I have an ls1 corvette clutch/flywheel/pressure plate and throw out bearing lined up for $100 but cuz of the torque tube I'm not sure if it will work for my lq4 t56 combo. I posted the same question on ls1tech and yes I've tried searching.
Hope it works cuz it will at least get me rolling.
It will work fine. All LS1/LS6 clutch and flywheels interchange. The slave/TOB will not work however. They're cheap though, check rock auto. I picked one up there for $67
True, I'm still saving for the Trans but with this I can put it together and get the motor in the truck so I can wire it up and plum stuff and all that jazz.
Nice, then it's just a simple trans install and clutch bleed once you pick one up. Can't recall, do you have a thread going on in the lsx section? You should start one up if you don't already have one!
I do, but it's a rather slow go. Hoping to get the clutch stuff this weekend, along with some other stuff from the pick n pull cuz it's 50% off this weekend!! Hello jeep Cherokee steering box
Derp...it's in your signature....i'm out of it today. Build looks fun! Where you located at? There's a local dude doing an IRS swap on a first gen truck too. I believe he's using nissan s-chassis or supra stuff. Should be a heck of a lot lighter than using solid axle and leaf springs!
Yea, I'm going supra. Changed the plan from a muncie to t56 as the rear is 4.30:1 so I figured I'd like to go faster then 100kmh lol. I should have the subframe bolted up finally next weekend. Then the complicated strut towers
