oil capacity for the 8.5" 10 bolt rear end? - S-10 Forum
post #1 of 3 Old 08-02-2003, 01:00 AM Thread Starter
ZQ8 2001
DoubleDown's Avatar
User is: DoubleDown is offline
just as the title says... does anyone know the capacity for the 8.5" rear diff?
thanks!
2001 Black ZQ8
post #2 of 3 Old 08-02-2003, 01:02 AM
musical engine builder
1988S10's Avatar
User is: 1988S10 is offline
Send a message via AIM to 1988S10
fill till it over flows. just get 2-4 quarts of fluid. not sure how much it takes really.
1988 S-10 4X4
3.2L (3.1L bored .030 over), speed pro light weight pistons,moly rings, cloyes timing chain,comp cams camshaft,crower high lube lifters,ARP rod bolts,manley valves,GMPP retainers,lunati springs,crower locks,edelbrock headers,JET fuel regulator, JET stage 2 chip,hypertech 180 degree T-stat,injector POD spacer,TBI spacer,dynomax exhaust,high flow cat,ACCEL 8.8mm wires, NGK iridium plugs,MSD blaster coil.
1988S10 is offline
post #3 of 3 Old 08-02-2003, 01:07 AM
Off Roadin' Member
fmfredrider501's Avatar
User is: fmfredrider501 is offline
Send a message via AIM to fmfredrider501
the 7.5" axle takes just under 2 quarts so i would say it takes somewhere around 2-2.5quarts.
4.3/3500/233/208/44/60/35" General Grabber MT's
