NP207 transfer case possible loose chain - S-10 Forum
post #1 of 4 Old 04-03-2009, 04:20 AM Thread Starter
sewerrat's Avatar
User is: sewerrat is offline
What are the symptoms of a loose transfer case chain? I've got a single hard bump when I get on the throttle. It will do it if you pull out really quickly and sometimes when your flooring it and it shifts to 2nd. Oh by the way mine is a 700r4 in an 85 Jimmy. I've checked for broken trans mount, loose ujoints, Slip yoke play. Thanks
sewerrat is offline
post #2 of 4 Old 04-05-2009, 02:43 PM
Spark Plugs Are Overrated
DieselS10's Avatar
User is: DieselS10 is offline
Re: NP207 transfer case possible loose chain
The chain isn't used unless you are in 4wd, so that probably isn't your problem.
'85 S10 4WD Ex-Cab Long bed, LLY/Allison/241/241, Locked 1 Tons with air-ride and 38's.
-{Click Here For Build Info}-{Transfer Case Doubler Info}-{ Click here for Duramax Swap}
post #3 of 4 Old 04-07-2009, 12:55 AM
3 Leaf Fab
Donahue's Avatar
User is: Donahue is offline
Send a message via AIM to Donahue Send a message via MSN to Donahue
have you checked the trans fluid?
Just an old dad now...for now at least
Donahue is offline
post #4 of 4 Old 04-07-2009, 04:10 AM Thread Starter
sewerrat's Avatar
Yep, both trans and t/case fluid levels are fine. I just realized I have a problem with the t/case shifter. This may or may not be related to my thumping sound. I put it into 4-lo for the first time and the stick won't engage all the way. I'm not sure if the t/case shifter hitting the tunnel. The v8 engine is set back 1" for better radiator clearence. I'll check it out later this week. Thanks
sewerrat is offline
