narrowing a rear end - S-10 Forum
post #1 of 7 Old 02-12-2006, 02:17 AM Thread Starter
User is: down2earths10 is offline
Send a message via AIM to down2earths10
i have a couple 8.2 10 bolts hanging around out of my dads 68camaro i can take. im puting a pretty stout v8 in my truck and im afraid the rear wont hold with posi and some little slicks. so i think might take the 8.2 68camaro rear end and get it narrowed to teh stock s10 width.
does anyone know how much it would approximately cost? and has anyone done this before?
btw i dont carea about the leaf perches cause im going to bag it soon so they wont be on. its a 84 s10 jsut ta let ya know
post #2 of 7 Old 02-12-2006, 04:22 PM
11 second station wagon
The Stunningman's Avatar
User is: The Stunningman is offline
Re: narrowing a rear end
The best thing I can tell you is if your going to make enough power to break the 7.5 then you'll be breaking the 8.2 IMO. You can narrow a 8.5 to stock s/10 width but it will require someone withe the correct alignment tool and professional welding skills. Take a early 8.5 say a (camaro trans am rear) procure 2 ....28 spline axles out of a 2wd s/10 and have the axle tubes narrowed accordingly. A little known fact is that the long axle on a 28 spline 4x4 s/10 is a bolt in (except the metric studs) for 8.5 Nova early Camaro rears. Hope this helps you.
post #3 of 7 Old 02-12-2006, 04:59 PM
FWD's suck
zerogravity58's Avatar
User is: zerogravity58 is offline
Send a message via AIM to zerogravity58
or you can look around and pull a 8.5 10 bolt from a s10. They have 30 spline axles and are pretty strong. I run a 8.5 in my truck with a spool and stuck axles....
92 S10 ex cab, 10.50's @ 130MPH, 1.50 60's 383, th350, 8.5 10 bolt. gone but not forgotten
01 S10 2.2, 5 speed, stepside, ZQ8, 2/3 drop, rollpan, cowl hood.
post #4 of 7 Old 02-13-2006, 12:29 AM Thread Starter
im having a hard time finding them. i heard they came in 95 and newer 2wd s10 and blazers that had a 4.3 in them. and cost is another issue. thats why i was going to try to use our camaro rear end.
post #5 of 7 Old 02-13-2006, 12:32 AM Thread Starter
what are all teh vehicles that came with 8.5 rear ends? did teh newer astro vans come with them?
post #6 of 7 Old 02-13-2006, 12:50 AM
no astro vans have the 7.5 rear. 72 up to 77 chevelles, 72-75 novas, trans ams and camaro's 72-81 + some of the nova clones like ventura,omega etc. are some of the cars you could look for to get a 28 spline 8.5. The trans ams and camaro's are more likely to be posi than the chevelle and nova rears.
post #7 of 7 Old 02-13-2006, 01:30 AM Thread Starter
atleast to richmond gears it says that 70-76 chevelle, 70-75 nova, 70-81 camaro, 70-81 gto/firebird, 72-81 z 28/ta have then in them. i dont know if thats correct cause im reading it out of a jegs catolog in teh gear section. how much would it cost to get a 8.5 narrowed? estimate anyone?
