2003 at 02:52 AM. |
#63 |
Registered Abuser
so what size is the ring gear? 7.5 or 8.5?
I sure hope I got the correct diff... Got a Zexel unit waiting to be put in, just looking for a diff cover and the greese to get the pattern. Is the inside diameter of the ring gear the same on a 7.5 and a 8.5 diff? Last edited by erronisme : 10-01-2003 at 09:52 PM. |
#64 |
I am lucky enough to be blessed with the covetted 3.08. lol. My 99 x is a 4.3 auto with the 3.08. But im kinda happy with that, just means i can get more acceleration by throwing a different rear gearing on there because i can only go up.
#65 |
What is the usual ratio for a 96 4.3L 5 spd. manual. 2WD LS package S-10.....my sticker in the glovebox is gone and I need to know, Thanks.
#66 |
CHEVROLET COUNTRY \/6
my 91 4x4 is a gu6 3.42 it pulls alright 0-60 times are slow though low nine high 10 times.
#67 |
sloooow downnn!
#68 |
i was in all data the other day and found out the g80 is made by eaton.
#69 |
How come i have a 1996 Chevy S10 with the 2.2L and i have limited slip?
I have tested it...in snow, the power shifts between wheels on the rear axle. I had my brother nail it at a stand still on ice, and the power shifted from left, to right, to left, to right, till it grabbed |
#70 |
LT. Morgan
Re: rear axle ratio RPO
Ok, I have a 90 and I looked in my glove box and found nothing there????? Am I just not lookin inthe right place in it or waht??? Where exactly are the codes located?
#71 |
v6 auto normal tranny = 3.42
v6 5 speed = 3.08 v4 5 speed = 4.10 v4 auto = 4.10 |
#72 |
I hate you
What if I dont have my glove box any more? How can I tell? Also the list only has LS models, what about base, base models?
#73 |
Off Roadin' Member
This G80 locker/posi/limited slip stuff has been gone over 5 billion times. it is neither a locker nor a limited slip, it is a POS...no really it isnt either one, its a hybrid of both. it contains clutches and springs like a limited slip, but it also has a cam mechanism, that when the clutches engage, that cam "lobe" slides over and locks up those clutch plates so its fully locked up, like a locker.
#74 |
Project: Sabriel
#75 |
eat hondas and s**t fords
How Bout Gq1 And Thats The Only Code In My Glove Box, It Was An 2.8 With A 4 Speed Manual Trans, I Counted Teeth Once And They Seemed To Come Out To A 3.42 But I Could Have Been Wrong
#76 |
[quote=meangreen9c1]Don't all 2.2s come with the 4.10s?[/QUOTE EXCEPT REG CAB 5SPD. THEY HAVE 3.73
#77 |
Find it funny here is the GMC spec AXLE RR Rear axle, 3.42 ratio, (TS10603 Regular Cab, short box, TS10803 Regular Cab, long box and TS10653 Extended Cab) (GU6) $0.00 Rear axle, 3.08 ratio, (TS10603 Regular Cab, short box) (GU4) $0.00 Rear axle, 4.10 ratio, (TS10603 Regular Cab, short box) (GT5) $0.00 all 2.2 L that I have owned had a 4.10 ratio this does not mean they didn't make something else.. maybe 10 years ago when you got your truck they used diff trany... |
#78 |
I think he was referring to the "V4" thing....
#79 |
4 banger Sorry Mr. muddy
#80 |
OK heres one, whats it mean if i got a GQ1 and GU2 ???
4.3 auto 88 |
#81 |
1st Gen come stock with 8.5?
I have a 89 S10 with an 8.5 with 3.08 gears its got the GU4 code in the glove box. But did s10 even come with an 8.5. Ive only seen 7.5s in them. Would the prev owner put it in or is it stock? What kind of posi would it have?
#82 |
Nagaremono
where can i get a zexel torsen LSD?
#83 |
Nagaremono
#84 |
GoingCarbed4.3
i have an '83 2.8 v6 2d, 2wd w/ 4 speed auto...the code says gq1....and nothing else. i understand its the standard ratio, but ive seen about 3 diff. rations listed here.
#85 |
GoingCarbed4.3
i also have a '91 sanoma used for parts that has the codes GQ1 and GU2......its not a 4x4 so im guessing that means GU2 (2.73 ratio) was the standard (GQ1 reads as 'standard gear ratio' on that RPO code list posted earlier)
so if anyone could help me in figuring out the ratios of this and the one i posted earlier it would be greatly apreciated. |
#86 |
Bad hair day
I want to run 18 or 20 inch wheels on my 03 ext cab 2.2. Now Im being told that I will lose horsepower because of thesize of the wheel swap, but that I can make it up by swapping the gears in the rear end. Now I know that I currently have the 4:10 now, can anyone help with what a better gear ratio would be to regain the lost horsepower?
#87 |
V8 Member
heres one for you all.. my code is a gu2.. that mean i have something higher then a 3.08??
#88 |
I'm Rick James Bitch
i didnt check my codes but my window sitcker said i have 3.08 gears. my differential is a full size though. it has 13 mm bolts instead of a 1/2
#89 |
13mm and 1/2" are pretty damn close in size. |
#90 |
#91 |
Draggin Body Member...
What the hell is a GU2?????
#92 |
V8 Member
#93 |
The GU's are the codes for what gear ratio your trucks rear end has in it. A good friend of mine works for GM and gave me the list that is below. You should be able to find one of these codes on a sticker located inside your glove box.
S-10 REAR END GEAR CODES GU5=3.23 GU6=3.42 GT4=3.73 GT5=4.10 HC4=4.56 G80 - locking differential |
#94 |
V8 Member
#95 |
Sorry i didn't missed the top part of the chart when posted the other one. Here is the top half.
S-10 Rear End Codes GU1=2.41 GU2=2.73 GU3=2.93 GU4=3.08 |
#96 |
Painted in Primer
84 S10 2.8L Ext. Cab 4x4 5spd manual. I have the GQ1, which is the "standard", but can anyone tell me for sure what the standard is?
#97 |
GQ1 Open Differential Rear Axle refers to a non-posi traction rear end. If you look very close at the numbers on the sticker in your glove box you will also find a GU number.
#98 |
GoingCarbed4.3
#99 |
ive got an 87' Sonoma with the 2.5 and a 4-speed, my code is GQ1, and GU6, which means I have a 3.42, but what is the GQ1?
#100 |
oops nevermind
