no reverse or third
hey guys i need some help with my tranny
i gotta 350 turbo out of a 69 camaro i put a b&m rebuild kit n it and stage 2 shift kit n it it has park, no reverse, neutral, drive only has 1st n 2nd no third, then has 2nd n 1st i rebuilt it myself with the help of an old tranny man which cant see very well so im thinkin i prolly left something out any idea wat would cause this |
I'm slap happy, bitches!
Re: no reverse or third
cracked direct piston, or the lip seal in the direct drum is ripped, torn, or not installed.
am i gonna have to tear the insides of the tranny apart to fix this?
yep.
is there a manual that shows like detailed pics besides chilton n thanks for your help
is this the direct drum, only pic i can find. n i cant find a pic of the piston or is the blue thing the piston Last edited by caddynomer : 08-20-2008 at 09:57 PM. |
ya i think it said it was a 400 but im gonna go to the shop n give this a shot ill b back n a lil while
ok i went took apart n i found it n i think there was two of them but i took them both apart n 1 had 4 seals n they were all good n the drum n piston were good, the other one had two seals n drum n piston were good also,
these are about half way down inside the tranny |
did you air check it before you ripped it apart?
no but i did after i put it back together lol n i was readin a gmm tranny book n it said theres a valve n the tranny called a 2-3 shift valve thats sticks and it cause reverse to not work or stick n wont let it shirt to 3rd
did the trans try to shift to 3rd, and rev up, or did it just stay in 2nd gear?
no it just stayed n second but u could kinda feel it pull if u rev'd it way up in reverse
Sounds like burnt out friction/clutch plates in the transmission. its like its only got 1% torque of what it should. |
the tranny only has about 1 mile on it n everything was replaced that should b replaced with an b&m complete overhaul kit
idk but i wouldnt think reverse would burn, n 1st n second still work |
