Posi Rear End?????
I want to put posi in my stock 97 4.3L pickup.....whats a decently priced setup with out having to get a different rear end.... is there anything in summit or jegs? Your help would be great... Thanks
goin broke but n style
Re: Posi Rear End?????
i put a torsen out of a ls1 camaro in my 94.
bought it off ebay as a take out to install a 12-bolt |
http://cgi.ebay.com/ebaymotors/CAMAR...130244755748is this like what you got?
i am not real sure on teh price but it was less than 100 i know.
That is exactly what i put in mine, you can also check out ls1tech.com and search there |
i like the powertrax lockrite. its really effective, easy on the wallet, and you dont have to mess with reshimming. much easier installation.
Road Racing Blazer
Are 4WD rear-ends differnet? I know I have a G80 so I'm guessing I'd have to pull that. I have a 98 4X4 that needs a posi badly at the autocross, so this sounds like a sweet deal to me. |
It's a bolt in job assuming you keep the stock shims and the differential going on has bearings already attached. In my experience, the Torsen is very difficult to install in a S10/Blazer because it's nearly impossible to get the axles into the differential far enough to attach the c-clips. I could not do it on my S10 nor my old Blazer. I ended up going with an Auburn diff out of a LT1 Camaro.
no problem intalling mine.
you will have to reshim the carrier due to it being a diff carrier. you may get lucky and your fact shims work, but more than likely they won't. i would suggest using new bearings. they aren;t that exp |
