Quick question for the tranny gurus.
Go Back   S-10 Forum > Engine and Drivetrain Tech > Transmission & Rearend
Old 11-15-2009, 01:48 AM   #1
Works too much.
BlownDime's Avatar
My '92 GMC 2500's tranny shit the bed. It was a 700R4 with an electronic speedometer. I picked up a used tranny, from an '85 Silverado, which has a mechanical speedometer. Any way I can get my current speedometer working with this tranny?
Old 11-15-2009, 02:04 AM   #2
Re: Quick question for the tranny gurus.
they make a adapter for your exact problem you might want to check one of those s10 v8 parts vendors they have what you want. Its called a signal generator
Old 11-15-2009, 05:36 AM   #3
Works too much.
BlownDime's Avatar
Can I just remove the plastic gear driven speedo cable, and slide the signal generator onto the shaft? Or would I have to swap the shafts right out?
Old 11-16-2009, 09:50 PM   #4
easterwabbit
fastr68's Avatar
if you can find the retainer body the same size style
or swap the housing from old style
but some shafts dont have means to attach gear etc
its kinda hit and miss and complicated
regardless there are adapters out there
remove housing from both trannies and check the shafts
see if parts can swap
might.
but if not then you have to debate on whether its better to buy adapter or completely gut both trannies in order to swap the shafts out.. might as well rebuild or shift kit it while you got it gutted then..
when my 700r4 in my 198k mile 91 4.3L burns up if ever ive got a super low miles TH400 with 27 spline output(3L80HD) from a 87 2wd pickup ready for it but i will have speedo issues like this as well. and i wil ahve to cut down the driveshaft since the 3L80HD is 34.5" long and 700r4 are 31.5"
but not a big deal.
but of course the 700r4 wont die since i am ready for it.. the only thing wrong with it is the TCC screwed up in it and i had to unplug it a few months ago.,
198k and still going. great..
Old 11-16-2009, 11:45 PM   #5
Works too much.
BlownDime's Avatar
I spoke to the local parts shop, they said the magnet will read the current gears. Doesn't make sense to me, since they're plastic, but I'll try it.
